Speaker imaging, I'm just not hearing it - Page 3 - AVS Forum
post #61 of 84 Old 08-09-2013, 11:03 AM
Bill Fitzmaurice's Avatar
Liked: 1346
Originally Posted by datranz View Post
That may be why I was never impress with my kef xq midbass. I will try to move it a little further. Thanks
To paraphrase Roy Allison, speakers should be either very close to or very far from the wall in back of them. One benefit of in walls/flush mounting is that there is no Allison Effect when you do so.
Bill Fitzmaurice is offline
post #62 of 84 Old 08-09-2013, 11:43 AM
wattheF's Avatar
Quoted: 45 Post(s)
Liked: 126
My Def. Tech Promonitor 1000's definetly image well. I agree that some speakers do this better than others. Wouldn't the levl of clarity/detail a speaker provides affect imaging as well?
wattheF is offline
post #63 of 84 Old 08-09-2013, 01:53 PM
Liked: 1346
One of the best imaging speakers I ever heard were some $75 Sony 2-ways that I used as nearfield monitors in my home recording studio control room. I don't give the credit to the speakers, I give it to the almost anechoic response of the room.
post #64 of 84 Old 08-09-2013, 04:22 PM
NuSoardGraphite's Avatar
Quoted: 25 Post(s)
Liked: 110
I have mine about 8" from the wall (circumstances require it). Is that close enough, or should I move them further back?
Stand tall and shake the heavens...
NuSoardGraphite is offline
post #65 of 84 Old 08-09-2013, 06:37 PM
kiwi2's Avatar
Liked: 144
The problem for the OP though is that one speaker has a wall behind it and the other one virtually doesn't to one whole side of it. No acoustic symmetry - two speakers that will sound different from each other.
kiwi2 is offline
post #66 of 84 Old 08-09-2013, 07:11 PM
g_bartman's Avatar
Quoted: 34 Post(s)
Liked: 59
I believe imaging is about equal parts speaker and setup. I have been into audio for about 40 years. I have heard some good speakers that were improperly placed and sounded awful. I have also heard some speakers that were placed properly and did not image very well. I like having a sense that there is a live band or orchestra playing in my room. I currently use 6' tall dipolar ribbon speakers that are more sensitive to room placement than standard monopole speakers. I'd say I have them dialed in fairly well. I have had people over while playing 2 channel music and they are sure the vocals are coming from the center channel. Also sound coming from farther apart than the speakers are placed. Last but not least, a good recording makes a difference as well.
g_bartman is offline
post #67 of 84 Old 08-09-2013, 07:32 PM
Liked: 1346
I assume the back of the cab is 8" from the wall. If the cab is a foot deep that places the baffle 20" from the wall. 20" is 1/4 wavelength at 170Hz, so that's the center of the cancellation dip. If the baffle is a foot from the wall that's 1/4 wavelength at 280Hz. That will be a lot less noticeable than 170Hz or lower.
The alternative is to pull the speakers further away, putting the dip below their passband. That's a problem with towers that run full range. If you want to have the dip down at 35Hz the distance from the baffle to the wall would have to be 8 feet. But with a sub crossed at 80Hz and bookshelves on stands a four foot distance from the baffle to the wall puts the dip at 70Hz., below where the bookshelves function, while having the subs two feet from the wall places their dip at 140Hz, well above where they're working.
Another option with bookshelves is to make them true bookshelves, by placing them on shelves and surrounding them with books that come out to flush with the baffle, and then there's no dip.
post #68 of 84 Old 08-09-2013, 09:48 PM
datranz's Avatar
Quoted: 27 Post(s)
Liked: 30
When I up the speaker against the wall I loose that relax and spacious sound., kinda hard to explain. I pull the speaker out to about 6 feet from back wall, I get a more hallo graphic sound as apposite to against the wall. I can tell where the sound is coming from when against the wall. Sound field just collapse.
datranz is offline
post #69 of 84 Old 08-10-2013, 12:33 PM - Thread Starter
LowerFE's Avatar
Quoted: 14 Post(s)
Liked: 37
I got a chance to play with speaker placement for a bit today. I pulled the towers a lot closer to me, placed them farther apart from each other, and toe'd them in. I feel like I get a "bigger" sound, but it still sounded like music was playing through the two speakers.
I got an interesting issue where the left speaker sounded louder than the right speaker, even when calibrated by Audyssey. It wasn't my ears (at least I don't think) because when I turned around, I hear more from the right ear. It doesn't seem to be the speakers either because I swapped speakers and the left speaker stilll sounded louder. I only had about 2 hours to play, so I didn't get much done. I'll see if I can find time next week to play with it some more.
LowerFE is online now
post #70 of 84 Old 08-10-2013, 01:53 PM
WVSyd's Avatar
Liked: 42
LowerFE:
This has been my approach to improving "imaging"
Raise the ratio of Direct to Indirect Sound ( including addressing first reflection points ).
Using designs that minmize diffraction ( including non- rectilinear and Ovoid shaped cabs )
And Ultimately - Placing my drivers in-wall.
"Beware of Salesmen: They are the modern Svengali, immune to Science and Reality"
WVSyd is offline
post #71 of 84 Old 08-10-2013, 02:57 PM
losservatore's Avatar
Quoted: 194 Post(s)
Liked: 295
I used to own this speaker for about 2 years , toe then in,use the port plugs , place then as far as you can away from the back and side walls, I will said 2 feet away from back and side ,but that's if you can.
Panasonic 65VT60 / Marantz SR7005 / Marantz UD7007 /PSA XS30 /Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds/Sonos Connect/ Roku 3 / Amazon Fire tv / Xbox One / HTPC / Darbee 5000 /Sonos play:1 for bedrooms,kitchen,bathroom/Master bedroom Sonos sound bar/Sonos sub and Sonos play 1 surrounds.
losservatore is online now
post #72 of 84 Old 08-11-2013, 01:10 AM
Menasor's Avatar
Any way you can get rid of that closet cabinet to the right? Also get a rug between you and the speakers to get rid of a lot of sound deflection coming at you. I would use at least one of the port plugs. I like my RC70's a lot more with one port plugged. Plugging two kills the bass too much imo. I have mine 1 foot from the back wall and they sound great with slight toe in
[HT]
Energy RC-70 Rosenut
Energy RC-LCR Rosenut
Energy Veritas 1.0CM
SVS PC12-NSD
Pioneer SC-1522-K
[Desktop]
Emotiva Airmotiv 4
Sennheiser HD555 modded
To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
Menasor is offline
post #73 of 84 Old 08-21-2013, 08:14 AM - Thread Starter
LowerFE's Avatar
Quoted: 14 Post(s)
Liked: 37
I have played with my speakers some more today. I have achieved some sort of imaging with my Paradigm Mini Monitors, but not my Energy RC-70, even though they're in the same position.
On my Mini Monitors, there is a very small sweet spot where I can hear the vocals in the center (somewhat). That only happens when I'm directly in the center of the 2 speakers, and have my head nodding down. If I have my head in the normal position looking forward, I don't get that imaging.
I might just have to live with no stereo imaging until I move out in a year or so.
Thanks for everyone's help.
post #74 of 84 Old 08-21-2013, 08:39 AM
Liked: 1346
Originally Posted by LowerFE View Post
That only happens when I'm directly in the center of the 2 speakers.
That's the only place it will happen. For the left/right sources to combine into a source perceived as being central the L/R must be heard at very close to exactly the same volume and phase. That occurs over a small area. It's easy to do with headphones, since they're always at exactly the same volume and phase. But if you listen to phones and pull one ear cup even slightly away from your ear imaging will be lost.
post #75 of 84 Old 08-21-2013, 08:44 AM
flickhtguru's Avatar
Liked: 105
I have been reading this thread and also trying some of the advice posters have given. I tried 4 things with the front L&R speakers: 1) NO toe-in, 2) Toed-in with axis crossing 1' behind MLP, 3) Toed-in with axis crossing AT MLP, and 4) Toed-in with axis crossing 1' infront of MLP. For my speakers in my room they sound best toed-in with axis crossing 1' infront of MLP. This provides best stereo imaging at MLP and also on either side of the MLP, this due to the fact that even tho you move closer to one speaker it is angled away from you but the farther speaker is angled toward you. So even when I move 2 to 3' from the Center MLP the stereo image doesn't collapse to one side or the other. Also room is 15' W X 20' L X 8' H, speakers are kinda near the front corners but are 12" from side walls and 18" from front wall. Speakers are BIC Acoustech PL-89s so they have a horn loaded tweeter so maybe that is why I am getting these results.
Shawn
flickhtguru is offline
post #76 of 84 Old 05-13-2014, 10:20 PM - Thread Starter
LowerFE's Avatar
Quoted: 14 Post(s)
Liked: 37
Just to update the thread.
I have moved to a new room, and the new room has carpet floors and popcorn ceiling. In that room, with the speakers about 12 feet apart, I am getting imaging. If I sit at the sweet spot, I can hear fairly clearly that the voice is coming from the center. However, it seems the soundstage width is limited to the width of the speaker, and I can't really pinpoint the sound location from anywhere else besides the center. For example, in Bon Jovi songs, I hear the voice and the guitar coming from the same "location" in the soundstage. I expect to hear the voice and guitar in different locations.
The room is still not optimal. The right speaker is near a corner, while the left speaker's left side is a large opening which is the entrance to the living room from the other rooms. Also, Audyssey MultiEQ XT seems to mess up imaging, and leaving the receiver on pure direct gives a more pinpoint accurate image.
When I have time, I'll play with placements some more.
post #77 of 84 Old 05-13-2014, 11:24 PM
kiwi2's Avatar
Liked: 144
And how far are you sitting from them?
You need to achieve more symmetry.
kiwi2 is offline
post #78 of 84 Old 05-14-2014, 05:45 AM - Thread Starter
LowerFE's Avatar
Quoted: 14 Post(s)
Liked: 37
I'm sitting about 9 feet from the speakers.
What are you supposed to hear in pop music if you have proper imaging?
post #79 of 84 Old 05-14-2014, 06:15 AM
shivaji's Avatar
There is also the possiblitly that one or both of your speakers are wired incorrectly and could be out of phase. That will prevent a pair of speakers from imaging as they should. Make sure you have them wired correctly.
shivaji is offline
post #80 of 84 Old 05-16-2014, 01:54 PM
kiwi2's Avatar
Liked: 144
They may be a little too far apart then. The general going rule is that you are sitting at the same distance away from the speakers as they are apart from each other so you form an equilateral triangle. Personally I like the speakers slightly wider apart, so if I was sitting 9 feet away then I would probably have them 10 feet apart.
A lot of pop music is poorly recorded so that stuff will be a very mixed bag. I like a lot of jazz and folk and live recorded music and such. Soundstaging for me means the music being detached from the speaker rather than sounding like everything is coming from the speakers. Imaging as wide as the room I am in yet at the same time each individual instrument and vocal is tightly defined in its own space. For example the main vocalist in the centre of the stage needs to sound about the same size as if they were standing in the room in front of me. If their head sounds like it is 6 feet wide then something isn't right and I haven't got good enough of what is technically known as 'localisation'.
kiwi2 is offline
post #81 of 84 Old 05-17-2014, 02:17 PM
RayGuy's Avatar
Quoted: 79 Post(s)
Liked: 77
That is an excellent point. You'll never get a good image if the speakers are out of phase. I also agree with another poster that the speakers are probably too far apart. Also, the speaker itself may not be that good at imaging. Some are much better than others. Lastly, there is the room. It may require treatments to get the full benefit from the speakers.
RayGuy is offline
post #82 of 84 Old 05-18-2014, 11:37 AM - Thread Starter
LowerFE's Avatar
Quoted: 14 Post(s)
Liked: 37
I played around some more, and I just can't get good imaging with Audyssey on. I have even tried hooking up both left and right channel to the left channel in an attempt to get Audyssey to apply the same EQ to both speakers (I like Dynamic EQ), but I just never got it to work.
Right now I have Audyssey off, and there is a solid centre image. It is a lot better than with Audyssey on, where even though the vocals do sound like it is coming from the centre, it is kinda faint, and I still hear some sound coming from the speakers. Now the vocals sound like it is coming completely in the centre.
I'm listening to more music, and most of the songs sound like the vocal and instrument is coming from the same center location. The only song I heard where this didn't happen is the live version of Hotel California. Is that how most songs are like?
I don't listen to much jazz or classical, so I can't really try them out for imaging
post #83 of 84 Old 05-20-2014, 01:26 AM
RayGuy's Avatar
Quoted: 79 Post(s)
Liked: 77
Jazz and classical probably benefit the most from good imaging. Sounds to me like you are trying to get an elephant to tap dance ....
RayGuy is offline
post #84 of 84 Old 05-20-2014, 10:58 AM
FMW
FMW's Avatar
Quoted: 266 Post(s)
Liked: 710
More likely he is being confused by the thread itself. OP, imaging is defined as the placement of sound sources within a sound field. Imaging is created at the mixing console using the pan controls. These controls determine how much of the content of each track is heard from the left and right channels. Speakers don't have "imaging" as a performance parameter. They reproduce whatever imaging was mixed into the final recording. They may do this well or badly depending primarily on their placement and the acoustics of the listening room. If a clearly stereo recording arrives at your ears as a monaural or nearly monaural soundfield then the problem is not with the speakers themselves. It is probably due to reflections and/or cancellations arising from speaker placement and acoustics. Borrow a recording with clear imaging and play in on your system. Then fuss with placement to see if you can improve the quality of the sound field. If not, then work on room acoustics. Blaming it on the speakers isn't going to help anything. Good luck.
FMW is online now
Reply Speakers
Energy Rc 70 Floorstanding Speaker Black Ash Veneer
User Tag List
