best speaker under $450 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 07-22-2013, 12:52 PM - Thread Starter
jeffrobson1's Avatar
so I have a budget of 450 dollars fro some front speakers in a bedroom setup. My receive is a sony strdh720 to power them what would you guys suggest for me to look into.
Thanks in advance.
Jeff
jeffrobson1 is offline
post #2 of 23 Old 07-22-2013, 01:02 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
Ascend acoustic cbm170s would be plenty for a bedroom
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
post #3 of 23 Old 07-22-2013, 01:20 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
http://www.theaudioinsider.com/product_info.php?p=swan-diva-6-1-floorstanding-loudspeaker%2C-single&products_id=230&osCsid=7f3dbe12088e65f9b7c0c59ab7f63a6e
If your looking for full range tower...
A little more info would be good.
Room size
Will u be using a sub?
Towers? Bookshelfs? Or satalites.. what do u prefer?
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #4 of 23 Old 07-22-2013, 01:29 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
Maybe something with horn tweeter?
http://www.bicamerica.com/showpage.php?brand=1&type=7&spkrID=25
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #5 of 23 Old 07-22-2013, 02:19 PM - Thread Starter
I do not have a subwoofer and my room is 12x13ft.it dosnt matter tower or bookshelf which ever one would fit best I have room also I was as looking at the ascend 170se but I could probly go up in price more what do you think. Thank you for the replies.
post #7 of 23 Old 07-22-2013, 03:28 PM - Thread Starter
well i do have a sub but its not that good its a polk psw10 do you think i should use it
post #8 of 23 Old 07-22-2013, 03:36 PM
smasher50's Avatar
Quoted: 354 Post(s)
Liked: 15611
if you don't mind buying used an avr member is selling his ascend acoustic cmt 340se's and cmt 340se center for $500http://www.avsforum.com/t/1469487/ascend-340-front-speakers
i'm so laid back,i'm laid out
smasher50 is offline
post #9 of 23 Old 07-22-2013, 03:58 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
Ehh, that is a pretty bad sub...
Jay1 is offline
post #10 of 23 Old 07-22-2013, 05:44 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
I like the first option the best. The arx look intresting
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #11 of 23 Old 07-22-2013, 07:27 PM - Thread Starter
those arx are a little over my budget. those ascend 170 have gotten good reveiws all over what do you think about those or the wharfedale 10.1 would you suggest just selling the sub or what
post #12 of 23 Old 07-22-2013, 07:38 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
Well I own the 170ses. They are awsome speakers but were not made to produce deep pounding bass. They do go too like 45hz flat though (ill double check that) and the bass blends very well so it MAY BE less noticeable to some. If your not going to have a sub then theese would not be enough for ht IMO, again there amazing speakers just made to be run with a sub IMO.
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #13 of 23 Old 07-22-2013, 07:49 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
170s go to about 55hz not 45 sorry. The 10.1s should give u a little deeper bass however I have not heard them. If I had to choose between the two with no sub I would probably go with the 10.1s
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #14 of 23 Old 07-22-2013, 07:58 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
Could u sell the sub and save more for the arx speakers?
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #15 of 23 Old 07-22-2013, 08:01 PM
Mike Garrett's Avatar
Quoted: 5567 Post(s)
Liked: 3545
mjgarrett100@gmail.com
Mike Garrett is offline
post #16 of 23 Old 07-22-2013, 08:03 PM
Liked: 3545
I don't think the posted said he is not willing to use a sub, just that he really did not have a decent sub. Without know the locations available to place speakers/subs, it is hard to tell which way to go, book shelf with sub or towers. For HT, I would probably lean toward book shelf and sub. For music, a lot of tower speakers go low enough.
post #17 of 23 Old 07-22-2013, 08:08 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
Okay I was under the impression his sub was not good enough and he wasn't buying another.
If u are intrested in a sub though a rd12w and the cbm170s would be an awsome setup for the bedroom imo
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
post #18 of 23 Old 07-22-2013, 08:23 PM - Thread Starter
i have room for a subwoofer and bookshelfs on stands or tower speakers i could possibly get the bic f12 that i have heard tons about i couldnt find the rd12w that you had mentioned. if i bought the sub i couldnt spend anymore than the ascend 170se on speakers/$340.
post #19 of 23 Old 07-22-2013, 08:39 PM
wagnju's Avatar
Great speakers for the size and money + WAF approved . Start without a sub and decide for yourself if you need one .
Cambridge Audio S30 .
http://www.amazon.com/Cambridge-Audio-Speakers-Dark-Pair/dp/B004NDN9NK/ref=sr_1_1?ie=UTF8&qid=1374547006&sr=8-1&keywords=cambridge+audio+s30
wagnju is offline
post #20 of 23 Old 07-22-2013, 08:52 PM - Thread Starter
what would you guys say arx a1b vs cbm 170se or any other suggestion in the 300 price range so then i could buy a subwoofer
post #21 of 23 Old 07-22-2013, 11:11 PM
cel4145's Avatar
Quoted: 2655 Post(s)
Liked: 2985
See this thread where an AVS member compared the two: http://www.avsforum.com/t/1446006/ascend-acoustics-cbm-170-se-vs-arx-a1b
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #22 of 23 Old 07-23-2013, 12:11 PM - Thread Starter
have any of you heard the the wharfedale 10.2 or 10.1 how would those compare they are in my price range
post #23 of 23 Old 07-23-2013, 07:38 PM
newc33's Avatar
Quoted: 733 Post(s)
Liked: 914
If u search klipsch rd12w u should get plenty of results. The have it on new egg or Amazon as low 279 some times
denon x4100
JTR noesis 228s LCR
Quad PSA T18s!!!!!!
newc33 is offline
Reply Speakers
Sony Strdh720 7 1 Channel 3d Av Receiver , Ascend Acoustics Cbm 170 Se
