2.1 or 3.1 start up - $2500ish budget - AVS Forum | Home Theater Discussions And Reviews
Old 07-03-2013, 07:28 AM - Thread Starter
jtheby05's Avatar
I've been reading many other threads which have similar budgets to mine for speaker+sub purchasing and have an idea of what I might do. So here's the scoop.
I'm looking to setup either 2.1 or 3.1 for now with the thought of adding in rears for a 5.1 setup.
I will use this mainly for movies and gaming (ps3 and ps4 when it comes out). Music is taken care of at my PC with headphones/studio monitors.
I have a Pioneer sc-1222-k on the way since it's on sale from Newegg. And now I'm picking out some speakers and a sub.
It looks like HSU packages would be a good fit but I'm also very interested in a KEF Q300/600/100 setup.
Currently planning:
KEF Q300 pair - $500 @ acc4less
KEF Q600c - $450 @ acc4less
HSU VTF-15h - $879
Then add in KEF Q100 pair for rears when my wallet recovers from the initial shock smile.gif
Also - any suggestions for stands for the Q300?
Just figured I'd toss the idea out there. Would these speakers and sub with the pioneer sc-1222 be a good fit?
Or do I go for a better setup over time by starting with 2.1 with:
KEF Q900 $1300 pair @ acc4less
HSU vtf15h $879
Then add in a center channel....then rears eventually. Or would the sub kind of defeat the purpose of going to the q900?
Any input is apprciated!
jtheby05 is offline
Old 07-03-2013, 07:40 AM
Nethawk's Avatar
Liked: 118
The Kef Q300 are fine speakers. I had them for about 2 months in a stereo setup but sadly my room was too big for them. Excellent clarity and accuracy, and both wide and deep soundstage, there was nothing they didn't do right (except fill a big room on their own). I think they would be a great choice for theater.
All subjective of course.
Nethawk is offline
Old 07-03-2013, 07:45 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 176
I would not recommend those Kefs if your primary purposes are theater. If you have the ability to build some enclosures then I would highly recommend building some of the Seos speakers. They also come in a kit version that you can assemble with only a little glue and time.
Otherwise if you don't want to mess with that, I would look into buying 5 of the used, older, Klispch Hersey's. These would most definitely best the Kefs for mcvies, plus they can be had for less than $400 per pair all day long! That would leave the budge some room for duel subs, which will make a great difference in the overall movie experience.
Martycool007 is offline
Old 07-03-2013, 07:46 AM
AcuDefTechGuy's Avatar
Quoted: 175 Post(s)
Liked: 262
I would get five NHT Absolute Zero (AZ) plus the HSU (or get 3 AZ for now, then add 2 more AZ later).
The HTM-measured the listening window response of the AZ is +/- 0.9dB, which is just exquisite.
AcuDefTechGuy is offline
Old 07-03-2013, 08:13 AM
cel4145's Avatar
Quoted: 2660 Post(s)
Liked: 2991
Agreed.
Start with the Q300s. If you decide you need more, you could always then save up for the Q900s and move the Q300s to surround duty.
It's not like the Q300s would be a waste as surrounds over the Q100s. The bigger drivers would give you a little bit richer midbass out of the surrounds.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Old 07-03-2013, 08:19 AM - Thread Starter
jtheby05's Avatar
Not a bad idea with starting with q300 then move em to rear duty.
Where would you reccommend finding the Hersheys from by chance?
The AZ setup would be a good value. $1000 for 5 and then 880 for the HSU sub.
At the $890 pricepoint - would there be any better suggestions for a sub? I do like the idea of the HSU one being a hybrid. Seems like that could come in handy.
I guess I should mention this is going in the basement which....is a relatively big space. It won't always be in this space though. I can get some dimensions when I'm home. It's kinda one entire side of the basement but I would be keeping it in a square corner space within the room itself.
jtheby05 is offline
Old 07-03-2013, 08:36 AM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
One thing you might want to consider is getting 5 of these highly regarded RHX Black Mini speakers which got a great review from Audiophile Quarterly and then tacking just a wee bit more on your budget for one of these Danley Sound Lab TH812 subwoofers, which should integrate well with the speakers due to it's rich upper mid bass articulation. The system as a whole will bring you a deep, nearly holographic sound stage with sparkling highs which nothing else can touch in its price range. Personally I wouldn't have anything less.
shadyJ is offline
Old 07-03-2013, 08:41 AM
Mike Garrett's Avatar
Quoted: 5613 Post(s)
Liked: 3594
I'm looking to setup either 3.1 for now or 5.1. I'm fine with doing 3.1 then adding in rears later.
Currently planning:
HSU VTF-15h - $879
HSU vtf15h $879
What will the listening distance be and do you like to turn it up or listen at lower levels?
What is your room like?
Need these questions answered to give you a recommendation that works for you.
mjgarrett100@gmail.com
Mike Garrett is offline
Old 07-03-2013, 08:42 AM - Thread Starter
jtheby05's Avatar
I think I'd make a halo to hang 10 of those off of. Now that's surround sound.
jtheby05 is offline
Old 07-03-2013, 08:59 AM - Thread Starter
jtheby05's Avatar
Distance wise probably around 10-12ft from my tv.
It's a finished basement with carpet. The space itself is almost like a sideways J or U without a bit of one side. I'll have to sketch it up to make it more clear.
Id have my setup in one corner and basically section off a square area for this stuff.
jtheby05 is offline
Old 07-03-2013, 09:31 AM
cel4145's Avatar
Liked: 2991
I think that's more useful for marketing than actually a great feature. Most sub drivers I have seen have different enclosure sizes when optimized for sealed vs. ported. I suspect that the HSU subs are optimized for ported use.
That sub is over $1000 shipped. If you want a good high output sealed sub, for a little more, you could go with the Power Sound Audio XS30.
Old 07-03-2013, 10:26 AM - Thread Starter
jtheby05's Avatar
Lol I totally forgot about shipping. So used to it being free everywhere. Yeah going to the PSA XS30 for a tiny cost increase looks to be good choice. Thanks for pointing that out smile.gif
jtheby05 is offline
Old 07-03-2013, 12:00 PM
Nethawk's Avatar
Liked: 118
Originally Posted by Martycool007 View Post
I would not recommend those Kefs if your primary purposes are theater..
This is the first such feedback I've heard. Why not?
Nethawk is offline
Old 07-03-2013, 02:06 PM
Quoted: 175 Post(s)
Liked: 262
KEF rates the Q300 @ 110dB SPL.
I think they will be great for movies unless the person sits 30 ft away. biggrin.gif
Old 07-03-2013, 05:29 PM - Thread Starter
jtheby05's Avatar
Yeah I don't think I'll be in a room that size anytime soon hah.
The section that will be cornered off so to speak is probably around 14'x12' but can be changed up however I want really. I may rotate it around and be able to make it more of a rectangle which may end up working out better.
So right now I'm considering the PSA XS30 for $1150 shipped or possibly the PSA XS15 for $750 (or $800 w/ base).
Gonna have to look up some stores and have a listen this weekend.
jtheby05 is offline
