Home Theater Speakers for the Garage - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-07-2013, 03:02 PM - Thread Starter
starggold's Avatar
My parents have gotten a hand-me-down projector from my sister, and are planning to use it for watching movies in the garage. I'm trying to figure out what kind of speakers we should use for our new home theater.
I think because the walls and ceiling are sheet rock, and floor is cement, the sound from the speakers will reverbiate too much. We don't really have much space for anything that will dampen the sound, so I'm wondering if some speakers will sound better than others and not echo as much? We could possibly put a rug in front of the speakers but that's about all we could do to help it.
starggold is offline
post #2 of 8 Old 07-07-2013, 03:14 PM
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 29
And the million dollar question- what is your budget? You could also get some DIY acoustic treatments for the walls to help absorb some of the reflected sound.
avfanatic1 is offline
post #3 of 8 Old 07-07-2013, 03:28 PM - Thread Starter
starggold's Avatar
Budget is on the cheap side. If there are speakers that will sound clear without needing to put up stuff to absorb the noise, then that is what would work best (not sure my dad wants to make a lot of adjustments to the garage.. that's the reason I am looking for speakers that will not echo too much)... there isn't room on the opposite wall for anything. (there is an air handler there).
With the projector's built in speaker the audio sounds like crap. You can't hear what they are saying on the movies. So we need speakers.
BTW the dimensions of the garage are 24' x 24'
post #4 of 8 Old 07-07-2013, 05:39 PM
smasher50's Avatar
Quoted: 355 Post(s)
Liked: 15755
without a budget its pretty hard to recommend speakers and how many 2? or are you looking for a larger system like 5.1and what will you be powering them with
i'm so laid back,i'm laid out
smasher50 is offline
post #5 of 8 Old 07-07-2013, 05:44 PM
Secret Squirrel's Avatar
Quoted: 44 Post(s)
Liked: 39
There are no magic speakers that will fix a room with acoustic problems. If the room sounds bad any speaker put in the room will sound bad.
Secret Squirrel is offline
post #6 of 8 Old 07-07-2013, 07:40 PM
Bill Fitzmaurice's Avatar
Liked: 4667
Line arrays have very tight vertical dispersion, which gives minimal early reflections off the floors and walls, so they would be far better than point source speakers. You probably would still need to do some wall treatment. Some carpet remnants would do the trick.
Bill Fitzmaurice is online now
post #7 of 8 Old 07-07-2013, 08:17 PM - Thread Starter
starggold's Avatar
I think 2 speakers would be good (I don't know), we don't have a lot of room for surround sound. Not trying to do anything amazing, just enough to have a nice little set up for watching movies.
post #8 of 8 Old 07-08-2013, 12:03 PM
TheWind's Avatar
Liked: 30
I think these would be absolutely perfect! – And, I bet you could pick some up on eBay at a great price.
I
TheWind is offline
Reply Speakers
