speaker sidewall distances - AVS Forum | Home Theater Discussions And Reviews
Old 07-20-2013, 06:22 PM - Thread Starter
ryu4000's Avatar
Does it matter if one speaker is 2inches more from the wall then the other speaker? would it make a different?Cause right now i got one speaker a little farther from the side wall then the other.Would this mess with imaging etc...?
ryu4000 is offline
Old 07-20-2013, 06:39 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Depends how much that 2" is a percentage of the total distances? How far is the other speaker off the side wall? What kind of distances in total are we talking about here?
kiwi2 is offline
Old 07-20-2013, 06:56 PM - Thread Starter
ryu4000's Avatar
Left side is 2ft 5 and a half and right side is 2ft 4 in a half.Both is 3.1ft from center speaker cone on each side.
ryu4000 is offline
Old 07-20-2013, 08:55 PM
Bill Fitzmaurice's Avatar
Liked: 4640
No, especially if toed in as they should be,
Bill Fitzmaurice is offline
Old 07-20-2013, 09:04 PM - Thread Starter
ryu4000's Avatar
Ok thanks and yes i got them toed in try a few songs sound pretty good everything like voices is dead center.
ryu4000 is offline
Old 07-20-2013, 09:51 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
They shouldn't be too bad like that.
Some people do make the mistake of having their systems too off center. i.e. one speaker in a corner and the other virtually in the middle of the wall length. Those two speakers are going to sound quite different from each other. Kind of defeats the purpose of buying a pair of speakers.
A quick and easy way to tell if there isn't enough acoustic symmetry is to play a full range pink noise through one speaker at a time and notice how much of a pitch change there is between the two. An individual frequency response measurement of each speaker at a time will be more revealing of the different sound fields they may be placed in.
It may not be a problem you would notice from just listening to the speakers until you actually fix the problem and realise how much better they could have been all along.
kiwi2 is offline
