Reference vs non - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-08-2013, 11:15 PM - Thread Starter
techlax's Avatar
For you klipsch owners my question is How would you describe the reference series? Is it a difference anyone could tell? Is it worth the extra coin to get a RF-62 vs a F-20.
techlax is offline
post #2 of 6 Old 07-09-2013, 08:56 AM
flickhtguru's Avatar
Liked: 111
I am a NON Klipsch owner but have done a few setups for ppl using the Icon and Synergy series and I have demo'd the Reference series.
IMO the Reference series is definitely better, BUT if you are only buying the Front Tower speakers and are on a tight budget the Icon or Synergy are fine unless your an audiophile and looking for a great musical speaker. However if you are planning on a 5.1 or higher Klipsch system I would recommend the Reference series. The centers in the Icon and Synergy series are really lacking and have horrible bass response and sound best with an xover at 100hz which to me is too high The RC-62 or even the RC-52 is a much better choice for a center. The surrounds in the Reference series are also much better than the others.
Shawn
flickhtguru is offline
post #3 of 6 Old 07-09-2013, 06:04 PM
Prime316's Avatar
Quoted: 185 Post(s)
Liked: 205
Projector: Benq W1070 1080p 2D/3D
AVR: Denon X2200W
Mains: Klipsch RF-62ii x 2
Center: Klipsch RC-62ii
Surrounds: Klipsch RS-42ii x 4
Subs: Dual Hsu VTF-15H's
Prime316 is offline
post #4 of 6 Old 07-09-2013, 06:09 PM
Mike Garrett's Avatar
Quoted: 6955 Post(s)
Liked: 4645
The reference line has lighter stronger, more rigid cones and more powerful motors. That is why the reference line is better.
mjgarrett100@gmail.com
Mike Garrett is online now
post #5 of 6 Old 07-09-2013, 10:03 PM - Thread Starter
techlax's Avatar
I currently have a RC52 centre, Celestion F30 towers (10 years old), no name surrounds. Deciding on whether to buy a set of bookshelfs and surrounds to match my Klipsch centre or just gradually piece out a new speaker setup.
techlax is offline
post #6 of 6 Old 07-10-2013, 11:00 AM
SDB30's Avatar
Quoted: 14 Post(s)
I have a pair of Icon Kb-15's, would the rb-51's be a major upgrade? I watch mostly TV and Movies, music every once in a while,
SDB30 is offline
Reply Speakers
