Bookshelf Speaker HELP PLEASE - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2013, 05:39 PM - Thread Starter
FunkMonkey55's Avatar
Hello I am looking to buy some new bookshelf speakers mainly for audio purposes, but will also be used for movies. The system will later be upgraded to a 5.1 arrangement when money is a little less tight.
I prefer 6.5" woofers ( since 8" seem to be out of budget) and enjoy powerful yet detailed sound. My budget is <$550 for the pair.
I am currently looking at the Focal Chorus 706V's and Klipsch RB-61II's. Are there better options? What are y'all suggestions? My amplifier is capable of running 100Wrms per channel @ 8ohms
FunkMonkey55 is offline
Old 07-08-2013, 06:08 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
I highly recommend ascend acoustic cbm170se's
They have the 6.5 inch woofer and sound very crisp detailed and acurrate for both music and movies even when pushed hard.
Then in the future u can do what I did and upgrade to the 340s for mains.
That way u will have matching 6.5 woofers all the way around
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
Old 07-08-2013, 07:26 PM - Thread Starter
Can the cbm170se's handle the daunting tasks of L/R mains? Also how is their bass performance? I have read a lot of good things about their mid/high performance, but shied away due to uncertainty of low-end response.
Old 07-08-2013, 07:41 PM - Thread Starter
What about def tec sm45's??
Old 07-08-2013, 07:54 PM
Kini62's Avatar
Quoted: 1415 Post(s)
Liked: 1298
A lot of good speakers in that price range. These Swans are probably the best deal in your price range right now.
http://www.theaudioinsider.com/product_info.php?p=swan-d2-1se%2B-stand-monitor&products_id=69&osCsid=48df3499f28c59a73481db73461a6700
Of course you really need to listen to as many speakers as you can to see what YOU like. Doesn't matter what anybody else likes. We can only give you our opinion of what WE like.
There are of course "professional" reviews and measurements etc...
I think you would be happy with any of them. The Klipsch seem to be the only one that has a love or hate thing. The compression tweeter in the horn tends to put some people off.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
Old 07-08-2013, 08:04 PM - Thread Starter
I have heard a pair of swans and did enjoy the sound. I will say I am rather biased to Klipsch. I enjoy bright highs. I use the promedia 2.1 set up for my computer and they definitely get the job done, but looking for a major upgrade. Is there really a huge difference in performance between the rb 51's and rb 61s? In other words does the tweet on the 51's completely drown out the 5.25" woofer?
Old 07-08-2013, 08:05 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
There low end is pretty good. It doesn't have any kind of hump down low its pretty much flat all the way from low to high and has a seamless crossover so the low end isn't as pronounced as maybe some speakers.
The 170s are awsome though when crossed at 80hz (depending on room conditions and taste I guess) and run with a sub.
I am much more happy with the 340s full range and no sub. The 170s I always ran with the sub
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
Old 07-08-2013, 08:16 PM - Thread Starter
Thanks alot for the input guys. Have a hard decision to make haha...
Kini62's Avatar
Liked: 1298
IMO when I demoed some Klipsch speakers a few years ago it seemed that as the woofer size went up the midrange got better, "thicker", more full. I would go for the 61s if you can afford it.
Def Tech SC8000
Kini62 is offline
Old 07-08-2013, 08:35 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
As far as using the 170s as mainsthere great for there size but in my opinion the 340s are the way to go no doubt.
Here is my review if u care to skim it
http://www.avsforum.com/t/1478626/ascend-acoustic-5-1-setup-review
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
Old 07-09-2013, 01:11 AM
Brian323's Avatar
If you like the horn tweeters you should definately get the Hsu HB-1's or a pair of HC-1's that is on sale rigt now for $469.00
You can rotate the tweeter of the Center 90 degrees and keep them upright. (maybe ask the technician there to do it for you if you dont want to screw it up before they ship it/ that is what I am planning to do soon. Who knows they might do it.)
LIke you mentioned, there are no other tweeter that match the horn tweeters as far as soundstage/realism/livelness goes...
The Hsu uses controlled directivity horn tweeters.
Here is a little information on that type of tweeter you prefer.
http://forums.soundandvisionmag.com/showthread.php?43995-Why-Horn-Loudspeakers
Why Horn Loudspeakers?
I posted this summary of the benefits of horn loudspekers on another forum. I thought that it might be interesting to also post it here as a topic of discussion:
Horns used to be the only way to get any sound out of the feeble power amplifiers available in the 1920''''s. They were used in large spaces like movie theaters to make a few watts of power fill an auditorium. And, of course, they were used on acoustic phonographs to get any sound at all!
Is there an advantage in using them now? Well, let''''s see.
They are still used in movie theaters, stadiums, concert halls and any other place where the sound has to be very loud, and fill a large space. One of their chief advantages is that because of their sensitivity and efficiency, they can easily take the wide dynamic range of motion picture soundtracks, live music, etc. If you tried to push any all-direct radiator speaker to the sound presure levels encountered in filling a movie theater, it would self-distruct in no time. Also, horns can be made to any directional characteristic needed. They can be made to fill a very specific area of an auditorium, with no sound wasted from being directed where it''''s not needed.
None of the above advantages have anything per se to do with home theater, or sound quality in general. In fact, the above systems sound pretty darn bad by hi-fidelity standards!
Now, Paul Klipsch of Klipsch Loudspeaker fame recognized the advantages of horns for home use in the late 1940''''s and created the Klipschorn. He championed one unique advantage to horns that does have a direct bearing on sound quality. That is low doppler distortion, in addition to low amounts of harmonic distortion. Simply put, doppler distortion arises whenever the source of sound moves, relative to a fixed point (the listener in this instance). What is moving? Picture the cone of a 15" speaker moving back and forth by 1/2" as it reproduces a 30Hz tone at a loud volume. Now superimpose another tone of 1000Hz on top of that 30Hz tone. The speaker cone is now moving that 1000Hz tone nearer and farther from you at a rate of 30Hz! The effect is exactly as that of a car passing you by while honking it''''s horn. In that speaker, it will make the 1000Hz tone sound like it''''s ''''underwater'''', or ''''gurgly''''. You are literally frequency modulating that 1000Hz tone, and creating distortion sidebands in the process.
Paul Klipsch reasoned that since a horn is very efficient, it''''s moving parts (the diaphram of the horn) needed to move very small distances in order to create healthy sound pressure levels. Because of this, his horn speakers produced dramatically reduced levels of doppler distortion (and also lower levels of harmonic distortion, for the same reason). They sounded cleaner than what was available at the time.
This is still true today, and is one of the chief advantages of horn speakers.
Of course, speaker technology has marched forward since that time, and today''''s speakers are much better than they were in 1950. BUT - take any speaker system today with direct radiators and play a loud continous bass tone that the speaker can reproduce, and add another pure tone that will be reproduced by that same driver (that has not been crossed over to the mid-range speaker by the crossover network), and you will hear doppler distortion if the level is increased enough.
Does this still matter today? People who make horn speakers (like Klipsch) think so.
When hi-fidelity meant only two speakers and music only, all this was somewhat a non issue to all but a few crazies like myself. Now, with the advent of home theater, with it''''s requirement to reproduce all manner of explosions, gunfire and other acts of violence, maybe it does matter. There''''s no denying that horns reproduce movie soundtracks with more ''''punch'''' than direct radiators do. Those of you who have Klipsch speakers probably purchased them because they sounded good with movies. But does this make horns better?
That is a personal question. Any good speaker can sound wonderful. Speaker manufacturing technology has evolved tremendously, and today''''s consumer speakers sound WAY better than they did 20 years ago. But here are a couple points:
As discussed above, horns reduce forms of distortion like doppler, and also harmonic and intermodulation distortion because the moving parts have to move so little to create high sound pressure levels.
Because horns can have a very well defined directional pattern, they are very adaptable to the principles espoused by certification entities like THX. It is much harder to control directivity with direct radiators. The sound can be controlled and kept off walls, floors and ceilings to a greater extent before it reaches the listener. This has become important in home theater.
With a all-horn system, it is possible by nature of the length of a horn to achieve precise time alignment between the low and high frequency drivers by simply moving them in relation to each other, forward and back. Moving their relative position while looking at the reproduction of a square wave is a good way to achieve precise time alignment. This is not possible with direct radiator speakers, when the drivers are all mounted on one flat baffle. This limitation can be overcome however by slanting the baffle, or having stepped mounting surfaces for each driver.
Then, there is the characteristic ''''horn sound''''. This can be absolutely wonderful and ''''alive'''' sounding if the horn system is executed well. Horns can also have a unique way of imaging the soundstage. They can image well behind the speakers (in stereo) as most conventional designs can, but they also have the ability to image the performers well into the room and all around you, way beyond the confines of the speakers. I''''ve yet to hear a non-horn system that can do that as effectively.
Horns are unfortunately not executed well a good deal of the time, and the resulting horns sound simply "honky". Horn systems such as these, and horns used for PA applications have given them a bad reputation for some people.
As horn coverage is widened to encompass more of the audio spectrum, it becomes increasingly important to use tube amplification. This is because of the uniquely wide "class ''''A'''' window" these tube amplifiers afford.
Horns are used mainly for tweeters in consumer systems today. It is very expensive to make a horn. In fact, most all horns today do not make use of a very important component that complements the horn: THE COMPRESSION DRIVER. Most horns today could be more accurately described as horn-loaded tweeters. They use a conventional speaker driver with a horn in front of it. A compression driver has a diaphram that fires through a ''''donut'''' shaped magnetic structure. But before it reaches the throat of the driver, the sound passes through a ''''phasing plug'''' which corrects the phase of the signals that enter the throat from the various parts of the diaphram. Thus there is no phase cancellation from say , the sound coming from the edge of the diaphram and that coming from the center. The problem with compression drivers is that they are extremely expensive to make. They require machining of precision parts, and this makes them cost prohibitive for consumer use.
The makers of today''''s horn speakers have done an excellent job of working around some problems arising from the lack of a true compression driver. Some of the phase problems resulting from direct loading of a conventional driver remain, however.
As home theater has come into being, there has been a gradual shift upwards in the sensitivity of speakers. This is probably for two reasons. More sensitive speakers (especially horns) are more able to take the abuse of sound effects that exist in modern motion picture soundtracks. This is simply because the speaker elements do not have to move as much to generate a particular sound pressure level. Thus less likelyhood of damage to the drivers. Another reason is that higher sensitivity speakers makes it possible to lower the power requirements of the power amps that power them. This was not much of an issue when amplifiers only had two channels, but gets to be a very big issue when as much as seven channels are put into a single amplifier chassis. 7 times 1000 watts? Get ''''outta town!!
Should you consider a horn system? Well, that is a question only you can answer. Shop around and give the various horn designs a listen. There are only a couple firms that market all horn speaker systems currently, most systems having horn tweeters. Therefore, for better or worse, your selection, and therefore how crazy you can get with it, is somewhat limited. That is, unless you go with professional speakers....
The controlled directivity of the Hsu with the horn tweeters takes away the "honkey-ness". Definately give them a try since they havce a 30 trial period as well.
Brian323 is offline
Old 07-09-2013, 02:41 AM
Nethawk's Avatar
Liked: 118
You can add Kef Q300 to the list.
Nethawk is offline
