Rear surround positioning, various compromised options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 08-13-2013, 03:04 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Hi all,
I have a set of Klipsch KPT-100 to use as rear surrounds in a room that is not ideal. The rear wall has a door where I would ideally put one of the speakers.
Here's my first option, with speakers close together (the cardboard cutouts show speaker locations on the wall).
  • Speakers are likely spaced too close from each other and are not symmetric with the center.
  • The sweet spot isn't so badly located but the second row seating would have a speaker directly behind a seat, off to the center.
Here's my second. Here, the KPT-100 would be mounted on wedges to angle them inward toward the sweet spot of the first row.
  • The speakers are 11 feet part.
  • On the plus side, they are completely out of the walk way.
  • The second row would get a wide dispersion, but nobody would be too close to a speaker.
The last option would be to place the KPT-100 sideways, using their slanted shape to partially angle the sound toward the seats. I would not build a wedge in this case. The speaker on the left would be mounted flush to the wall,and would intrude a bit into the door molding. Doesn't bother me. The right speaker would have to be mounted about 3/4" off the wall using a cabinet mounting wedge since I don't have access to the wall behind it (concrete). I suppose I could use a similar spacer on the left for symmetry (and let the speaker float over the door molding).
Here's what the left side (looking to the back) would look like with the side surround fairly close.
...and the left side. Notice that the surround speaker on this side is farther away. The room layout is symmetrical on the front but the back wall is shorter so I have less space on the left side (and thus the need for the inset surround speaker).
I am leaning towards the last option, but am open to ideas and discussion.
Peter
psgcdn is offline
post #2 of 15 Old 08-13-2013, 03:40 PM
Fastslappy's Avatar
Liked: 749
# 1 fair & balanced across the room
#2 but spaced them wider( the one to the other corner ) & move the DVD rack to somewhere else speakers take the best spot > shelves lower order on the totem pole
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #3 of 15 Old 08-13-2013, 03:52 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Originally Posted by Fastslappy View Post
# 1 fair & balanced
Thanks for the input, but... #1 isn't balanced because the speakers are not centered (the projector is on center).
#2 as shown is centered on the projector and seats.
psgcdn is offline
post #4 of 15 Old 08-13-2013, 04:15 PM
Rhetor's Avatar
Liked: 230
I the three options, I like option 3 of your scenarios best, especially since they will be aimed in toward the center of your seating. Always thought if I ever used those speakers for surrounds (and did not have a perfectly symmetrical rear wall--which I don't) that I would do something similar, to push the sounds to the center.
You have a tough choice to make.
It is all about compromises for most of us, isn't it?
I love deadlines. I like the whooshing sound they make as they fly by! --Douglas Adams
Rhetor is offline
post #5 of 15 Old 08-13-2013, 04:35 PM
Mike Garrett's Avatar
Quoted: 5568 Post(s)
Liked: 3550
I would go with number two and toe them in. Rather than mount flat on the wall, I would look into a ceiling mount so that the speaker could be angled in. Something like this: http://www.parts-express.com/pe/showdetl.cfm?partnumber=248-8598
mjgarrett100@gmail.com
Mike Garrett is online now
post #6 of 15 Old 08-13-2013, 04:35 PM
Fastslappy's Avatar
Liked: 749
w
i didn't notice the center was the pj
with that in mind then 3
Mike
post #7 of 15 Old 08-13-2013, 04:54 PM
Fastslappy's Avatar
Liked: 749
Really you should try ALL of them & then decide
Mike
post #8 of 15 Old 08-13-2013, 06:52 PM
Mongo171's Avatar
Quoted: 828 Post(s)
Liked: 1251
I would lean towards something like Option #2. You don't want the rears to be too close to the sides.
"I am a Meat Popsicle." - Korben Dallas, "The Fifth Element"
Mongo171 is offline
post #9 of 15 Old 08-13-2013, 08:54 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Suggested on the Klipsch forum:
http://www.thx.com/consumer/home-entertainment/home-theater/surround-sound-speaker-set-up/
The above link suggests:
  • THX specs rear speakers close together, so a modified #1 with the right speaker closer to the projector, in symmetry with the other rear.
  • Dolby® TrueHD or DTS-HD Master Audio specs a 60 degrees spread between rear speakers, which is just about what #2 or #3 give.
psgcdn is offline
post #10 of 15 Old 08-14-2013, 07:08 AM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Here's a sketch of the room layout to give you a better idea of the geometry associated with the options.
psgcdn is offline
post #11 of 15 Old 08-14-2013, 11:43 AM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Further info... The front wall is 20 feet wide. The right side surround is about 7 feet from the back wall (where options #2 and #3 would place the rear right surround).
This link suggests that options #2 or #3 are best:
http://www.dolby.com/us/en/consumer/setup/connection-guide/home-theater-speaker-guide/index.html
psgcdn is offline
post #12 of 15 Old 08-15-2013, 06:47 PM
cjrccjrc's Avatar
Assuming that THX geeks have done their homework properly, option #1 with SBL "shoulder to shoulder" to SBR would probably be the best solution. It's simple, symmetrical, a bit unusual (so there's a lot to talk about around a beer) and... you can complain to the pros if it doesn't work as expected! ;-)
http://www.thx.com/files/2009/12/7-1-speaker-setup-400x300.jpg
cjrccjrc is offline
post #13 of 15 Old 08-15-2013, 09:13 PM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Honestly, I find it weird that THX says one thing and Dolby says another. I may try #3 for a while and see how that goes.
From the same site as your link (Dolby® TrueHD or DTS-HD Master Audio™ Set Up):
(I would have said welcome to the forum but I see that you've been lurking for two years!)
psgcdn is offline
post #14 of 15 Old 08-15-2013, 09:42 PM
gregzoll's Avatar
Liked: 33
My living room is roughly about the same length. This is how I dealt with my rears, where our couch is. I have them at about 57" for the tweeter height, 8" on center from the edge of the wall on the left of the speaker, to the center of the speaker, on those RB-41 II's. Because of the wall at the Dining room/Living Room, could not go with the RS-42 II's, so went with the RB 41's. The sound footprint actually stays within the living room area, and does not spill out into the dining, so it stays tight and does pack the sound punch that I wanted, when I designed my layout.
As for the THX & Dolby setup guides, they are just that, not to be taken as the bible. You have to just do trial and error, to find the best positioning for how your room is setup, along with where your seating is in line with the rears. You really do not want them so high, that you have to tilt them so far downwards, that it defeats the purpose. But then again, you do not want them too low, where you have to tilt them up, or they are where they can be easily damaged by people leaning against the wall at those points.
Always easier to start with a clean room, put in the furniture where the seating area will be, then bring in the equipment and speakers, then any extras like dvd racks, but not where it overloads the room, that it muddles up the sound.
gregzoll is offline
post #15 of 15 Old 08-19-2013, 07:14 AM - Thread Starter
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Well, option #3 it was... Watching GI Joe tonight so I'll let you know how it goes. So far I have only switched from 5.1 to 7.1 on one scene of the latest Batman and liked what I heard.
I mounted them pretty flush, without using the bracket provided.
Next on my list:
  • Patch hole left by previous center speaker.
  • order in-wall wire and hide those new wires.
  • hang suspended ceiling (painted brown; same color as moldings.
  • build a mini stage for back row before new furniture arrives
psgcdn is offline
Reply Speakers
