Time to VOTE!! HSU vs Ascend vs Arx - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 5Likes
post #151 of 174 Old 11-11-2013, 03:33 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Originally Posted by Bill Fitzmaurice View Post
Dome tweeters are essentially cone drivers, and a rear chamber is to a dome tweeter as a sealed enclosure is to a midrange, woofer or sub driver. Just as with larger drivers the overall response of the tweeter can be tailored by the size of the rear chamber. A larger rear chamber doesn't damp the backwave, that must be accomplished by lining the chamber with damping material. The larger the chamber, the lower the frequency that must be damped. That's because destructive reflections occur when the distance from the dome to the rear of the chamber approaches 1/4 wavelength, so the larger the chamber the more issues there are with destructive reflections, not less. Conversely, the smaller the chamber, the shorter the return path, and the less the need for damping, so the damping can be made thinner, or even eliminated. The smallest rear chambers are found in horn drivers, which usually are machined to the shape of the dome, and the depth of the chamber behind the dome is on the order of only a millimeter or two. Doing so eliminates any internal reflection issues, as 2mm is 1/4 wavelength at about 50kHz. Making the chamber that small does lessen response in the low end of the passband, but with a horn that's down to compensate for the low pass function of the horn. .
"a damping chamber" Does that sound off to you? It is clear to me Dave was refering a damped chamber not a large chamber will damp.
RicardoJoa is offline
post #152 of 174 Old 05-02-2014, 03:48 AM
Satyaa's Avatar
Nexus221, are you still around the forum? What is your experience with the speakers you ordered?
This interesting thread suddenly went cold!
Satyaa is offline
post #153 of 174 Old 07-07-2014, 12:30 AM
Raskolnik's Avatar
Liked: 0
I would also like to second the request for more information/a resolution. The choice facing me seems to be between the Ascend CMT-340 and the HR HB-1 MK2, so I'm very interested in what anyone might add to this discussion.
Raskolnik is offline
post #154 of 174 Old 07-07-2014, 06:27 AM
Transmaniacon's Avatar
Quoted: 1586 Post(s)
Liked: 1394
This is a very tough decision. The Ascend probably gives you a more dynamic sound stage with the MTM speakers, but the HSU's are horn-loaded and also offer great dynamics. The Ascend are going to be louder, so if you sit farther than 10-12' I would take them. The VTF3-MK4 is a better sub than the Rythmik though.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #155 of 174 Old 02-01-2015, 09:18 PM
ArchonX's Avatar
Quoted: 327 Post(s)
Liked: 181
I owned the Ascend speakers, I unfortunately had to sell them due to circumstances, but I will give you my take on them.
CBM-170SE: They are BIG bookshelf speakers, most seem wimpy by comparison. They sound thin and lackluster when you first listen to them, especially if coming from dynamic speakers. They need to be broken in and have your ears adjust to them. I would say they are much better for movies, paired with a Denon 2112 receiver, a Pioneer SC1222, and finally a Sony STR-DN1040 receiver. They are very clinical, meaning if you play a low quality MP3 song through them, they won't sound like you are playing a decent MP3. liked them but I would say they are better for surrounds.
CBM-340SE: Much bigger and better sounding speaker, better for music than the CBM-170SE but still not as dynamic as some brands of speakers. They image excellent and have a full sound, much fuller than the Ascend 170SE. A sound quality more rich than the smaller bookshelf and of course they dig deeper, so more room filling. The sound qualities are about the same, revealing of source material and uncolored sound.
They have very good imaging, once broken in they can sound very good. Very well balanced and dynamic and if you play high quality material through them, you will be rewarded with great sound.
For music listening, I do not think the CBM-170SE across the front sound stage would be ideal, they are better for movies. They lack the richness and dynamics, but I think with certain types of music they would sound great. I would say if you want to use for all around sound, the CBM-340SE would be the way to go for all three front speakers. Not that the CBM-170SE is a bad speaker, but it is designed as a surround speaker to compliment the CBM-340SE. You CAN use CBM-170SE as mains and for every speaker, but you may or may not like the overall sound. Now the CBM-340SE is a different story but it is heavy and huge, so hanging on walls would not be easy to do. They are also all rear ported, so they need room to breath. You need stands or arms to mount any Ascend speakers.
I hope this helps, they are good speakers but I think you can do better for an even cheaper price and get a better Sub. I would say Ascend and HSU for 50% or more movie watching, Chane Arx for music 50% or more. I have not heard the HSU or Arx, admittedly. But I do know how they are designed and they both will have a bigger sound stage than the Ascends.
charmerci likes this.
ArchonX is offline
post #156 of 174 Old 02-02-2015, 08:04 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
Just a minor correction. Our CBM-170's were certainly not designed as surround speakers to complement our 340's. We built the company with our 170's sold as mains, 340's didn't come around for many years later. In fact, the 340 center came before 340 mains and was developed by popular request as a "dedicated center" to be used with the 170's as left/right. We then later introduced the left/right version of the 340.
David Fabrikant
audio professional and soft spoken representative of www.AscendAcoustics.com
Ascend is offline
post #157 of 174 Old 02-04-2015, 05:48 PM
ArchonX's Avatar
Quoted: 327 Post(s)
Liked: 181
Hi there David, I do stand corrected. I do really like your products and I push them in most situations.
I liked the sound of both CBM-170SE and CBM340SE. I actually had 4 CBM-170's as my mains and surrounds and the CBM-340 as my center. Of course by comparison the CBM-340 was much richer and just a better all around speaker but I loved all of my Ascend speakers. Unfortunately I had to sell them off, but I just purchased 5 of the Wave Crest Audio HVL-1 for my room system, I am excited to hear them and I think I will like what I hear.
I like to review speakers critically, but I can say the CBM-170SE is more than adequate for mains, just not as ideal as the CBM-340 due to the fact it will have an obviously bigger (more room filling) and richer sound. I do love the imaging on the CBM-170 and they dig deeper than some towers I have heard and/or owned.
ArchonX is offline
post #158 of 174 Old 02-11-2015, 07:24 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
No worries Archon. I just wanted to make sure that there was no confusion regarding our 170's -- as they were fully designed to be main speakers and the majority of their sales are for this purpose.
David Fabrikant
Ascend is offline
post #159 of 174 Old 02-11-2015, 09:38 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
IIRC, that was back in the day when although people liked the speakers so much, the finish was uninspiring. So people were stripping the speakers and dressing them up with veneers and all. Is that sort of right, Dave?
On other notes, does Ascend see itself into developing a line of high efficiency speakers?
"I've found that when you want to know the truth about someone that someone is probably the last person you should ask." - Gregory House
Chu Gai is offline
post #160 of 174 Old 02-12-2015, 07:01 AM
Billy p's Avatar
Quoted: 302 Post(s)
Liked: 665
I asked that question recently over at the AA forum & the response was no. Dave could elaborate & explain things further on the vary subject of HE monitors or the uninspiring finish found with the lower models.
If you ask me though...Ascend seems to be doing prudy good at the moment with what's at hand but you just never know. I'd be more intrigued if the were to develop a new mid range driver for the Towers like they did for the new S2.
Ascend Acoustics Towers: STC w RAAL, 200 SE in espresso,
54" of Panny Bliss, Anthem MRX 300, Oppo BDP-103D,
Apple TV+ Giga 1800
Sub FA 18: (Santos RW)
Indian proverb: We don't inherit the earth from our ancestors but we borrow it from our children!
Billy p is offline
post #161 of 174 Old 02-12-2015, 08:27 AM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
I didn't mean it as a slight on the speakers, rather that when they were first introduced people liked them so much they were willing to spend time and money to jazz them up.
On the HE monitors, I just see it as the wheel coming around with those types coming into relative popularity. The wheel never stops turning though.
Chu Gai is offline
post #162 of 174 Old 02-12-2015, 05:47 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
Hey Chu -- memories of the old days It was mostly our dear old friend MLS, who, having nothing to compare sound quality wise with the 170's, started all that "uninspiring finish" matter. Our 170's still sell as well now as they did back then. It is really a remarkable story for a speaker, a true testament of how a well engineered product stands the test of time.
We introduced them exactly 15 years ago this very month. And in all this time, we have had only one revision to the speaker. I am quite confident that our CBM-170's are the top selling "ID" loudspeaker ever offered, and by no small margin.
As far as the "uninspiring finish" -- seems like our philosophy of a basic black box has caught on quite a bit
Hope you are well!
David Fabrikant
Ascend is offline
post #163 of 174 Old 02-12-2015, 08:05 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Fifteen years. Wow. I'll bet theyre almost fully broken in by now. That's staying power. Wasn't it Howard Ferstler who gave it a knock it out of the park review back then?
Chu Gai is offline
post #164 of 174 Old 02-12-2015, 08:31 PM
postrokfan's Avatar
Quoted: 612 Post(s)
Liked: 3723
Interesting synopsis. I've read this sort of opinion a number of times. I think it's perhaps a typical review coming from a listener who has not experienced a truly neutral speaker with a flat response. When I had a pair of the CBM-170SEs I kind of felt this way at first as well (being new to quality speakers) but realized shortly after that this was due to previous speakers I had owned "over-accentuating" in certain areas.
Eastern Shore Audio Collective-E.S.A.C. Member, www.esac.club
postrokfan is online now
post #165 of 174 Old 02-12-2015, 09:20 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
I know, right? 15 years - hard to believe. And to think, when I designed the 170's -- I had no kids and a lot more hair on my head, I don't think there even was an AVS forum yet.
Yep, it was Howard who first reviewed them and gave them a glowing a review. He loved the 170's -- bought a few pairs for himself and friends as I recall.
David Fabrikant
Ascend is offline
post #166 of 174 Old 02-12-2015, 09:30 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
Maybe a reprinting of reviews over the years as part of a 15 year anniversary celebration?
Chu Gai is offline
post #167 of 174 Old 02-12-2015, 10:06 PM
Ascend's Avatar
Quoted: 123 Post(s)
Liked: 298
We should probably do something. 15 years is worthy of recognition.
David Fabrikant
Ascend is offline
post #168 of 174 Old 02-13-2015, 08:58 AM
TornadoTJ's Avatar
Quoted: 1723 Post(s)
Liked: 539
I am glad this thread got revived. I am looking for new speakers, and it seems there are some great options in this low price range. I expected a need to spend much more, but I'm starting to see that it might not be required to do so.
If someone has had experience with the speakers discussed here, along with some of the other options in this price range, I'd love to hear opinions. I'll be pairing these with an Outlaw LFM-1EX, so anything under 80hz is irrelevant.
TornadoTJ is offline
post #169 of 174 Old 02-13-2015, 11:53 AM
bgtighe23's Avatar
Quoted: 1660 Post(s)
Liked: 971
So uh.. .. what's the tally?
_____ _____ _____ _____ _____ _____ _____ _____
Receiver : Denon x5200
Front Stage : Martin Logan Motion 60XTs/Elac Debut F5 Center
Surround Speakers : HTD Level 2 and 3 Towers
Subwooferage : Dual UM-18s/6 SI HT18s
Born in 1995 and still continuing my HT journey
bgtighe23 is online now
post #170 of 174 Old 02-13-2015, 04:13 PM
muzz's Avatar
Quoted: 756 Post(s)
Liked: 507
The AA Towers have a dedicated Midrange driver, there really is no need to develop a new driver for it.
Why waste $ on more cheap stuff, it's like challenging a dragon with a pocket knife.
muzz is offline
post #171 of 174 Old 02-13-2015, 04:35 PM
bgtighe23's Avatar
Liked: 971
15 years, 15% off!
post #172 of 174 Old 02-13-2015, 04:45 PM
Chu Gai's Avatar
Quoted: 584 Post(s)
Liked: 817
If the speakers have serial numbers, then you could have a contest for the oldest pair.
Chu Gai is offline
post #173 of 174 Old 02-13-2015, 04:50 PM
muzz's Avatar
Quoted: 756 Post(s)
Liked: 507
They all have SN AFAIK.
muzz is offline
post #174 of 174 Old 02-13-2015, 07:51 PM
LitoGeorge's Avatar
Quoted: 53 Post(s)
Liked: 56
I have the 340SE LCR and the HTM200's surround. HSU VTF3 MK4, Emotiva XPA5, Onkyo 818.
Fabulous combination - the bass makes all three floors of my house rattle. Makes for a VERY fun movie experience. (also wakes up my toddlers when I get a little happy with the volume button)
I learned that when you start these speakers up as a noob, that you should pour 90% of your time into learning how the room affects your sound. How treatments, furniture placement, speaker placement can radically change the sound. Its kind of amazing really, blows a newcomers mind.
Learn how to use EQ, and learn how to set up your stuff using audio "helpers" like Audyssey and the more importantly things like REW (there are more). This forum is an absolute treasure trove of brilliant information, I consider myself more of a noob now than ever after learning some of the stuff that most experts here have forgotten already.
Enjoy your speakers. They are a great match and Dave Fabrikant from Ascend Acoustics is a personable, knowledgeable, very helpful guy. Who knows his stuff
(no affiliation to him either whatsoever, just my personal experiences)
edit: Other side of the coin: having had this system (I've sold it all just recently), I have to admit wanting speakers having a larger soundstage and more power. So its been a brilliant starter package for me, with a firm eye on the upgraditis path. If you have no desire to listen to super loud stuff (ref+) then this is a great package with exceptional potential as you learn how to work with their capabilities.
LitoGeorge is offline
Reply Speakers
Hsu Research Hb1 Mk2 , Hsu Research Hc 1 Mk2 , Hsu Vtf3 Mk4 , Ascend Acoustics Cmt 340 Se Center , Ascend Acoustics Cbm 170 Se
