New Home with Pre-Wired Bose Cube Speakers...options? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 07-02-2013, 09:43 PM - Thread Starter
roadwarrior980's Avatar
I know Bose is a sore subject around here and I can do a search and read all of the negative feedback people have or condescending comments, I would appreciate only those with relevant comments to make. I am hoping there are a few out there who can weigh in so I have an idea of which direction to go. smile.gif If there are no options and what I am looking for doesn't work or I have the wrong idea in mind (again, save me the 'Bose' drama), then let me know.
I just moved into a new home after getting back from Afghanistan (third deployment smile.gif ) that has Bose Cube speakers already installed. Three up front and two in the back. The back two look like they were previously set up via a wireless receiver (probably the SL2) and the remaining RCA cables for the Bose speakers are intact. No other equipment was left behind, just the speakers already mounted to the walls / ceiling
I'm not sure what kind of setup they were running, whether it was a T20, V25, or an Acoustimass of some sort.
I like how they are setup and would like to make use of them instead of attempting to remove them since the wires are already in the walls. I had previously heard them when I first checked the place out and they sounded good. I wasnt aware of the full setup they were running at the time.
My question is what should I look for if I'm going to make use of them? Right now I can pick up a full V25 setup for $1800, although I dont need the speakers. I'm sure I can locate an Acoustimass somewhere cheaper than whats offered, and I can also get a SL2 wireless receiver for the back speakers for $200.
If I go with the Acoustimass option, will i be able to hook my current receiver (Pioneer VSX-21) up to it and make use of the high def audio (DTS-MA, etc)? I know that most Bose systems takes these signals and downgrades them to DTS 'Core' and in essence dont support true HD audio and I would rather not have to lose quality if I can help it.
Also, would I be able to run the Acoustimass with the SL2 wireless receiver or does it have to be paired with a certain Bose system?
I appreciate any thoughts or suggestions. I am not looking for top of the line sound or suggestions that I buy a new receiver, no by Bose, or rethink everything I'm doing. I'm looking for make the most of what I have and make that work
"To sin by silence when we should protest makes cowards out of men."
Operation Iraqi Freedom Campaign Veteran, 06-08.
Operation Iraqi Freedom Campaign Veteran, 09-10.
Operation Enduring Freedom Campaign Veteran, 12-13.
roadwarrior980 is offline
post #2 of 13 Old 07-02-2013, 10:41 PM
Yosh70's Avatar
Quoted: 172 Post(s)
Liked: 126
Since Bose users are few and far between here on this forum, why don't you contact Bose thru their website?
Or even try here http://bose.infopop.cc/eve/forums/a/frm/f/76010377 and post your question.
Help is a minute away using Google.
Yosh70 is offline
post #3 of 13 Old 07-03-2013, 06:44 AM
Bill Fitzmaurice's Avatar
Liked: 4637
Toss the cubes, install good speakers, use your AVR, utilizing the wire that's there. Wireless options for rear speakers abound.
Bill Fitzmaurice is online now
post #4 of 13 Old 07-03-2013, 08:16 AM - Thread Starter
Am I still able to make use of the existing wires for the setup?
The previous Bose system used RCA type cable to connect to it's receiver. The cables then hooked up to the speaker but not sure if these are wires strictly for the Bose or not.
Would a HT tech be able to do an install or alteration to what I already have here? Would it require removing the current wires or can I still make use of those?
post #5 of 13 Old 07-03-2013, 08:19 AM
Liked: 4637
So long as they're sufficient gauge, yes, just cut the RCA ends off. If not sufficient gauge, get new wire. I wouldn't buy an over-priced under-performing system just to save twenty bucks on new wire.
post #6 of 13 Old 07-03-2013, 08:45 AM
Mike Garrett's Avatar
Quoted: 5575 Post(s)
Liked: 3553
I agree with Bill, unless the wire is in-wall, I would not think twice about scrapping it.
mjgarrett100@gmail.com
Mike Garrett is online now
post #7 of 13 Old 07-03-2013, 09:06 AM - Thread Starter
Yea, I believe they are whatever RCAs the system came with. So clipping the RCA input at the end and I can use t as is? How can I tell if they're sufficient gauge before i cut? (Sorry, not too familiar with wires lol)
post #8 of 13 Old 07-03-2013, 09:08 AM - Thread Starter
Also, I can provide a few pictures of what I have here if that will help
post #9 of 13 Old 07-03-2013, 09:48 AM
Liked: 4637
Most wire has the gauge embossed or printed on the jacket anyway, but if not, cut away to find out. I'd say that if they were good enough to work with the Bose cubes they should be OK with anything, but knowing how Bose cuts corners at every opportunity they might be under gauge.
post #10 of 13 Old 07-03-2013, 11:32 AM - Thread Starter
This is what I saw written on the RCA (pics attached also). Not sure if this helps or if its telling me the right info, but any thoughts would be great:
AWM 2468 80oC VW-1 18AWGX4C UNIELEC SZ (the 80oC would read as 80 degrees)
photo 1.JPG 2396k .JPG file
photo 2.JPG 2876k .JPG file
photo 3.JPG 1964k .JPG file
ID:	70492   Click image for larger version
ID:	70493   Click image for larger version
post #11 of 13 Old 07-03-2013, 12:20 PM
Liked: 4637
That makes it 18 ga. This will tell you what 18 ga will work for depending on the wire length, speaker impedance and power:
http://www.bcae1.com/images/swfs/speakerwireselectorassistant.swf
post #12 of 13 Old 07-03-2013, 03:31 PM - Thread Starter
Cool, thanks.
Having trouble opening the link..is there another way to get it?
post #13 of 13 Old 07-03-2013, 08:47 PM
Liked: 4637
Cool, thanks.
I just opened it, works a treat. The issue must be on your end.
Reply Speakers
