Thinking going from Energy Reference RC-70 to Paradigm Studio 100 or Studio 60 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-15-2013, 09:01 AM - Thread Starter
pont2000's Avatar
Any Paradigm owners who switched from Energy to Paradigm?? I'm wondering if I switched to the Paradigm Studio 100 whether it would be a notable difference. My amp is a Rotel SS Class AB putting out 200 wpc. I like a good clean low end. Would be interested in your views. Only negative is that the Energy Reference Connoiseur go for $800 a pair and the Paradigm"s are in the $3000.00 +.
pont2000 is offline
post #2 of 5 Old 07-15-2013, 09:06 AM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
Consider shopping at canuckaudiomart.com, used[yourcity].com or [yourcity].kijiji.ca. Gently-used S60v4s should run ~$1,000 or less; S60v3s ~$800 or less. (I paid $1,100 for a mint-condition pair of S60v4s a little over three years ago.)
-- Edit --
A couple of ads currently on CAM:
- Studio 60v4 in Rosewood ($750)
- Studio 60v4 ($900)
eljaycanuck is offline
post #3 of 5 Old 07-15-2013, 09:14 AM - Thread Starter
pont2000's Avatar
Thanks!! I'm in Ottawa region and have been watching CAM to see what comes up. I'm going to be using speakers strictly for a 2 channel set-up. Hoping that I would get some responses from Paradigm owners that have had the Energy's to see if it is worthwhile to make that switch.
Chuck.
pont2000 is offline
post #4 of 5 Old 07-15-2013, 09:15 AM
Liked: 1800
Yeah, sorry I can't provide you with an Energy-to-Paradigm perspective. I'm sure someone who can will chime in soon enough. smile.gif
post #5 of 5 Old 07-15-2013, 06:30 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
I haven't compared them directly, but I've heard each briefly and have listened more to the Studio 60s and the Energy RC-30s and RC-50s.
The RC-70s are fairly warm and forgiving, with some excess mid- to upper-bass and smooth, but somewhat reduced highs.
The Paradigms are more neutral, but some may find them "bright" or a little harsh in comparison to the RC-70s.
If you like a speaker with lots of midbass and forgiving highs, go for the Energy. If you like a more neutral speaker with more relative high-frequency output, go for the Paradigms.
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
Reply Speakers
Paradigm Studio 60
