Clean way to run wires out of wall? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-16-2013, 02:26 PM - Thread Starter
SoxFan44's Avatar
I'm lucky enough to have my walls open right now, and I've run speaker wire for 5.1. My question is, what's a clean way to run the wires through the drywall? I figure I can either:
1) Run them to a low voltage box and cover with a wall plate with banana plugs. This seems like it's going to be ugly to have to use a full wall plate for two small plugs. But I don't see any smaller ones.
2) Run the wires directly out of the walls. My concern here is that the drywall guy isn't going to know exactly where I want them to come out and it they're off by a little bit it's going to look ugly.
Any suggestions? Thanks!
SoxFan44 is offline
post #2 of 8 Old 07-16-2013, 02:31 PM
cschang's Avatar
Quoted: 107 Post(s)
Liked: 164
Have you looked at some of these solutions:
http://www.parts-express.com/term/wallplates?srch=wallplates
-curtis
Owner of Wavecrest Audio
Volunteer Mod at the Ascend Acoustics Forum
Like all things on the Internet, do your research, as forums have a good amount of misinformation.
Help beat breast cancer!
cschang is offline
post #3 of 8 Old 07-16-2013, 03:00 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
Run them to a low voltage box. There's a wide selection of wall plates available, and it will give you a more professional looking installation.
crn3371 is offline
post #4 of 8 Old 07-16-2013, 03:18 PM
LastButNotLeast's Avatar
Quoted: 1487 Post(s)
Liked: 1085
LastButNotLeast is offline
post #5 of 8 Old 07-16-2013, 08:24 PM
mbkintner's Avatar
I know exactly where I want my speaker wire to come out so here's what I did.
I used one hole nail in pipe clamps and the smallest PVC pipe I could find.
The drywall will get cut in around the pipe. The pipe will protect the wire and will get pulled through the hole once drywall is finished. I'll then put a grommet into the hole for the wire to go through.
mbkintner is offline
post #6 of 8 Old 07-16-2013, 09:05 PM
Liked: 1085
Will that meet code? I'm just guessing, but that probably wouldn't fly in my township.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
post #7 of 8 Old 07-16-2013, 09:14 PM
mbkintner's Avatar
For what reason? The wire is stapled to the stud so once the the PVC is pulled out it's no different than poking a hole in the drywall and pulling the cable through.
post #8 of 8 Old 07-16-2013, 09:25 PM
Liked: 1085
Reason? Here in NJ they don't need a reason.
Reply Speakers
