are there good small speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 07-13-2013, 08:49 PM - Thread Starter
danonkeys's Avatar
I was looking for and got advice on speakers in another thread and thought I was all set, but then I ran into a snag.
It turns out that when my wife found out that the new sound system would include 3 speakers 14.75" x 8-1/4" x 11" (HWD) (plus an AVR W 17.1" x 6.57" x 12.95"), she was blown away by these sizes. She was anticipating bose-like speakers the size of your fist -- not speakers the size of a stack of 8 or so reams of paper. To be fair we have no sound system at all, so the AVR and speakers will be added to our existing (minimalist) setup -- and everything else is small or tiny (except the TV on the wall which is serving our audio needs for now).
We have a wide open minimalist floorplan and decorating style, and small speakers seem to be strongly preferable.
My question is: are there small speakers that don't suck? how small can I go? Does it help if I kick up my budget? how high would I have to go? (A related question probably for another forum is: are there small AVRs?)
There is still hope I'll be able to figure out a way to sell the idea of the stacks-of-reams-of-paper-sized speakers -- especially if I give it more time. It would help if I understood the options on the small side.
Thanks for any help!
danonkeys is offline
post #2 of 18 Old 07-13-2013, 09:03 PM
Bill Fitzmaurice's Avatar
Liked: 4630
A speaker's capabilities are pretty much directly related to size, so if you want small speakers you will get small sound.
Bill Fitzmaurice is online now
post #3 of 18 Old 07-13-2013, 09:22 PM
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 29
While larger speakers with many drivers are certainly ideal, you can certainly get quite an improvement and definitely a fairly filling sound (depending on the size of your room) with higher quality satellite speakers and a good subwoofer. If I'm remembering correctly, Jamo is the brand of fairly good quality satellite speakers for their size. You will have to step up your budget a bit to get larger sound from smaller speakers (since they need larger neodymium magnets for their size to increase output). As for small receivers, the Marantz 1504/1604 may be good compact receivers to look into.
avfanatic1 is offline
post #4 of 18 Old 07-13-2013, 09:26 PM
avfanatic1's Avatar
Quoted: 74 Post(s)
Liked: 29
Could something the size of the Energy 5.1 speakers work? (6 7/8 x 4 1/8 x 4 1/8)
post #5 of 18 Old 07-13-2013, 09:53 PM
JerryLove's Avatar
Liked: 79
There's always going to be a compromise related to driver size (assuming you want any real volume).
Some other options include use of in-wall or in-ceiling speakers. Also: panel speakers are possible (though they have placement concerns so perhaps bad), as they are flat and can be hung on walls like art.
I would drop the center in favor of a phantom before I would shrink the LCR down too much in size. And (I presume since you have a center, you are looking at watching movies) don't forget the sub.
Another idea might be to mix the speakers into the decor. While something like (http://salksound.com/veracity%20st%20-%20home.htm) would be large, it is as much a piece of art as anything else in there and has a very small footprint.
JerryLove is offline
post #6 of 18 Old 07-13-2013, 09:55 PM
Mr.SoftDome's Avatar
Quoted: 389 Post(s)
Liked: 308
I am in a small condo. Of course I prefer much larger speakers with large drivers when possible. I needed small speakers to accommodate my rear needs. My Dynaudio Focus 110s were too big for rear and I moved them out for now.
I went with Focal Dome and while not cheap they are by far the best small speakers I have heard. I played with them in my front just to get an idea and of course they are not close to my C1s but I am very very impressed with these speakers and they look great as well.
There is a picture in my album in rear use. You may google some reviews and they are available at musicdirect.com.
http://www.musicdirect.com/p-4508-focal-dome-20-mini-speakers-pr.aspx
http://www.musicdirect.com/p-4010-focal-dome-stands-pr.aspx
http://www.youtube.com/watch?v=JpHIr9WmMoo
If you must use a smaller satellite speaker I highly suggest them. If you can go for a traditional speaker I suggest that route but all in all these are really nice speakers although fairly expensive. The stands that complete the look is at $300 or so.
Rick
Mr.SoftDome is offline
post #7 of 18 Old 07-14-2013, 02:20 AM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
As mentioned by others ... with small/satellite speakers you'll always loose low freq. and even lower-mid freq. The sub will need to take over these freq. so you should probably plan on a mid-priced ($600-$700) sub, with good accuracy, detail, etc. (Most the "budget" subs are a bit sloppy and you want to avoid that with satellite speakers.)
Re general sq, I've heard some very nice sounding small speakers but they are (considerably) more expensive than their bookshelf equivalents. The Focal Dome's mentioned by Mr.SoftDome are a good example - small, great sq, pricey.
I can think of two satellite speakers in the $100 a piece range that get good mention ...
- The NHT Absolute Zero.
- The Cambridge Audio Minx - Min11 and Min21. (The larger Min21 is about the size of a Coke can.) There is an active owners thread here in the forum that should be helpful.
A wild card option ... the KEF KHT 3005 SE satellite system (w K2 sub) is on clearance at accessories4less for $900. The sub that comes with the system doesn't go particularly low (fine for music, just ok for HT) but it does cover the freq. zone between the sub-bass and the satellites very well. The system's current "clearance" price makes it one of the few "mid-priced", good sounding satellite systems out there.
http://www.accessories4less.com/make-a-store/item/KEFKHT3005BLKSEK2/KEF-Kht3005-se-5.1-Speaker-Package-with-Kube2-subwoofer-Black/1.html#!more
If you did go with the KEF you might consider upgrading the sub somewhere down the road.
sdg4vfx is offline
post #8 of 18 Old 07-14-2013, 06:44 AM
KnifeGuy's Avatar
Salk Silks are a smaller and the finish is completely customizable. However they are expensive. I've heard these and they are astounding for a speaker of their size. They also play down to 42Hz so you may be able to eliminate a sub (although I would still run a sub for TV and movies if it were me).
A phantom center as JerryLove suggested will keep the cost down and eliminate one more thing in your room. You may notice some dialogue shift out of the sweet spot without a center though.
For the AVR and other electronics, you can hide them away in a closet. Get an IR repeater to send the signals from your remote to the AVR. Run the cables and speaker wires through the walls to their destinations and then the size of the AVR, cable box, amp etc is irrelevant. Just make sure you have good air flow into and out of the electronic closet.
Salk Silks and the elimination of a sub and all your electronics in a closet is about as minimalist as you can get while still providing high SQ.
KnifeGuy is offline
post #9 of 18 Old 07-14-2013, 03:35 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
I had a chance to hear the Salk Silks and they sound fantastic. Cost is $3500 a pair. They aren't necessarily "small" speakers though, they are fairly average size bookshelf speakers ... 14 H x 8 W x 11 D.
If you can go that large the Ascend Sierra 1 is a popular option - it's the same size, goes down to 44hz and many folks use it without a sub. They go for $850 a pair.
sdg4vfx is offline
post #10 of 18 Old 07-14-2013, 03:53 PM
Nethawk's Avatar
Liked: 118
I own a pair of small bookshelf EMP Tek E41-B, the finest pair of small speakers I've heard. While they are discontinued the E41 are still being manufactured, the only difference is material makeup of the midrange. I've read there is little difference. At $300 per pair they're worth considering.
Nethawk is offline
post #11 of 18 Old 07-14-2013, 07:13 PM
JerryLove's Avatar
Liked: 79
I am suddenly reminded though of a pair of (IIRC Song Surrounds, which are much less expensive than the Silks) that Jim built on request that were tall and wide but very shallow. They were intended to be hung on walls.
If the issue is "I don't want to see the speakers", that doesn't help... but if the issue is space they take up: they are functionally quite discreet and can be made in any finish desired.
I'm not fully sure if the OP is truly only looking for "tiny" or is actually looking to solve a space+appearance issue.
post #12 of 18 Old 07-14-2013, 08:52 PM
Elihawk's Avatar
Quoted: 1014 Post(s)
Liked: 856
The Cambridge audio minx systems gets high reviews for a small speaker!
Set up #1: EMP e5ti, e5Ci, and EMP e5Bi surrounds, Outlaw LFM1 Plus sub, EMP 10i10i sub
Set up #2: Def Tech SM450, CLR2002, SLS Qline surrounds and Klipsch 12wD sub
Set up #3: Philharmonics- BMR in a 2.0 system, music only
Elihawk is online now
post #13 of 18 Old 07-14-2013, 09:03 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 913
What about ascend acoustic Htm 200s all around
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is online now
post #14 of 18 Old 07-25-2013, 11:52 AM - Thread Starter
danonkeys's Avatar
Thank you all so much for your ideas and help! I ended up not having to compromise quite so much on the size of the speakers by adding in a piece of furniture that helps minimize the visual impact of the KEF Q series (Q100, Q200, Q400) that are on their way. A major compromise for now will be that I have to lay the Q100 L/R on their side -- not idea I know, but I decided for that that is a better compromise than getting smaller speakers.
Any thoughts on which side to lay them on? I'm guessing drive units out.
Anyhow, more details over here as setup is my next step after the stuff gets here.
post #15 of 18 Old 07-25-2013, 12:33 PM
Ron Alcasid's Avatar
Shouldn't be an issue with concentric drivers.
Ron Alcasid is offline
post #16 of 18 Old 07-25-2013, 12:36 PM
accordn2ryan's Avatar
How big is your living room? I'm in a similar situation, but I do share one wall with a neighbor and just worried about purchasing a sub that will be too loud.
accordn2ryan is offline
post #17 of 18 Old 07-25-2013, 12:55 PM
simp1yamazn's Avatar
Quoted: 109 Post(s)
Liked: 77
I would suggest not dismissing a particular sub because of overall volume capability. A sub that is playing too loud can be turned down. A sub that can't create clean bass will often times sound even louder because of high levels of distortion. A sub that can play cleanly at higher volumes will sound better at moderate volumes than a cheap sub. Just my $0.02
simp1yamazn is offline
post #18 of 18 Old 07-25-2013, 01:49 PM - Thread Starter
danonkeys's Avatar
Details are here, but the short answer is roughly 21x22 feet.
Reply Speakers
Marantz Nr1504 Slim Line 5 1 Network Receiver , Marantz Nr1604 Slim Line 7 1 Network Receiver , Energy Rc Micro 5 1 Surround Speaker System Black
