Crossover question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-13-2013, 07:55 PM - Thread Starter
tkarns24's Avatar
I have a custom built LCR(I know no popular) that has 2 daytona RS100 and a  Dayton Audio ND28F-6 1-1/8" Neodymium Dome Tweeter for each channel . Now  here are the spec charts for both
Daytona RS100
PRODUCT SPECIFICATIONS
Power Handling (RMS)      30 Watts
Power Handling (max)      60 Watts
Impedance      8 ohms
Frequency Response      87 to 20,000 Hz
Sensitivity      85.6 dB 1W/1m
Voice Coil Diameter      1"
Daytona ND28F-6
Specifications: • Power handling: 30 watts RMS/60 watts max • VCdia: 1" • Le: 0.08 mH • Impedance: 6 ohms • Re: 5.4 ohms • Frequency range: 2,200-20,000 Hz • Fs: 1,097 Hz • SPL: 88.4 db 1W/1m • Qms: 2.16 • Qes: 2.94 • Qts: 1.24 • Dimensions: Overall diameter: 2.56", Cutout diameter: 1.71", Depth: 0.77"
Here are my questions.
What should i set my frequency response at, I was thinking 80hz.?
should i send any base the the drivers in this case at all?
Guys I am new to all the calibration stuff and can use any help that i can get . I would like to set it up right this time.
tkarns24 is offline
post #2 of 8 Old 07-13-2013, 08:34 PM
Ozzie Isaac's Avatar
Liked: 102
Would post in the DIY section. You will get more responses.
Ozzie Isaac is offline
post #3 of 8 Old 07-14-2013, 06:02 AM - Thread Starter
tkarns24's Avatar
yep
tkarns24 is offline
post #4 of 8 Old 07-14-2013, 06:34 AM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
I would say although your speaker starts to roll so earlier, it will still benifit from a high passed. 80hz is good staring point.
I run my full range and my speaker roll around 70 hz in sealed with sub cross around 50 hz. It all depends how lound you play and the overall integration.
RicardoJoa is offline
post #5 of 8 Old 07-14-2013, 07:00 AM
Mike Garrett's Avatar
Quoted: 6697 Post(s)
Liked: 4381
Daytona RS100
Impedance      8 ohms
Daytona ND28F-6
Did you build someone's design or roll your own? Modeling the cabinet design will answer your question. Also what are you using for a crossover?
mjgarrett100@gmail.com
Mike Garrett is online now
post #6 of 8 Old 07-14-2013, 09:53 AM - Thread Starter
tkarns24's Avatar
I went with my own. i am using a Daytona 3 way
tkarns24 is offline
post #7 of 8 Old 07-14-2013, 09:55 AM - Thread Starter
tkarns24's Avatar
80hz  enen if the driver say 87hz
what do you mean by overall intergration
tkarns24 is offline
post #8 of 8 Old 07-14-2013, 03:22 PM
RicardoJoa's Avatar
Quoted: 23 Post(s)
Liked: 24
Looks like you are finishing up your three way desing. Sorry i thought it was some kind of subwoofer integration.
Check DIY section.
Reply Speakers
