speaker questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-15-2013, 09:51 AM - Thread Starter
velocci's Avatar
Quoted: 117 Post(s)
Hi all, i'm researching speakers and have a couple of questions:
1. a pair of paradigm speakers says suitable amp power range is 15-150watts. but the maximum input power is 90watts. what does this mean? what's the difference?
2. are the paradigm Mini Monitor and Atom Monitor good speakers?
www.johnvelocci.com
system: Onkyo TX-NR 646 AVR with Polk Audio RtiA3 fronts and
BIC America F12 sub
velocci is offline
post #2 of 5 Old 08-15-2013, 10:00 AM
Bill Fitzmaurice's Avatar
Liked: 4628
If you have a 150w amp don't turn it all the way up.
Bill Fitzmaurice is online now
post #3 of 5 Old 08-15-2013, 10:04 AM
flickhtguru's Avatar
Liked: 110
For wattage it is worded that way because if you are going to listen at loud volume levels it is better to have an amp/receiver that is more powerful than what the speakers say they handle. The reason is if the amp/receiver is pushed too hard to achieve the volume level you desire it will start to clip ( distort the sound and the signal) which is actually more damaging to speakers than slightly over powering them for short periods of time. Plus most receivers may say they are rated at 130 watts/channel, but if you look closely at the specs that's with only 2 channels being driven. Most good receivers only put out 70-90 watts per channel with all channels driven.
Yes they are pretty good speakers, but what does that mean? Speakers are so subjective its really all about what you think sounds good and how it sounds in your room.
Shawn
flickhtguru is offline
post #4 of 5 Old 08-15-2013, 10:36 AM - Thread Starter
velocci's Avatar
Quoted: 117 Post(s)
sorry I don't quite understand this. if the suitable amp power is 15-150 watts, then why is the maximum input only 90? shouldn't the max be 150 since 15-150 is suitable?
as for the way companies rate their receivers, all they say is XXX watts per channel. if they don't say only 2 channels were driven, are we to assume its all of them?
www.johnvelocci.com
BIC America F12 sub
velocci is offline
post #5 of 5 Old 08-15-2013, 12:45 PM
cel4145's Avatar
Quoted: 2654 Post(s)
Liked: 2984
That's the problem. Neither speaker manufacturers nor receiver manufacturers are very consistent with how they list wattage specs. And they sometimes exaggerate their specs. If you want to get an idea on how wildly different actual performance can be vs. stated receiver specs, read through the measurements pages for some of the receiver reviews listed at hometheater.com and compare them with stated specs (listed on another page of each review): http://www.hometheater.com/category/av-receiver-reviews
You are probably worrying about this a little too much. See those numbers from the speaker manufacturer as very rough specs that you could use to compare against speakers with significantly less or significantly more wattage rating. And then speakers which have lower RMS or continuous power ratings (50 watts to 75 watts) might not be a good choice if you buy an expensive receiver that is rated at 100 or more watts per channel. In other words, use the ratings as rough guides for comparison.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is online now
Reply Speakers
