Need Satellite Speakers to Match Current Sub and Amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 07-28-2013, 01:47 PM - Thread Starter
icu222much's Avatar
My uncle donated his Onkyo Tx-SR707 amp and Yamaha YST-SW100 sub to me the other day. My current TV is set up in an enclosed 12'x12' square room. I am wondering what sort of satellite speakers I should purchase to accompany this setup. Is there anything in particular I should look for? I am looking for a 5.1 setup, so I need to purchase 4 more satellites.
icu222much is offline
post #2 of 12 Old 07-28-2013, 02:10 PM
ifor's Avatar
Quoted: 64 Post(s)
Liked: 72
For 5.1, you'll need 5 speakers for the center, left , right and surrounds. The sub is the .1.
Anything will work for you as long as all the speakers are matched so you will get the same sound from all of them.
ifor is offline
post #3 of 12 Old 07-28-2013, 05:59 PM - Thread Starter
icu222much's Avatar
Sorry, I meant 4.1 :P
How about quality? Shouldn't all the speakers be of the same tier? The sub seems to be quite a good sub, so would it be a waste to pair it up with lower tier sats?
ifor: what do you mean by: "as all the speakers are matched so you will get the same sound from all of them"?
post #4 of 12 Old 07-28-2013, 06:43 PM
ifor's Avatar
Quoted: 64 Post(s)
Liked: 72
What is your budget?
Any size constraints?
ifor is offline
post #5 of 12 Old 07-29-2013, 10:39 PM - Thread Starter
icu222much's Avatar
My budget would be under $500 for four speakers, and I don't have any size constraints. I am more worried about making sure the speakers I get are of the same grade as my sub so the sounds from my sub would sound significantly better then my satellites and become a bottleneck for my audio experience.
For example, lets say I purchase a really great top of the line computer to play video games on, but I have only 1GB of RAM. I wouldn't be able to get much gaming done with such little RAM. I am unfamiliar with audio speakers, but would I run into a case like this - especially since after reading the reviews for my sub that it is a high quality sub back when it came out.
post #6 of 12 Old 07-30-2013, 12:29 AM
ifor's Avatar
Quoted: 64 Post(s)
Liked: 72
So... you have a center already? Do they have to be bookshelves? Can they be towers?
ifor is offline
post #7 of 12 Old 07-30-2013, 09:24 AM
afrogt's Avatar
Quoted: 1414 Post(s)
Liked: 968
The Yamaha sub is not a high end sub so you don't have to worry about it outshining your speakers.
Where are you located? Can you have towers or bookshelf speakers?
Here are some good deals on towers.
http://www.accessories4less.com/make-a-store/item/BOSA250WHA/BOSTON-ACOUSTICS-A250-2-Way-Dual-5.25-Floor-Standing-Speaker-EA-White/1.html
http://www.bestbuy.com/site/Pioneer---5-1/4%26%2334%3B-Floor-Speaker-%28Each%29/5086937.p?id=1218610014331&skuId=5086937
There are lots of bookshelf speakers available that you could get for $250/pr.
Boston Acoustics A26 and A26
http://www.accessories4less.com/make-a-store/item/BOSA26GBA/BOSTON-ACOUSTICS-A26-2-Way-6.5in-Bookshelf-Speaker-Each-Gloss-Black/1.html
http://www.accessories4less.com/make-a-store/item/BOSA25GBA/BOSTON-ACOUSTICS-A25-2-Way-5.25in-Bookshelf-Speaker-Each-Gloss-Black/1.html
Polk RTiA1 and RTiA3
http://www.ebay.com/itm/RTiA1-BLACK-Bookshelf-Speakers-from-Polk-Audio-PAIR-/230951492914?pt=Speakers_Subwoofers&hash=item35c5c81d32
http://www.ebay.com/itm/RTiA3-BLACK-Bookshelf-Speakers-Polk-Audio-PAIR-/231017957013?pt=Speakers_Subwoofers&hash=item35c9be4695
You could actually use the RTiA3 for the fronts and RTiA1 for surrounds and still be right at $500.
Cambridge Audio S30
http://www.crutchfield.com/p_779S30N/Cambridge-Audio-S30-Noir.html
Since you said 4.1 does that mean you already have a center channel or that you don't want want one? If you already have a center you should get something that matches it.
Afro GT
afrogt is offline
post #8 of 12 Old 07-30-2013, 07:23 PM
ifor's Avatar
Quoted: 64 Post(s)
Liked: 72
lol, I was trying to be nice about his sub by not mentioning it.
ifor is offline
post #9 of 12 Old 07-31-2013, 09:17 PM - Thread Starter
icu222much's Avatar
That is great news that my sub is not a high end one. My uncle is very wealthy and loves his theater room, so I assumed he bought a really expensive sub. Now I feel much better about his present smile.gif
I live in Vancouver, Canada, and I would prefer to purchase something locally. Is there anything in particular when I am looking for a set of speakers? I can go for either tower or bookshelf speakers.
post #11 of 12 Old 08-05-2013, 09:10 AM - Thread Starter
icu222much's Avatar
I went to a few stores yesterday to listen to some speakers (including the ones mentioned above) and I had mixed advice. I was given different advice from several different sales rep:
Look for a heavy speaker as that means quality. Also check the connectors at the back as quality speakers would have bigger and more secure connectors
Since you have a Yamaha sub, you want Yamaha speakers to ensure you have the same quality of sound
Also, I believe my amp can only support 100 watt per channel (http://www.amazon.ca/electronics/dp/B002DSMNPC). Looking at the following speaker that was recommended to me, is this speaker compatible with my amp? The specs says it has a power capability of 200 watts?
http://www.bestbuy.ca/en-CA/product/precision-acoustics-precision-acoustics-tower-speakers-hd35t-black-two-speakers-hd35t/10212374.aspx?path=8ec7c7fae2914942b46808f67d848976en02&SearchPageIndex=1
post #12 of 12 Old 08-05-2013, 11:09 AM
afrogt's Avatar
Liked: 968
The 707 would have plenty of power for those speakers. Just because they can handle 200 watts doesn't mean you need 200w to drive them to acceptable levels.
My current speakers handle up to 250 watts and I'm driving them with a 50 watt per channel Harman Kardon or 75 watt Denon. Plenty of power for my needs.
Afro GT
afrogt is offline
Reply Speakers
Onkyo Tx Sr707 7 2 Channel A V Surround Home Theater Receiver , Yamaha Yst Fsw100 Subwoofer 75 Watt Black
