PLEASE help with in-ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-18-2013, 11:38 AM - Thread Starter
Tonka24's Avatar
Unfortunately, I must use in-ceilings speakers for a 5.1 set up. I have attempted to do as must research as possible and have come up with a few options:
Triad Bronze LCR's in front
or
ML Vanquish for a center and 2 EM-r's for the LR
either set up with cheaper rear surrounds
Need help with a matching sub. Currently considering:
SVS sb12-nsd
SVS sb13-ultra
SVS pb12
SVS pb12 ultra
HSU ULS 15
HSU VTF-15H
Sub will by placed on the left rear side firing toward the listening area
System will be the main home system for HT and everyday use. 75% HT 25% music
Currently running with Denon 3808 but may upgrade
Open to all suggestions.
15x27 with wall to wall windows on one 27' foot side and 2 openings to kitchen and dining on the other with a fireplace where the TV will be placed over
All suggestions greatly appreciated!
Tonka24 is offline
post #2 of 6 Old 08-18-2013, 08:33 PM - Thread Starter
Tonka24's Avatar
Anyone?
Tonka24 is offline
post #3 of 6 Old 08-18-2013, 09:23 PM
BobL's Avatar
Liked: 56
I don't have an opinion on the martin logans as I haven't hear the Vanquish or EM-r's but they do not look to angle that much and they do not appear to be enclosed speakers.  I'd go for the Triad system or one that has an enclosure and angles at least 30 degrees.  Speakers need to aim at you to get the best performance.
BobL is offline
post #4 of 6 Old 08-19-2013, 01:18 PM
platoon2063's Avatar
If you must use in-ceiling speakers.....I would be looking for those that are angled by at least 30 degrees as mentioned. Revel makes some nice in-ceiling speakers but I'm not sure of the angle. You might look at the Definitive Technology RCS line as well.
platoon2063 is offline
post #5 of 6 Old 08-19-2013, 05:38 PM
vardo's Avatar
Quoted: 41 Post(s)
Liked: 130
Take a look at Speaker Craft with angling (pivoting) 8" woofer and tweeter.
http://www.designeraudiovideo.com/speakercraft-aim8-one.html?gclid=CLCmmKnWirkCFWho7AodOlwARQ
vardo
vardo is offline
post #6 of 6 Old 08-19-2013, 07:00 PM
BobL's Avatar
Liked: 56
Speaker craft only angles 15 degrees.  They aim more down then towards the listener unless sitting very close to them.
BobL is offline
Reply Speakers
In Ceiling Speakers
