cmt 340se max dbs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-01-2013, 06:51 PM - Thread Starter
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1233
o
What's the Max output in dbs on my cmt 340se? Is the only way to have an spl meter? My room is 16x22 if I remember right. All closed except one 8 foot opening. Thanks
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
post #2 of 7 Old 07-01-2013, 07:21 PM
Mike Garrett's Avatar
Quoted: 6699 Post(s)
Liked: 4388
Per the math, 118db peaks at one meter, but since it uses a Seas soft dome tweeter on a flat baffle, no way it can do 118db. How much you lose due to distance will depend a lot on your room. In my room, I lose 6db for doubling of the distance. My guess for actual number would be around 113db from one meter. cschang may know what they can actually do.
newc33 likes this.
mjgarrett100@gmail.com
Mike Garrett is online now
post #3 of 7 Old 07-01-2013, 07:44 PM
Ascend's Avatar
Quoted: 120 Post(s)
Liked: 289
Originally Posted by newc33 View Post
What's the Max output in dbs on my cmt 340se? Is the only way to have an split meter? My room is 16x22 if I remember right. All closed except one 8 foot opening. Thanks
We have run a pair cleanly (crossed at 80Hz) at 112dB peaks measured at ~11 feet distance in our heavily damped listening room. Add at least another 3dB to that number for a typical lightly treated listening room.
newc33 likes this.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #4 of 7 Old 07-01-2013, 09:24 PM - Thread Starter
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1233
Wow that'd pretty good! I really need to get an split meter. IV never turned my Avr past -10 as that was plenty loud but not 112dbs loud I don't think. Sounds like it would be closer to 0 on the Avr:eek:
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #5 of 7 Old 07-01-2013, 09:25 PM - Thread Starter
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1233
And how exactly do I determine what "reference" level is?
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #6 of 7 Old 07-02-2013, 07:39 AM
flickhtguru's Avatar
Liked: 111
Without having an SPL meter. Run your receiver's auto room correction (Audyssey, YPAO, MCACC) If you leave all levels set where that software puts them then 0db on your master volume control is reference level. That's why its 0 and anything lower has a - number because you are below reference. However I use Audyssey then use an SPL meter to get 75db from each speaker to my MLP. For what ever reason there is quite a big difference in how Audyssey sets it and the SPL meter ( I think its like 3 or 4 db difference).
newc33 likes this.
Shawn
flickhtguru is offline
post #7 of 7 Old 07-02-2013, 11:48 AM - Thread Starter
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1233
Okay makes sense to me thanks!!
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
Reply Speakers
Ascend Acoustics Cmt 340 Se Center
