NES simply being plugged in causes subwoofer rumble - why and should i be worried? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 16 Old 07-15-2013, 11:52 PM - Thread Starter
JohnRaynor's Avatar
The apartment I live in has some electrical wiring issues. I picked up a NES today and noticed something really peculiar. When I plugged the NES in (not even turned on), I get a pretty loud rumble from my sub. The sub is plugged into a different power strip halfway across the room. The sub rumbles even when I unplug my receiver. I tried the RF and composite outputs on the NES; same issue. Why is this happening and should I be worried about the safety of my TV and sound setup? Thanks in advance to anyone who replies.
JohnRaynor is offline
post #2 of 16 Old 07-16-2013, 07:55 AM
Bill Fitzmaurice's Avatar
Liked: 4668
What's an NES?
Bill Fitzmaurice is offline
post #3 of 16 Old 07-16-2013, 07:59 AM
eljaycanuck's Avatar
Quoted: 1235 Post(s)
Liked: 1808
What's an NES?
NES = Nintendo Entertainment System
eljaycanuck is offline
post #4 of 16 Old 07-16-2013, 08:04 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #5 of 16 Old 07-16-2013, 09:02 AM
hdnewbie21's Avatar
Liked: 38
Blow the cartridge, blow inside the system, insert the game cartridge, move it left right, A, B, A, B, Select, start. , ahhh, the good old days.
Yamaha RX-V673 | HSU HC-1 MK2 | HSU HB-1 MK2 - LR | Pioneer SP-BS22-SLR | BIC RtR-V44-2 (Presence)
hdnewbie21 is offline
post #6 of 16 Old 07-16-2013, 10:01 AM
losservatore's Avatar
Quoted: 2315 Post(s)
Liked: 2061
I love old games ,I have controllers clones for Nintendo and Super Nintendo that I use on my PC with emulators ,why you don't just use something like that.
about your problem try a different outlet with long extension cord.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #7 of 16 Old 07-16-2013, 10:06 AM
Liked: 2061
another posible problem, the sub RCA cable may be damage.
post #8 of 16 Old 07-16-2013, 10:24 AM
hdnewbie21's Avatar
Liked: 38
Sorry for being a little off topic, do you have an emulator you can suggest? I've been itching to play super mario. It's been a least 10 years since I used an emulator.
post #9 of 16 Old 07-16-2013, 12:51 PM
Liked: 4668
Sorry, I don't have time to go looking up stuff that should have been made clear in the first place. OP, chances are you have a ground loop.
http://www.rane.com/note110.html
post #10 of 16 Old 07-16-2013, 12:54 PM
Liked: 1808
Hard to believe you didn't have time for a five-second Google search, but you had time to type out "What's an NES?" wink.gif
post #11 of 16 Old 07-16-2013, 02:14 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
Or to post that link about ground loop...smile.gif...he's prolly shocked he didn't know what an NES was...it happens to us all at some point.
Doing what I do best...LIVIN!
josh6113 is offline
post #12 of 16 Old 07-16-2013, 08:23 PM
Liked: 2061
that's a clear proof that he is not a gamer. is not a big deal.
post #13 of 16 Old 07-16-2013, 09:20 PM
josh6113's Avatar
Quoted: 16 Post(s)
Liked: 25
josh6113 is offline
post #14 of 16 Old 07-17-2013, 03:40 PM - Thread Starter
JohnRaynor's Avatar
Can anyone answer why the NES does that, and should I be worried about the safety of my TV and speakers? It seemed like the NES was putting out some serious feedback, and I'm just worried about it damaging my setup.
post #15 of 16 Old 07-17-2013, 09:24 PM
hdnewbie21's Avatar
Liked: 38
Try a different RCA cable like it was suggested, or just turn off the sub. I doubt the NES is sending LFE signals.
post #16 of 16 Old 07-18-2013, 06:29 AM
Liked: 4668
As I already posted a ground loop is likely. Per the link I provided the usual cure is to use transformer isolation of the audio, and in some cases the TV cable as well. Examples:
http://www.amazon.com/s/?ie=UTF8&keywords=audio+isolation+transformer&tag=googhydr-20&index=aps&hvadid=7215107489&hvpos=1t5&hvexid=&hvnetw=s&hvrand=1042901330877224855&hvpone=&hvptwo=&hvqmt=e&hvdev=c&ref=pd_sl_2jpfmdarqt_e
Reply Speakers
