$1000 Speakers for dorm room setup only classical music - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2013, 07:32 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
The cabinets on those Serene speakers look just... odd. Those would be a no-go for me. But perhaps that sort of thing doesn't bother you as much as it does me.
Also this:
The Talisman measures 8" high x 5" wide x 6" deep. It is rear ported and uses a 3" full range driver. Power comes from a built in 15 W X 2 high-efficiency Class D amp with extremely low THD.
A 3-inch "full range" driver? biggrin.gif Uh-huh...
Any of the recommendations above will likely run rings around the Serenes. That doesn't mean that the Serenes will sound bad, FWIW, but their competition seems to be Logitech and other lower-end "computer speaker" makers.
skriefal is offline
Old 07-08-2013, 07:40 PM
losservatore's Avatar
Quoted: 2303 Post(s)
Liked: 2047
I found that funny too a 3" speaker that goes down to 70hz. Those spec are not accurate at all. Its just marketing gimmick.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
Old 07-08-2013, 07:50 PM
skriefal's Avatar
Quoted: 85 Post(s)
Liked: 69
That 70-hz @ -3dB is hard to believe from such a tiny speaker. Either they're exaggerating or they're using some sort of digital EQ to compensate for the small cabinet and driver. Neither is good.
skriefal is offline
Old 07-08-2013, 08:46 PM
Quoted: 911 Post(s)
Liked: 489
Originally Posted by losservatore View Post
***For classical music, people tend to choose ribbon tweeters..
A ribbon, with that ultra-wide upper mid/lower treble dispersion, is the exact wrong choice for a small, narrow dormroom. (And people who like "classical" music do not "tend to choose ribbon tweeters" as a rule.)
Probably the best suggestion made so far is the Behringer monitor. Another good option (both considerably better and a little cheaper than the Q300 mentioned) is KEF's Q100. The Q300 goes lower and gets a little louder than the Q100, but has comparatively degraded midrange performance. For an all-in-one package (DAC/amp/speakers) KEF offers the X300 or something like that. But I'd go with Q100's and a small amp. The Griffin Twenty is $99 and not a bad choice (though it won't get super loud). It also doubles as a stand for your MacBook charger, and has a subwoofer crossover built in.
The Pioneer BS22 is also a good choice for a dorm. They sound quite good, and one's only out a small sum if someone pours bong-water on them, or throws up Natty Light all over them, or in the course of an over-excited young hookup an errant leg sends one careening to the floor.
Nethawk likes this.
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
Old 07-08-2013, 10:06 PM
Lance-AR's Avatar
I think we may be over thinking this. I would purchase the Emotiva and be done.
Lance-AR is offline
Old 07-08-2013, 10:47 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3091
Some powered monitors might fit the bill here. The Emotiva and Behringer options would be great (Emotiva Airmotiv 4 or Behringer Truth). For passive speakers I would definitely consider the KEF Q100s and Ascend options (CBM-170SEs) as well as the Cambridge S30s. Many members here aren´t B&W fans but IMHO the 685s sound wonderful with classical music.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
Old 07-09-2013, 03:05 AM
Nethawk's Avatar
Liked: 118
Good point on the Pioneer BS22. The budget-but-good speakers may be the best route since the OP is likely to be victimized for playing classical only in a dorm room biggrin.gif
Nethawk is offline
Old 07-09-2013, 04:46 PM
JerryLove's Avatar
Liked: 79
Originally Posted by slayerming2 View Post
Okay thanks guys for all the advice. So what can i expect the Ascend Sierra-1 to give me that would be different from the Sennheiser hd 600? Once again my knowledge of speakers is very minimal.
I cannot speak specifically to the Ascend: but what you should get (in addition to not having headphones, and most audio isn't mixed for headphones) is better HF response. I've yet to run into a sub $1k set of cans that didn't have problems over 8khz.
JerryLove is offline
Old 07-09-2013, 08:21 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3091
Actually, I´m impressed. At least it´s not dub-step.
Old 07-09-2013, 08:33 PM
Dennis Murphy's Avatar
Quoted: 402 Post(s)
Liked: 583
Originally Posted by svadas View Post
What about one of the Dennis Murphy designed bookshelves that Salk can build?
Thanks for the suggestion, but I think the Philharmonitor would turn out to be the better deal since the cabinet costs are lower. Plus, it has a ribbon tweeter, which I prefer--particularly for jazz and classical music. I haven't heard many powered speakers. But I am familiar with the non-powered Cambridge S30, which is an excellent deal if you don't need much bass extension.
Nethawk likes this.
Dennis Murphy is online now
Old 03-25-2014, 03:54 PM
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
Originally Posted by JerryLove View Post
Considering your budget: if you'd like to go more up-scale in appearance and sound; I'd recommend http://philharmonicaudio.com/philharmonicaudio/philpages/monitors.html
As a bonus: a portion of the profits go to the Washington Philharmonic Orchestra.
How would the Adam F7 compare to this one?
seiyafan is offline
Old 03-25-2014, 06:22 PM
jevans64's Avatar
Quoted: 187 Post(s)
Liked: 145
Do you have some exact measurements of your computer desk? Size of monitor? Other stuff that will take up space on the desk?
Reason this would be good for us to know is that you really want the biggest main driver/speaker you can fit on your desk. I wouldn't go any smaller than a 5" main driver if you want decent low-end output for big Contra Bass sound in classical music. I DO have back-ported active monitors, and, yes, you have to have some distance between back of speaker and wall. The distance will depend on your room though. Mine sound best at about 12" from the back wall. Isolation pads/stands are recommended as well to keep the desk from vibrating. These will also tighten up the sound as well.
I think an X-ART ribbon tweeter is what you'll want for classical. The one in the Emotiva Airmotiv compares to the one in Adam active speakers. I used my Airmotiv 5 with just the analog out on my computer for a while. You'll be fine with compressed music codecs but you'll want a DAC for high-resolution music. There is A LOT of classical out there in SACD or 24-bit/192 kHz quality.
As others have stated, the Emotiva Airmotiv 6 are currently on sale because these are being phased out in favor of their Stealth 6. They are a bit too big for my 60" x 30" desk with 27" monitor and computer, but they are solid performers with 200w RMS per speaker. I can't recommend the Emotiva DC-1 DAC enough. It is a well-designed DAC with precision analog volume control and TWO high-quality headphone pre-amps. It also has a standard RCA analog input for legacy sources. Other DACs to consider are, of course, Topping, Dayton, Teac, Audioengine, and Parasound.
I haven't heard the Adam F7, but I did a side-by-side with the A5X vs. my Emotiva Airmotiv 5. I just couldn't justify the price of the Adam when I really couldn't tell the difference those and the Emotiva. I preferred the Emotiva over the rest of the stuff I demoed at Guitar Center as well.
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
Old 03-25-2014, 10:41 PM
seiyafan's Avatar
Quoted: 28 Post(s)
Liked: 25
Interesting, I am into classical music too. Have you heard the JBL LSR 305/308?
seiyafan is offline
Kef Q300wa Bookshelf Speakers , Onkyo Tx 8255 Stereo Receiver , Onkyo Tx 8050 Network Stereo Receiver Black , Harman Kardon Hk 3490 120 Watt Stereo Receiver
