Subwoofer for Bowers and Wilkings 686 (BW 686B) book shelf speakers? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-18-2013, 09:01 PM - Thread Starter
zeeoo7's Avatar
I'm in a 1 bed room apartment. living room size 14x22.
My setup Sony 55" Class (54.6" diag.) BRAVIA HX800, PS3, Comcast DVR. But no receiver or speakers.
I bought a Pioneer SC-71 (Open Box with all accessories included) for $499 in Best Buy.
I also bought a pair of B&W 686 speakers. I want to start with a 2.1 system to begin with since I am in a small apartment.
I don't want to spend too much on a subwoofer right now as the bookshelf speakers have some decent bass to get by until I can spend more.
Also, I am planning to bi-amp the BWs so that will impove the sound quality more. BB did a demo of the bi-amp and it sounded great (without subwoofer).
Can anyone suggest a good subwoofer to match the BW 686? Under $200?
Zee
Sony Bravia HX800 55" 240Hz 3D LCD EdgeLit LED
Pioneer Elite SC-71 Receiver
PS4 and PS3 Slim (with 3D Blue Ray player)
Comcast Cable Xfinity X1 DVR (Panasonic HD-DVR)
Bowers & Wilkins 686B Book Shelf Speakers (Front L and R)
BIC America F-12 12" Subwoofer
zeeoo7 is offline
post #2 of 8 Old 08-18-2013, 10:14 PM
postrokfan's Avatar
Quoted: 520 Post(s)
Liked: 3093
You don´t really need to ¨match¨ the subwoofer to your front speakers as such. I would check out the budget subwoofers thread in the Subwoofer forum for ideas since your budget is on the low side. Some models to consider would be the Polk SW505 and the Dayton SUB-1200.
Living Room: B&W 804D, B&W CMC S2, B&W ASW610, Yamaha RX-A2030, Rotel RC-1570, Rotel RB-1582 mkii, Oppo BDP-93, ATV.
postrokfan is offline
post #3 of 8 Old 08-26-2013, 03:09 PM - Thread Starter
zeeoo7's Avatar
I'm going to get BIC America F12 from Amazon.
http://www.amazon.com/gp/product/B0015A8Y5M/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
I need help choosing the sub-woofer cable. I bought speaker cables from Sewell Directo for my Front and Left speakers. They don't seem to have much subwoofer cable collection.
Here are the cables I am trying to decide on.
Mediabridge cable that is suggested together with BIC F12 in Amazon.
http://www.amazon.com/Monster-Standard-THX-Certified-Subwoofer-Interconnect/dp/B00006RHZG/ref=sr_1_7?s=electronics&ie=UTF8&qid=1377547195&sr=1-7&keywords=subwoofer+cable
Monster Standard THX Certfieid
Belkin
http://www.amazon.com/Belkin-PureAV-Subwoofer-Audio-Cable/dp/B0001XGR1C/ref=cm_cr_pr_product_top
Monoprice
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023603&p_id=6306&seq=1&format=2
MediaBridge has good reviews. But the bad reviews mostly complain about the connectors being too tight to plug-in (which is also listed as one of the Pro's giving tight fit).
Belkin - Most bad reviews list a hummmm with this cable. Not sure if it's cable related or just their equipment.
zeeoo7 is offline
post #4 of 8 Old 08-26-2013, 03:24 PM
tsaville's Avatar
Quoted: 163 Post(s)
Liked: 299
Mediabridge makes low-cost, high quality cables. I personally have a subwoofer cable and several micro USB cables from Mediabridge. All of them are very well-constructed; no need to pay more for a "name brand" cable.
tsaville is offline
post #5 of 8 Old 08-26-2013, 03:29 PM - Thread Starter
zeeoo7's Avatar
Thanks. Yes. I'm not looking for name brand. Just looking at the reviews irrespective of the brand.
BTW, I have a MediaBridge HDMI cable that I have used to connect my Sony HX800 55" to PS3 for 3D movies and had no issues.
zeeoo7 is offline
post #6 of 8 Old 08-26-2013, 05:23 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I'm a big fan of Monoprice. Can't beat their prices.
crn3371 is offline
post #7 of 8 Old 08-26-2013, 07:56 PM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 164
Biamping is a bunch of nonsense. If you thought you heard a difference then either your ears were fooling you, or BB was doing something shady to make it sound different.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #8 of 8 Old 08-26-2013, 08:15 PM
darthray's Avatar
Quoted: 941 Post(s)
Liked: 897
+1 on that and I would also look at the offering from Blue Jeans Cables.
Ray
darthray is offline
Reply Speakers
