Mini speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 07-14-2013, 04:30 PM - Thread Starter
jsmore's Avatar
Thinking of going small. Orb, Cambridge Anthony gallo.
jsmore is offline
post #2 of 9 Old 07-14-2013, 04:37 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
If I may ask, why do you want small?
And what is your usage in what size room with what size budget?
bladerunner6 is offline
post #3 of 9 Old 07-14-2013, 04:43 PM - Thread Starter
jsmore's Avatar
I've got ML 4's for front 6 center and 2's in back. Thought about upgrading slowly. Motion 30 for center then esl's for fronts. Still might go that way but realizing I'm always going to be chasing the " best" sound. Also not happy with the 6 for tv and movies. Voices just don't pop out and it seems I have to play with the volume constantly to compensate. So, just thought I'd stop reaching and just go with something w itch a small footprint that sounds good with music and clear for for voices. Budget is sort of unlimited as I'm willing to build slowly to be completely satisfied.
jsmore is offline
post #4 of 9 Old 07-14-2013, 05:08 PM - Thread Starter
jsmore's Avatar
Any advice blade runner.
jsmore is offline
post #5 of 9 Old 07-15-2013, 10:05 AM
david3772's Avatar
I hope your thread gets some helpful input. Like you, I have considering going with smaller speakers and have looked at the speakers you mentioned. I have some older B&W's on stands for LR speakers and between the speakers, the tv, and some furniture that wall seems somewhat crowded.
I have read some good reviews on the Orbs and Anthony Gallo's, but I haven't been able to listen to a pair. I saw some small Jamo's (sp?) at a MHT store, but was unable to listen to them. I assume the Cambridge speakers you are considering are in the Minx line?
David
david3772 is offline
post #6 of 9 Old 07-15-2013, 02:03 PM - Thread Starter
jsmore's Avatar
I haven't heard any of them either. That's kind of what I wanted to find out, what is even worth looking at. The Cambridge minx 21's seem to get good reviews.
jsmore is offline
post #7 of 9 Old 07-15-2013, 05:32 PM
jevans64's Avatar
Quoted: 194 Post(s)
Liked: 148
I'm not familiar with any of the speakers mentioned, but they are all a one-way design -- the same as Bose speakers. A slightly larger speaker with a two-way driver design would be better for producing the full frequency range. The Energy RC-Micro speaker set is a two-way design with 3/4" tweeter and 2.5" mid that isn't much bigger than those one-way orb speakers that use a single 3" driver. A 1" tweet, 3.5" mid would be the ideal combo for small speakers, but I'm not familiar with any that are under 5" wide/deep.
Orb's tag-line is, " Small speakers for smart people. " That in itself would make me stay away from that manufacturer since it is so Bose-like. LOL
Denon AVR X7200WA, Emotiva XPR-5, Emotiva XPA-7, Sony XBR 75" 850C, Oppo UDP-203, Roku Ultra.
DefTech BP7000SC (L/R), CLR3000 (C), SM55 (FH), UIW BPZ/A (SB), UIW 75 (TM).
JBL L7 (Sur), EoSone RSR 350 (RH).
PC 2.1 setup. Emotiva Stealth 6, SVS SB16-Ultra sub, Emotiva DC-1 DAC.
jevans64 is offline
post #8 of 9 Old 07-16-2013, 01:14 AM
ien2's Avatar
Quoted: 55 Post(s)
Liked: 69
The Minx uses BMR's and are not the same as a conventional driver, the FR for the Min21's is ~120/150hz - 20khz and it really is that. These are what the Bose cubes should be, but aren't.
We have a thread you may want to browse at your leisure:
http://www.avsforum.com/t/1339511/cambridge-audio-minx-loudspeaker-discussion-thread
I haven't heard the other two, the Jamo's mentioned above aren't worth listening too if it's the spherical speakers he's thinking of. Perpendicular on that thread I believe had the orbs and could tell you what to expect there and how they compare and contrast with the Minx. Otherwise as far as the Minx go, the Min21's are a very nice speaker. Very good clarity and dispersion which produce a sweet area instead of a sweet spot for listening. They are a very musical speaker because of the detail they provide without being harsh or analytical sounding. The dispersion with the clarity and detail that goes with it shines when it comes to dialogue. However, the increasing/decreasing volume has a lot to do with the sound mixing for movies and some tv shows.
The Minx are far better than the RC-Micro's. You aren't missing any low end compared to the Micro's 150hz and the quality of sound is so much better with the Minx.
ien2 is offline
post #9 of 9 Old 07-16-2013, 04:36 AM
BobL's Avatar
Liked: 58
How small does it need to be?  You are always giving up some performance with small speakers, smaller drivers just don't have the output, dynamics, sensitivity or low frequency extension of a larger speaker.  You will benefit from a two-way speaker as compared to one full range driver.  Here are some small speakers but might be too large.
Genelec G One or G Two
Paradigm MilenniaOne
There are many small 3-4" woofer with a tweeter designs or for a little smaller a coaxial design like Tannoy or Kef.  Going smaller than this is a big compromise.
BobL is offline
Reply Speakers
