Suggestions for LCR + Subwoofer please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-07-2013, 01:02 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Looking for a left, center and right speaker plus subwoofer for a 5.1 system (the rears are in-ceiling speakers). I don't need audiophile level stuff but want it to sound good. The TV console I'm using looks like this, and the speakers will go in the openings on the left, center, and right (with the AV stuff in the lower openings between the cabinet doors). Receiver will be a Denon but haven't decided which one.
Is using something like this pretty decent? http://www.amazon.com/Polk-Audio-5-Channel-Theater-System/dp/B000ZKNW82/ref=sr_1_20?s=electronics&ie=UTF8&qid=1373217840&sr=1-20&keywords=polk+audio+speaker
I'd be using 3 of the 5 speakers obviously.
Also for a subwoofer, something like this? http://www.amazon.com/Yamaha-YST-SW216BL-Subwoofer/dp/B000FJ89UO/ref=sr_1_1?s=aht&ie=UTF8&qid=1373217925&sr=1-1&keywords=polk+sealed+subwoofer
HX_Guy is offline
post #2 of 15 Old 07-08-2013, 12:07 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
HX_Guy is offline
post #3 of 15 Old 07-08-2013, 12:17 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
How tall are those openings where you want to place your l, c, and r, speakers? These might fit horizontally.
http://www.nhthifi.com/Home-Theater-Absolute-On-Wall-Speaker-Black?sc=12&category=7166
Afro GT
afrogt is online now
post #4 of 15 Old 07-08-2013, 12:34 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
The openings are just slightly over 6.25" tall but those speakers seem a bit more pricey than I had planned on spending.
Also, the center opening can only accomodate a 6" deep speaker as there is a divider in there, unless I place the center speaker off-center but I would rather not. Would like something wide so it looks like in the picture above.
HX_Guy is offline
post #5 of 15 Old 07-08-2013, 01:00 AM
afrogt's Avatar
Liked: 755
Since you didn't give a budget we have no idea how much you're willing to spend.....
how bout 3 of these?
http://www.amazon.com/Energy-Veritas-V-Mini-C-Channel-Speaker/dp/B0091VODHU/ref=pd_bxgy_e_img_y?t=slickdeals&tag=slickdeals&ascsubtag=Jt6ftuecEeKlah40xRvYTAjSJ1_M.qb3_0_0_0
since the center opening is much wider than the other two openings are you trying to get 3 of the same exact speaker?
Afro GT
post #6 of 15 Old 07-08-2013, 01:03 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
HX_Guy is offline
post #7 of 15 Old 07-08-2013, 01:07 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
Sorry didn't see your reply before I asked about the Klipsch speakers.
Forgot to post the budget, that would have helped of course. I was thinking no more than around $300 - $400 total for all three speakers, so the ones you posted would work price wise. Are they good? Never heard of that brand. Also it's ok to use a center channel for left and right fronts as well? Would need them in black as well, have to see if they come in other colors.
HX_Guy is offline
post #8 of 15 Old 07-08-2013, 03:12 AM
BarnacleBill's Avatar
Liked: 39
Would you consider putting the L and R speakers on top of the cabinet instead of inside it? That would give you more options and may sound better. Many speakers don't sound as well inside closed cabinets. Also, the 6.3" height is very small. It's difficult to find speakers that small that don't require a sub.
A couple more questions. Is the back of the cabinet enclosed? What is the size of the L and R speaker openings, including depth?
BarnacleBill is offline
post #9 of 15 Old 07-08-2013, 03:52 AM
ifor's Avatar
Quoted: 60 Post(s)
Liked: 72
Why not wall mount the tv and then you have the top of the cabinet to place the center speaker? The center channel height will be an issue when you are an a budget.
Look at the Pioneer floorstanding speakers and center channel for your setup. You could place the speakers to the sides of the cabinet and the center on top of it.
http://www.pioneerelectronics.com/PUSA/Home/Speakers/Home+Theater+Speakers
The Klipsch sub from Newegg is a good deal and would get my recommendation.
ifor is offline
post #10 of 15 Old 07-08-2013, 07:49 AM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
Agreed. You should get much better sound with the L/R on top of the entertainment center.
For a sub, look into the Dayton SUB1200. Considered by many on the AVS subwoofer forum to be one of the best values for its price.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
post #11 of 15 Old 07-08-2013, 09:08 AM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
The speakers have to go inside the openings but they will be flush with the cabinet so it shouldn't affect the sound. The TV is already wall mounted and has some objects on top of the cabinet and to the sides so I have to find something that fits inside the openings.
HX_Guy is offline
post #12 of 15 Old 07-08-2013, 10:57 AM
afrogt's Avatar
Liked: 755
Yes you can use the same speaker as a left, center and right. Since you have size limitations those would be good for your setup.
If the speakers will be placed inside the cabinet why does color really matter? The grille's are black and that is all anyone will see. The rosenut color of those speakers is actually very, very nice.
Better pricing on the V mini speakers.
http://www.ebay.com/itm/Energy-Veritas-V-Mini-C-2-Way-Center-Channel-Speaker-Each-Rosenut-/350598928832?pt=Speakers_Subwoofers&hash=item51a15319c0
Energy is a Canadian speaker company than has been around for 40 years. Klipsch owns them now. Very popular speaker brand on AVS Forums.
Afro GT
post #13 of 15 Old 07-08-2013, 11:03 AM
afrogt's Avatar
Liked: 755
How is this for a center channel: http://www.amazon.com/Klipsch-Synergy-C-10-Premium-Center-Channel/dp/B003XRD9UU
And two of these for the front left and right speakers: http://www.amazon.com/Klipsch-Synergy-S-10-Surround-Speakers/dp/B003XRD9VE
You'd be better off using 3 C-10's instead of adding the s-10 surrounds as fronts. The S-10s are designed to be surround speakers where the sound can reflect off walls. It is not a direct radiating speaker.
Afro GT
post #14 of 15 Old 07-08-2013, 11:13 AM
hdnewbie21's Avatar
Liked: 38
http://www.amazon.com/Pioneer-SP-FS52-LR-Designed-standing-Loudspeaker/dp/B008NCD2S4/ref=sr_1_1?ie=UTF8&qid=1373303663&sr=8-1&keywords=fs52
Agreed, for you budget for 3 speakers, if you can make them fit in your setup, this is probably as good as you can get. Have you thought about getting a riser (or wall mount) for your TV to accommodate a larger center channel?
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
post #15 of 15 Old 07-08-2013, 02:32 PM - Thread Starter
HX_Guy's Avatar
Quoted: 175 Post(s)
Liked: 40
So what's better, the Klipsch C-10s or the Energy Vertias V Mini C? Newegg has the C-10 for $110 right now.
HX_Guy is offline
Reply Speakers
