B&W CM Centre vs CM Centre 2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 07-31-2013, 02:12 PM - Thread Starter
shanewu's Avatar
I have a 52" space to install a TV and left front, center and right front speakers.
I am buying the Sharp 757u 80" LCD TV and that takes up 42" so now I'm left with about 10" for the center and maybe left and right if I want to put them under the TV instead of to the sides.
I am considering the B&W CM Centre and CM Centre 2 for all 3 speakers, but I haven't been able to demo either.
So now I'm curious and looking for input on how superior the CMC2 is to the CMC???
And is anyone on this forum using the CMC for LCR duties instead of just center?
My listening will be about 70% TV/movies and 30% music.
And I'm open to suggestions for any other 10" high and 12" deep speakers (not really concerned with width at this point).
Thanks for any input!
shanewu is offline
post #2 of 15 Old 08-01-2013, 11:46 AM - Thread Starter
shanewu's Avatar
Does anyone have any feedback at all on the CM Centre or CM Centre 2?
shanewu is offline
post #3 of 15 Old 08-01-2013, 08:39 PM
Brian B's Avatar
Quoted: 233 Post(s)
Liked: 101
I only clicked on this thread cuz I was curious to know what a CNC speaker was...you might want to edit your title. Yes, the 2 is much better than the smaller center. It is the difference of a 2-way vs. the 3-way with the FST mid.
B.
Brian B is offline
post #4 of 15 Old 08-01-2013, 10:47 PM - Thread Starter
shanewu's Avatar
Thanks, Brian. I took your advice.
shanewu is offline
post #5 of 15 Old 08-03-2013, 08:40 AM - Thread Starter
shanewu's Avatar
Is B&W not very popular around here?
shanewu is offline
post #6 of 15 Old 08-03-2013, 10:19 AM
deeda's Avatar
My sense is that B&W is perceived as good on this forum but not a great value. I have B&W in-ceiling and they perform well. I am looking at KEF R series for LCR duty. Still expensive but a better value than CM series IMO.
I would post your question on the dedicated B&W thread. You may get a better response.
deeda is offline
post #7 of 15 Old 08-03-2013, 10:53 AM
Geoff4RFC's Avatar
Quoted: 317 Post(s)
Liked: 1573
+ 1
Also, I've seen folks using three towers or three book shelves as an L/C/R but not three center speakers. That's not to say it can't be done smile.gif
Spinning the rear tire at 150mph while at 3/4 lean angle will put wrinkles in your seat
Set up:
Integra 70.4--Oppo 103--LG50"Plasma--Emotiva: XPA-3, XPA-2 x 2--PolkAudio: RTiA9 x 4--CSiA6--FXiA6 x 4--Epik: Empire x 2--XBOX 360--Furez 10awg homemade cables
Geoff4RFC is offline
post #8 of 15 Old 08-03-2013, 12:33 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
Intuition also tells me that three book shelf speakers or towers would work better than three MTM center speakers. I´m currently using three CM5s for front L/C/R in my bedroom system.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #9 of 15 Old 08-03-2013, 12:45 PM
Jay1's Avatar
Quoted: 236 Post(s)
Liked: 220
The CM Centre 2 is a WtmW design, with a 350hz crossover from the woofers to mid. It will work fine as a horizontal LCR.
A 350hz wavelength is 3.2 ft, both woofers are operating well under that distance from each other. Lobbing will be extremely minimal.
Jay1 is offline
post #10 of 15 Old 08-03-2013, 01:00 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
A few years ago I was in the market I was considering CM9s and did a lot of research. At that time I found the CMC2 was regarded quite well but the not so much the CMC. Would recommend the CMC2.
Main Kef: Reference 205/2 & 202/2c, Surrounds: Kef XQ40, Velodyne Optimum 12, Integra DHC 80.3, Ayre K-5xeMP, Oppo BDP-103, Bryston 4Bsst2, Parasound Halo A31. Second B&W: 685 (3), CCM618, Def Tech Powerfield 1500, Onkyo TX-NR1008, Zone 2 Klipsch AW650.
jima4a is offline
post #11 of 15 Old 08-03-2013, 01:03 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
I agree on all points. I had a Kef system but choose B&W ceilings as I believe they are the better speakers. Also concur on R series over CM. And you will get better response in the B&W thread.
jima4a is offline
post #12 of 15 Old 08-03-2013, 03:06 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
If I were setting up a music only system with just one or two seats (i.e. a narrow listening area) I would strongly consider the B&W CM series. But for a combination of HT and music I would recommend the KEF R series - same great detail/mid-range as the B&W's but to my ears the KEF's have better imaging with a wider soundstage. The B&W centers, again to my ears, have been a weak link in the B&W line for a long time, while the KEF Q and R centers are among the better horizontal centers I've heard (often wondered if it had something to do with the concentric tweeter/midrange driver ...).
That being said, of course I've heard a notable exception ... a friend has three B&W PM-1's LCR across the front (with CM5's as surrounds) and it sounds just plain amazing. Loads of fun to watch a movie at his place wink.gif
sdg4vfx is offline
post #13 of 15 Old 08-03-2013, 03:15 PM
jima4a's Avatar
Quoted: 275 Post(s)
Liked: 146
Run three LS50s or better yet five.
jima4a is offline
post #14 of 15 Old 08-03-2013, 05:05 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3074
post #15 of 15 Old 08-04-2013, 12:18 AM - Thread Starter
shanewu's Avatar
Once again, I thank you all for the info. I will look at KEF more and hop on over to the B&W thread.
shanewu is offline
Reply Speakers
