Yamaha soavo 1 VS B&W 683,OR B&W 684 - AVS Forum | Home Theater Discussions And Reviews
Old 07-24-2013, 02:16 AM - Thread Starter
khashram's Avatar
Im looking for some decent speakers, my options are :
1- yamaha soavo 1
2-B&W 683
3- B&W 684
They will be used for music listening and also HT
Please help me make the right choice
khashram is offline
Old 07-24-2013, 08:47 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Why those 3? Have you listened to them? I know nothing about the Yamaha's, but between the B&W's, I prefer the sound of the 684's. Pick what sounds best to you.
crn3371 is offline
Old 07-31-2013, 01:28 AM - Thread Starter
khashram's Avatar
I live in Jordan, unfortunately there are not much choices... the 684 is definitely better from the 683, so the comparison now is between Soavo and 684
khashram is offline
Old 08-20-2013, 12:38 AM
Isobaric's Avatar
Hi Kashram,
What amplifier are you using? I have listened to the Soavo models and did not like them at first, but after a few hundred hours they became one of my favourite all time speakers. B&W I find to be a bit mediocre for the price you end up paying. Nice but just a bit flat and lifeless.
Best I have heard the Soavos is on an A-S2000 and matching CD-S2000.
Isobaric is offline
Old 08-20-2013, 05:27 AM - Thread Starter
khashram's Avatar
Hey Isobaric,
I went with the B&W 683, their specs are as following:
Frequency range -6dB at 30Hz and 50kHz
Frequency response 38Hz - 22kHz ±3dB on reference axis
Dispersion Within 2dB of reference response
Horizontal: over 60º arc
Vertical: over 10º arc
Sensitivity 90dB spl (2.83V, 1m)
Harmonic distortion 2nd and 3rd harmonics (90dB, 1m)
<1% 90Hz - 22kHz
<0.5% 120Hz - 20kHz
Nominal impedance 8Ω (minimum 3.0Ω)
Crossover frequencies 350Hz, 4kHz
Recommended amplifier power 25W - 200W into 8Ω on unclipped programme
Max. recommended cable impedance
Im now looking for a decent Av receiver to handle them, any suggestions?
khashram is offline
Old 08-20-2013, 03:46 PM
Isobaric's Avatar
NAD T757 or if you are willing to go to it, T777.
They don't have all the bells and whistles but they sound incredible.
They can also be upgraded via cards do if you want something like 4k for example, you switch out a card but don't have to buy a new amp.
Cheers.
Isobaric is offline
