First HT setup - using Polk OWM3's - AVS Forum
post #1 of 15 Old 08-03-2013, 06:09 PM - Thread Starter
Slade1's Avatar
I am looking to get my first HT system for my family room. I am considering the Polk OWM3's for 6 of the speakers, a Polk CS10 for the central, and the Polk PSW505 for the sub. The opening on my TV stand won't hold a standard sized receiver, so I am looking at a Marantz 1604. My family room is not that big - 15X13, but it is already wired for 7.1. Any thoughts on this system? I know tower or bookshelf speakers would be better for the L/R, but my wife doesn't want anything that big. I am also considering the OWM5's for the L/R, and just using the OWM3's as satellites, but the OWM5's are pretty big.
Slade1 is offline
post #2 of 15 Old 08-03-2013, 06:24 PM
67jason's Avatar
Quoted: 60 Post(s)
Liked: 777
The OWM series are ok and would make for good satellite surrounds, you will be really selling yourself short using them as mains. Ya gotta do whatever it is ya gotta do to convince the wife in the use of real mains. If you watch newegg you can get a pair of monitor 65's or 75's plus matching center for reasonable sale prices...or go for a set of the monitor bookshelf speakers.
I wish you luck in your endeavour.
Slade1 likes this.
I don't need snobs to tell me how to think, thank you!
LOL!
Why you wouldn't want to join this forum
67jason is online now
post #3 of 15 Old 08-03-2013, 06:32 PM - Thread Starter
Slade1's Avatar
thanks for the quick reply. What would be a good matching center?
Slade1 is offline
post #4 of 15 Old 08-03-2013, 06:35 PM
67jason's Avatar
Quoted: 60 Post(s)
Liked: 777
The 15c or 25c. The 15c works well with the bookshelf speakers in the monitor line and the 25c works well with the monitor towers.
Slade1 likes this.
LOL!
post #5 of 15 Old 08-03-2013, 07:39 PM - Thread Starter
Slade1's Avatar
Is there a big difference between the 15c and the cs10? or is it just that the 15c works better with the monitor line?
Slade1 is offline
post #6 of 15 Old 08-03-2013, 07:58 PM
67jason's Avatar
Quoted: 60 Post(s)
Liked: 777
The cs10 is a match for the tsi series. Differences are basically cosmetic, as the tsi series and monitor series are very very similar.the cs10 or 20 along with the older monitor cs1 or 2 can all be interchanged with virtually no ill effect.
Slade1 likes this.
LOL!
post #7 of 15 Old 08-03-2013, 08:06 PM - Thread Starter
Slade1's Avatar
That's good to know. Will the PSW505 sub work well with the front 3 if I go with the bookshelf speakers (monitor 45B's) and the 15C for the center? Thanks again for your help. I have been trying to research the last week or so, but there are so many different versions of speakers that it is a little overwhelming.
Slade1 is offline
post #8 of 15 Old 08-03-2013, 08:10 PM
postrokfan's Avatar
Liked: 293
The subwoofer doesn´t need to match the front 3. The PSW505 is a decent budget sub. However, I would check out the budget subwoofers thread here on AVS for other options (budget = $300 or less).
postrokfan is offline
post #9 of 15 Old 08-03-2013, 08:50 PM
67jason's Avatar
Quoted: 60 Post(s)
Liked: 777
^^ agreed, however if the budget for a sub is in the $200ish range the 505 is the sub to get in my opinion. With a budget in the $300ish range then klipsch has a fantastic sub. Over $500 then there are many excellent options from the likes of svs, hsu, psa, etc. Best to go to the subwoofer forum to learn more.
Slade1 likes this.
LOL!
post #10 of 15 Old 08-04-2013, 07:45 AM - Thread Starter
Slade1's Avatar
what is the Klipsch sub in the $300 range? I would like to stick with $200, but am willing to consider going up if it will be a noticeable difference.
Slade1 is offline
post #11 of 15 Old 08-04-2013, 07:47 AM - Thread Starter
Slade1's Avatar
i checked out the "budget subs" thread. Wow, that's a lot of choices. The PSW505 had really good reviews, it is a 12 in, the frequency range was below 30Hz, and it is only $200. That's why I was interested in that one, but I'm definitely willing to consider alternatives. I will mostly be using the setup for movies, video games, and TV with occasional music.
Slade1 is offline
post #12 of 15 Old 08-04-2013, 10:08 AM
cel4145's Avatar
Quoted: 78 Post(s)
Liked: 653
Your instincts are right. For $200, you won't do better than the PSW505. If you can go up to $300, the Klipsch RW-12d--when on special at Newegg--is the one to get. Here's the discussion thread for it: http://www.avsforum.com/t/1442829/klipsch-rw-12d-on-sale-for-299-at-newegg-com-again-today
You would appreciate the performance difference between the two when it comes to movies and gaming, and if you happen to listen to bass heavy genres like hip hop or EDM.
Slade1 likes this.
cel4145 is offline
post #13 of 15 Old 08-04-2013, 10:46 AM
postrokfan's Avatar
Liked: 293
I didn´t realize the budget for the sub was $200. For $200, the PSW505 absolutely makes sense. wink.gif
post #14 of 15 Old 08-04-2013, 10:57 AM
sdg4vfx's Avatar
Liked: 92
+1 ^^^
sdg4vfx is offline
post #15 of 15 Old 08-04-2013, 06:51 PM - Thread Starter
Slade1's Avatar
Thank you all for the ideas and info. I am still in the planning/saving stage, but I am hoping to get my system in the next few months. I will let you all know how it turns out. Since I'm only using the built in TV speakers right now, I think I"ll be pretty happy with anything though.
Slade1 is offline
Reply Speakers
User Tag List
