7 speakers $500-$700 - AVS Forum
post #1 of 9 Old 07-18-2013, 07:37 AM - Thread Starter
bender222's Avatar
I'm looking to replace some old onkyo speakers from a htib i bought almost 10 years ago. I already have a rhythmic audio lv12r subwoofer and a denon 2313ci. My room will be pre-wired for every channel except for the center (which I can probably do myself). The wires are near the roof so the speakers are mounted near the roof. I am hopping that i can find a bracket or something to angle the speakers downward. Anyway, that means floor standing front speakers are going to be a problem and I need to go with bookshelves. I was browsing around and I came across the pioneer speaker set SP-PK52FS. However since it is only 5.1 and has a sub/floor standing speakers it won't exactly work for me. I then set out to try to piece together a set of speakers that I thought would compare. I opted for the same center channel and 3 pairs of the bookshelves for front, surround, and rear channels. is there any problem with using 3 pairs of identical speakers like this? Can you come up with better options ?
bender222 is offline
post #2 of 9 Old 07-18-2013, 08:24 AM
eljaycanuck's Avatar
Quoted: 70 Post(s)
Liked: 484
I already have a rhythmic audio lv12r subwoofer ...
... I opted for the same center channel and 3 pairs of the bookshelves for front, surround, and rear channels. is there any problem with using 3 pairs of identical speakers like this?
Nope, there's no problem at all.
eljaycanuck is offline
post #3 of 9 Old 07-18-2013, 08:32 AM
flickhtguru's Avatar
Liked: 105
I would check out BIC America FH6-LCR speakers at acousticsounddesign.com. The price listed on the site says $119 each but I know they give 15% discounts to AVS members and they will give you a good deal. I bet you could get 7 of those speakers for around $700 delivered to your house.
Shawn
flickhtguru is offline
post #4 of 9 Old 07-18-2013, 05:26 PM - Thread Starter
bender222's Avatar
so 7xBIC America FH6-LCR? I see they come with wall mounting hardware also which is a plus.
post #5 of 9 Old 07-18-2013, 07:16 PM
Jay1's Avatar
Liked: 102
Given the speaker locations, I dont think the BIC LCR is the best option. It will be hard to angle that speaker down. The FH6 might be a better option
http://www.amazon.com/America-FH-65B-Bookshelf-Speakers-6-5IN/dp/B002ISTP8K/ref=sr_1_2?m=AED492BX4II6G&s=merchant-items&ie=UTF8&qid=1374199842&sr=1-2&keywords=bic+fh6
You could flip the speaker upside down, so the tweeter is closer to you, and then use these mounts to angle it down
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI/ref=sr_1_3?ie=UTF8&qid=1374200074&sr=8-3&keywords=speaker+wall+mounts
Jay1 is offline
post #6 of 9 Old 07-19-2013, 10:02 AM
HOTDIGITY's Avatar
If you haven't seen these already, give them a look:
http://www.wavecrestaudio.com/
Designed by Dave Fabrikant of Ascend Acoustics.
HOTDIGITY is offline
post #7 of 9 Old 07-19-2013, 12:23 PM
smasher50's Avatar
Quoted: 47 Post(s)
Liked: 1113
fwiw, if you live near a fry's electronics they have the infinity p 163's for$129 a pair. imo best bang for the buck besides the p363 for $215 a pair
i'm so laid back,i'm laid out
smasher50 is offline
post #8 of 9 Old 07-19-2013, 12:27 PM
HOTDIGITY's Avatar
Here's a pretty good review of the Wave Crest Audio HVL-1's:
"http://www.avsforum.com/t/1473975/wave-crest-audio-hlv-1-ascend-designed-budget-bookshelf#post_23501698"
Can't hurt to have more info on them, right?!
Happy hunting!
post #9 of 9 Old 07-19-2013, 08:03 PM
sdg4vfx's Avatar
Liked: 94
The Pioneers are remarkable for the price - the go-to budget speaker. But a couple other, slightly higher priced options might be ...
HTD level 2 series. 6 bookshelf and a center would be $730.
Cambridge Audio S30 x6, S50 center would be $760.
I think both would likely be a step up in sound quality.
In the same price range - the new Wave Crest HLV-1's are very interesting too. I haven't heard them but am likely going to audition them soon. They have a very good pedigree and I'm (irresistibly) curious wink.gif
sdg4vfx is online now
Reply Speakers
Denon Avr 2313ci Receiver , Bic America Fh6 Lcr Dual 6 5 Inch 175 Watt Lcr Speaker With Mid High Frequency Horn
Gear in this thread - 2313ci by PriceGrabber.com
