HTD level 2 VS Polk audio ebay store - Page 5 - AVS Forum | Home Theater Discussions And Reviews
post #121 of 123 Old 07-20-2013, 11:29 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Free measurement software.
http://www.hometheatershack.com/roomeq/
Allows you to figure out what frequencies need to be EQ'd by taking a measurement of your subs response. Yes you can use the mic that comes with your receiver for this. You will have to find the patience to learn to use the software correctly, but it is possible even for someone unfamiliar with the subject material.
Jay1 is offline
post #122 of 123 Old 07-21-2013, 10:13 AM
Shady195's Avatar
Liked: 34
There is also a built in EQ on REW that will tell you the c correct adjustments that need to be made to get the desired output
It's not 100% foolproof but after just starting to play with it it gets your pretty darn close then its just little tweaks if you so choose
The Mic On the denon does audysseys EQ, and while it sure to make everything a little more balanced its not as good as going through yourself and doing it.
EMP E55ti | EMP E56ci | Polk T15's for surround duty | Ultimax 15" Sub | Integra 40.2 | Rotel 976 | Panasonic 60ST60
Shady195 is offline
post #123 of 123 Old 07-26-2013, 07:25 PM - Thread Starter
powerlifter405's Avatar
Quoted: 67 Post(s)
Liked: 80
ok good idea
Stereo Noob, Sherbourn SR-120 pushing 5ch Arx/Chane. 2nd Gen JTR 218HT prototype
powerlifter405 is offline
Reply Speakers
Polk Audio Rti A7 Floorstanding Speaker , Denon Avr 2113ci Receiver , Polk Audio Rti A1 Bookshelf Speakers Pair Black , Polk Audio Psw125 12 Inch Powered Subwoofer Black , Polk Audio Csi A6 Center Channel Speaker Single Cherry
