Speaker Suggestion - Paradigm Studio 60/100 or Energy Connoisseur RC-70 - Rotel 200 wpc Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-12-2013, 01:47 PM - Thread Starter
pont2000's Avatar
Hey,
Need some advice. I'm not able to audition the speakers I have tentatively selected, Paradigm Studio 60/100 or the Energy Connoisseur RC-70. Speakers will be used in a strictly 2 channel set up with an Anthem Pre and a Rotel Class A/B SS amp running 200 wps. I listen to Blues, Oldies, Rockabilly and Country as well. I like to play it loud whenever possible. Almost all of my 2 channel music is from Flac and High Res Flac from my Mac through a Logitech Squeezebox Touch, using the DAC from my Anthem. My room is about 20 x 13 ft, and then is open to L shaped into the dining room. I like a speaker that has good solid, clean bass and easy to listen to for extended periods. The Paradigms are around $2600, Energy RC-70 at $800.00. Other brands can also be considered.
All suggestions will be welcomed.
pont2000 is offline
post #2 of 3 Old 07-12-2013, 03:29 PM
eljaycanuck's Avatar
Quoted: 1346 Post(s)
Liked: 1962
Gently-used on CanuckAudioMart.com:
- Paradigm Studio 60v4 in Rosewood ($750)
- Paradigm Studio 100v2 ($800)
eljaycanuck is offline
post #3 of 3 Old 07-13-2013, 01:36 PM - Thread Starter
pont2000's Avatar
Thanks, appreciate the links!!
pont2000 is offline
Reply Speakers
Paradigm Studio 60
