subwoofers; are two better than one - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-26-2013, 11:56 AM - Thread Starter
proshow123's Avatar
are two subwoofers better than one? is it better to have two smaller inexpensive units than one large unit?
proshow123 is offline
post #2 of 7 Old 07-26-2013, 12:15 PM
Mike Garrett's Avatar
Quoted: 7063 Post(s)
Liked: 4772
Two subs are better than one sub, because you can smooth out the bass response in the room better. Hard to say if two cheaper subs are better than one more expensive sub, because we could be talking about anything. In other words two $100 subs are not going to be better than one $1,000 sub. Just using money as an example.
mjgarrett100@gmail.com
Mike Garrett is offline
post #3 of 7 Old 07-26-2013, 12:19 PM - Thread Starter
proshow123's Avatar
great point..lets say 2 600 dollar 10 inch vs 1 1000 12 inch..maybe an episode or force five from goldenear
post #4 of 7 Old 07-26-2013, 01:42 PM
vardo's Avatar
Quoted: 56 Post(s)
Liked: 148
Two of these SVS SB-1000 would be great for a medium sized listening area.
http://www.svsound.com/subwoofers/sealed-box/sb-1000#.UfLd9hy2tvk
How large (cu ft) is your home theater/listening area? Also you might post your question in
the sub forum.
I don't know to much about the subs you are referring to.
vardo
vardo is offline
post #5 of 7 Old 07-26-2013, 02:56 PM
HAMP568's Avatar
Quoted: 22 Post(s)
Liked: 31
Shouldn't this be in the subwoofer part of the forum and not in speakers?
HAMP568 is offline
post #6 of 7 Old 07-26-2013, 03:15 PM
newc33's Avatar
Quoted: 957 Post(s)
Liked: 1235
Yes
1600 cubic foot sealed room! Samsung 8500 curved 4k
denon x4100
JTR noesis 228s LCR
Ascend acoustics cmt 340se side ss.
ascend acoustics cbm170se rear ss
Quad PSA T18s!!!!!!
newc33 is offline
post #7 of 7 Old 07-26-2013, 03:35 PM - Thread Starter
proshow123's Avatar
great will do that..did not notice a subwoofer forum thanks
Reply Speakers
