speaker mounts for SP-BS41-LR - AVS Forum | Home Theater Discussions And Reviews
Old 07-23-2013, 04:48 PM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
Planning to buy these speaker or BS21. Anybody have any suggestions on where to get the speaker mounts?
I dont want to spend more than 15 per mount.
I have looked at lot of them and did not like any of them. I like this one B-Tech BT77 so anything similar is fine.
I found some great stores when I bought faceplace for hometheater courtesy of the AVS.
jk_bama is offline
Old 07-23-2013, 08:13 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
Doubt you'll find that type of mount for what you want to pay except perhaps used. Those were/are also marketed as Pinpoint AM40 (believe they have discontinued selling theirs) and Videoescu side clamping mounts. You could also drill into the speaker cabinet for other options but get one sufficient to hold it in place for the weight of the speaker (and usually they lie about how much weight such other types of mounts will actually hold in place).
lovinthehd is offline
Old 07-24-2013, 09:37 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
how about getting some DIY .. get some plank and hang it on the stud. Maybe some braces.
jk_bama is offline
Pioneer Sp Bs41 Lr 130 Watt Rms 2 Way Speaker
