Bose Cinemate GSII Wall Mounts, UB-2 - AVS Forum | Home Theater Discussions And Reviews
Old 07-25-2013, 04:09 PM - Thread Starter
jjk454ss's Avatar
I picked up a couple wall mounts online for a Cinemate GSII, I received the Bose UB-2 Mounts, it looks like these are the wrong ones. I don't have the Cinemate here to just try, can anyone tell me if these mounts will work with the Cinemate GSII? Thanks
jjk454ss is offline
Old 07-26-2013, 01:59 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Yes they should work just fine.
jjk454ss likes this.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
Old 07-26-2013, 05:56 AM - Thread Starter
jjk454ss's Avatar
Thanks, I thought they might, but I couldn't find anywhere that said it would.
jjk454ss is offline
Old 07-26-2013, 05:49 PM - Thread Starter
jjk454ss's Avatar
Thanks again, they worked great:
jjk454ss is offline
Old 07-27-2013, 01:04 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Good! Glad it worked out for you.
