Need Help with Klipsch Synergy F1 Speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-14-2013, 01:59 AM - Thread Starter
bowmah's Avatar
So I have an old A/V receiver and sub already. Just wanted some low cost speakers to play some music in the bedroom and only need speakers now. Just found a set of Klipsch F1's for $45 / pair. Don't know much about Klipsch speakers but for the bedroom, I don't care that much about the speakers. Just something decent will do. The heavy lifting for movies and music is already set up in the living room.
http://www.klipsch.com/f-1-floorstanding-speaker
Can anyone read the specs and tell me how these are? For $45, I can't go wrong right?
Will these cones need to be refoamed in the future or did Klipsch use some polymer so it's not foam surrounds?
Need to make a quick decision. At this price, someone is probably going to snatch it up fast.
bowmah is offline
post #2 of 8 Old 08-14-2013, 02:11 AM
Bond 007's Avatar
Quoted: 2373 Post(s)
Liked: 1910
That is a great deal. The F1s are fine speakers. Grab em.
The surround is not foam. It is butyl rubber and will last a long time.
Licence to Kill
Bond 007 is offline
post #3 of 8 Old 08-14-2013, 02:14 AM - Thread Starter
bowmah's Avatar
ok great. Thanks for the info. I was able to dig up IMG = Injection Molded Graphite. Apparently based on a review site, the IMG woofer has woofer rubber surrounds so perfect. Let's see if the guy jacks up his price tomorrow and what the condition the speakers are in.
I assume when I listen before buying I will want to make sure I hear sound coming from the horn and woofer by placing ear right up to each component of each speaker? Is that the best way to test?
bowmah is offline
post #4 of 8 Old 08-14-2013, 02:37 AM
Bond 007's Avatar
Liked: 1910
Yes
Licence to Kill
Bond 007 is offline
post #5 of 8 Old 08-14-2013, 03:22 AM - Thread Starter
bowmah's Avatar
Alrighty. Thank you!
bowmah is offline
post #6 of 8 Old 08-14-2013, 05:19 PM - Thread Starter
bowmah's Avatar
Seller turned out to be too shaddy. Seems like a scammer. The search goes on.
bowmah is offline
post #7 of 8 Old 08-14-2013, 07:21 PM
Bond 007's Avatar
Liked: 1910
Figures. That did kinda sound too good to be true. Good luck.
Licence to Kill
Bond 007 is offline
post #8 of 8 Old 08-18-2013, 12:35 AM - Thread Starter
bowmah's Avatar
I bought another set for $60. Care to share some thoughts?
http://www.avsforum.com/t/1486569/bought-acoustic-profile-psl-88-6-need-feedback
bowmah is offline
Reply Speakers
