Help setting up 5.1 speakers - AVS Forum | Home Theater Discussions And Reviews
Old 07-02-2013, 09:21 AM - Thread Starter
ennogs's Avatar
Would anybody like top help a newbie? I have been using a very crap pair of 2.1 speakers. Today I bought a set of 5.1 speakers with subwoofer and an amp. My soundcard is an Asus Xonar D2X (I am using Windows 8). The speakers and subwoofer are Tannoy TFX 5.1. The amp is a Sony STR-DH520
Subwoofer
Amp
I am really struggling to set it all up.
Speaker wires
Back of speaker
The speaker wires have a white cable and the other is white cable with a black stripe. I assume the black striped speaker cable connects to the black on the back of the speaker and the white speaker cable connects to the red on the back of the speakers. Am I correct?
The problem I have working out is
1) Where to connect the speaker wires to on the amp
2) Do I connect the subwoofer to the AMP or Asus soundcard? Where on the soundcard or amp do I connect the subwoofer?
I was also told I needed these wires but not sure what they connect to
ennogs is offline
Old 07-02-2013, 09:29 AM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
Well each speaker will correspond to the speaker terminals on the back of the receiver. Since you have 5 speakers, you will be using Front L and R, Center, and Surround L and R.
Place your speakers, and connect them accordingly. If you put the black striped wire in the black terminal, make sure to keep that convention for all your speakers.
The sub woofer will connect to the receiver via the RCA cable, there is a sub output on the back of the receiver that is labeled.
You will connect your sound card to the receiver using the S/PDIF output, with the digital audio coaxial cable. Plug this in to the orange digital audio input on the receiver.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
Old 07-02-2013, 09:40 AM - Thread Starter
ennogs's Avatar
Thanks for your reply.
Just to clarify for myself (I did say I was a newbie lol)
Front L and R, center = the 2 front speakers and the center speaker
Surround L and R = the 2 rear speakers.
Am I correct?
ennogs is offline
Old 07-02-2013, 09:44 AM
Liked: 1319
Am I correct?
Yes that is correct.
You can reference this link and use the 5.1 set-up diagram to help with placement.
Old 07-02-2013, 10:01 AM - Thread Starter
ennogs's Avatar
Thanks you so much. Very kind of you.
I have one last question. The wires to the rear speakers are going to be longer than the wires to the front speakers. Does that matter? Should I make all the wires the same length?
ennogs is offline
Old 07-02-2013, 10:24 AM
Liked: 1319
Yes that is expected, try to follow the placement of that diagram I linked and then lay your wire accordingly. Unless you have a huge room, you shouldn't have any issues with cable length.
Old 07-02-2013, 10:30 AM - Thread Starter
ennogs's Avatar
sorry for my newbie confusion. Yes that is expected the wires will be different length or yes it is expected that the wires will be the same length?
ennogs is offline
Old 07-02-2013, 10:42 AM
Bill Fitzmaurice's Avatar
Liked: 4631
It's expected that the wires will each be long enough to reach where they are going, that's all that matters.
Bill Fitzmaurice is offline
Old 07-02-2013, 10:47 AM - Thread Starter
ennogs's Avatar
Thank you.
ennogs is offline
Old 07-04-2013, 05:20 PM - Thread Starter
ennogs's Avatar
Due to work I have only just managed to finish work on this. I am stuck again.
I have set up the 5 speakers and ran the speaker wires to the receiver.
I am now stuck connecting the last 2 cables.
Do I connect the Phono to Phono cable
To the S/PDIF out on the PC soundcard (Asus Xonar D2X)
and to the orange labeled DB/DVD Coaxial in on the back of the receiver
ennogs is offline
Old 07-04-2013, 05:26 PM - Thread Starter
ennogs's Avatar
If I have got the phono to phono cable right. How do I connect the subwoofer?
The last cable I have left is a very short digital optical cable
Receiver
Subwoofer
ennogs is offline
Old 07-04-2013, 08:13 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Do I connect the [RCA-to-RCA] cable ... To the S/PDIF out on the PC soundcard ... and to the orange labeled DB/DVD Coaxial in on the back of the receiver
Yes.
How do I connect the subwoofer? The last cable I have left is a very short digital optical cable
Run an RCA-to-RCA cable:
- from the SUBWOOFER output on your AVR,
- to the LEFT input on the sub (as indicated on the back of the sub).
eljaycanuck is offline
Old 07-04-2013, 10:46 PM - Thread Starter
ennogs's Avatar
Originally Posted by eljaycanuck View Post
Yes.
Thanks. I will have to take the digital cable back and get another RCA cable.
ennogs is offline
Old 07-05-2013, 03:16 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
You don't need to do that. People here often buy digital coaxial cables from Monoprice to connect their subs. It should work fine. Just plug it up and see smile.gif
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 07-05-2013, 04:16 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
I think the OP's cable is an optical cable. No good for sub.
crn3371 is offline
Old 07-05-2013, 04:28 PM
cel4145's Avatar
Liked: 2987
You are right. Never mind. Bad eyesight looking at pics on a phone. redface.gif
Old 07-07-2013, 12:35 PM - Thread Starter
ennogs's Avatar
Thanks for all the help so far. Due to work I have only just got the chance to finish this off.
I have now connected all the wires where they should be in the AVR, Sub and sound card on the PC. I have done the auto calibration test. I could hear all 5 speakers and the sub. I then took the microphone out out of the auto calibration socket.
I am not getting any sound when using the PC? I am on Windows 8. I have tried a you tube video and a video through VLC player. I have checked the volume on the AVR and in windows. I think I have selected the right sound option in Windows. When go into windows sound options I do see the green level for the sound going up and down.
Anybody any idea as to what I am doing wrong?
ennogs is offline
Old 07-07-2013, 12:49 PM - Thread Starter
ennogs's Avatar
When I do the auto calibration test should I be speaking something in the microphone?
ennogs is offline
Old 07-07-2013, 01:06 PM - Thread Starter
ennogs's Avatar
When I am doing the speaker set up on the AVR do I choose surround sound?
ennogs is offline
Old 07-07-2013, 01:12 PM - Thread Starter
ennogs's Avatar
Sorry another question. Where should the microphone be positioned when doing the auto calibration test?
ennogs is offline
Old 07-07-2013, 02:20 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
The mic should be at your main listening position, at ear level. It helps if you have a tripod.
crn3371 is offline
Old 07-07-2013, 05:56 PM - Thread Starter
ennogs's Avatar
Thank you
ennogs is offline
Old 07-07-2013, 05:58 PM - Thread Starter
ennogs's Avatar
Anybody any idea why I am not getting sound when using windows?
ennogs is offline
Old 07-08-2013, 06:19 AM - Thread Starter
ennogs's Avatar
Bump. Still not getting any sound from windows.
ennogs is offline
Old 07-08-2013, 07:31 AM
Liked: 1319
You have the right input selected on the AVR right? Look and see what the digital coaxial audio input on the back is labeled as and make sure to select that source on the receiver, probably "Audio 1" or something along those lines.
Other than that it is probably a setting in the properties for your sound card, or if the XONAR has propietary software. I would hunt around and see what you can change.
Old 07-08-2013, 01:03 PM - Thread Starter
ennogs's Avatar
Thanks for you reply.
I think i have the connections right?
I did not realise you have to select the audio on the avr I will have a look at how to do that.
ennogs is offline
Old 07-08-2013, 01:23 PM
Liked: 1319
Yeah everything looks like it is plugged in correctly, if you didn't select the right source on the AVR then I am 99% sure that is the problem biggrin.gif
Old 07-08-2013, 01:25 PM - Thread Starter
ennogs's Avatar
I have gone through every menu option on the AVR and still getting no sound
ennogs is offline
Old 07-08-2013, 01:31 PM
Liked: 1319
Just try turning on the radio of the AVR and seeing if you get sound. If we can localize the problem it will be easier to diagnose. If the AVR and speakers all work, then we can narrow it down to the cables/soundcard/computer.
From your picture the XONAR was set as the default device, I would look in the properties and see what everything is set at. If your motherboard has an optical or coaxial output, try that instead. See if you can get sound without the XONAR.
Old 07-08-2013, 02:06 PM - Thread Starter
ennogs's Avatar
This is what options i have on the AVR
Using the input selector control I have chosen BD/DVD
With the the input mode button I have choice between auto and coax. I have chosen coax.
ennogs is offline
