Klipsch RW-12d 12 and new CC question. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-15-2013, 01:07 PM - Thread Starter
Are-Jay's Avatar
Q #1. Will a Klipsch RW-12d 12 work in a room that is 32'l x 28' w x 20'h. The room also opens into the kitchen that is about 700sqf or so. The sub will next to the sofa.
Q #2. I need a CC that can be mounted under my hearth that is 6” deep and 60" long. I was looking at Definitive Technology Mythos three CC because its only 4.3" deep but I am worried that it will not be powerful enough. Are there any other slim CC that you would recommend?
Are-Jay is offline
post #2 of 2 Old 08-18-2013, 03:38 AM
vivatech's Avatar
That Klipsch will work in any room. It's not going to be that powerful though to shake that size of a room.
Take a look at the Def Tech RLS II or RLS III. I'm building the RLS III into my mantel. It's only 3-7/8" deep and sounds better than a Mythos. Requires something to put it into however.
vivatech is offline
Reply Speakers
Klipsch Rw 12d 12 Subwoofer Each
