Newer martin logans? - AVS Forum | Home Theater Discussions And Reviews
Old 08-03-2013, 05:59 PM - Thread Starter
mrevo2u's Avatar
Quoted: 54 Post(s)
Anyone have any experience with newer (slimmer) ML's? Have some prodigy's that I love with my tube gear, but want something less intrusive for a small (15' x 20'). Do the on wall stats still have that big airy sound?
mrevo2u is offline
Old 08-03-2013, 06:42 PM
simp1yamazn's Avatar
Quoted: 110 Post(s)
Liked: 78
for the on-walls I'm guessing you are referring to the EFX? If so, I would be surprised if they aren't a fairly large step down from the prodigy that you have. The newer ML's are excellent but you really would need to look at the Montis or Summit X to keep in line with the same quality that you are coming from
simp1yamazn is offline
Old 11-02-2013, 08:24 PM
snyderkv's Avatar
Quoted: 185 Post(s)
Liked: 48
Yes the EFX on-wall stats would have that signature electrostatic sound. They have the same panel size as the ML Source but a slightly newer technology as it's the ESL series. I'm replacing my Spires with them which typically sell for $4000. I'm in the same boat as you, want something smaller but keep that electrostatic sound. Just get a really good sub like the new balanceforce which should have a custom filter for the EFX and I'm sure you won't miss your 20 year old 100lb dinos, they might even sound better overall.
snyderkv is offline
