To THX or not to THX - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-10-2013, 12:32 PM - Thread Starter
bert170881's Avatar
Hi everyone
As mentioned in a bit older thread I'm going to construct a HT-dedicated room with in wall and in ceiling speakers.
I'm focussing right now on the Klipsch-speakers, but they got a THX-line and a 'normal' line which is, you'd never guess it, a lot cheaper.
Now for me, I'm not that a audioholic that THX is a must have, but my AV-receiver and propably my beamer (an Epson) will also be THX-certified.
Do you guys think those THX-speakers are worth it's price or ain't they really necessary to get an awesome sound?
bert170881 is offline
post #2 of 10 Old 07-10-2013, 12:46 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 878
I assume you mean the thx ultra 2 line,
They're very good speakers, but whether or not they're worth it depends on the price. In most cases, unless you're getting a bargain, there are better options for the price.
KidHorn is offline
post #3 of 10 Old 07-10-2013, 01:07 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
If its a dedicated room why are you going with in walls? You get much more bang for your buck with traditional speakers. Just get an acoustically transparent screen and hide the front three behind it.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #4 of 10 Old 07-10-2013, 01:26 PM
Transmaniacon's Avatar
Quoted: 1530 Post(s)
Liked: 1319
I would go for the Klipsch Reference series instead. With the savings, buy a better sub or a second one, and add some room treatments (since this is a dedicated room). You will get a lot more out of your system that way.
Samsung PN60F5300 | Denon AVR-1713 | EMP E55Ti | EMP E56Ci | EMP E5Bi | Outlaw Ultra-X12
Transmaniacon is offline
post #5 of 10 Old 07-10-2013, 02:44 PM
MKtheater's Avatar
Quoted: 1591 Post(s)
Liked: 1122
It all depends on price. What about the Heresy speaker.
Marantz 7702 Atmos
MKtheater is offline
post #6 of 10 Old 07-10-2013, 02:59 PM
Zen Traveler's Avatar
Quoted: 527 Post(s)
Liked: 530
I bet a lower end AVR could drive 5 Heresies and a sub, but if you weren't going to go all Heresy, finding a center channel and surrounds would be a problem...
That said, I heard an all Heresy setup with two SVS subs and it sounded nice but I would rather have the RF-7s and appropriate center channel up front, and substitute direct radiating speakers for their WDST line...I'm also convinced you need an AVR whose power supply can handle 4 Ohm loads with all speakers being driven with the upper-end Klipsch Reference..
Zen Traveler is online now
post #7 of 10 Old 07-10-2013, 05:17 PM
jbrown15's Avatar
Quoted: 2523 Post(s)
Liked: 1993
I was looking threw the classified section yesterday and I ran across what seems like a pretty good deal on a THX Jamo D7 Ultra2 setup for only $2500, that might be worth taking a look at!
http://www.avsforum.com/t/1480769/jamo-d7-thx-ultra2-system-5-d7lcr-and-2-d7sur
jbrown15 is offline
post #8 of 10 Old 07-10-2013, 05:51 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Originally Posted by bert170881 View Post
Hi everyone
The Klipsch THX in-wall line is a fully enclosed speaker set. The rest of the Klipsch in-wall line is open-backed. There is a *HUGE* difference between enclosed and open-backed in-walls. Read this: http://www.cepro.com/article/how_to_prevent_audio_loss_with_in_wall_speaker_systems/D1/ In a Home Theater environment, I would *never* use open-backed in-walls. But that's just me.
In addition, THX certification of speakers, (in-walls or free-standing), ensures the following:
  • wide horizontal dispersion with limited vertical dispersion
  • the ability to output full Reference Level at 12 ft in a 3,00 cubic foot room
  • the ability to be used with the THX crossover of 80 Hz and have the proper roll-off
If any or all of those things are important to you, and the speakers are within the budget, then yes, they're "worth it."
Craig
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #9 of 10 Old 07-10-2013, 07:12 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
I agree with Flying_fool.
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #10 of 10 Old 07-10-2013, 10:17 PM - Thread Starter
bert170881's Avatar
@all: thx for the replies!
@craig-john: thx for the technical explanation. It seems indeed worth it to look into those fully enclosed speakers.
Reply Speakers
