A Little Off Topic... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-20-2013, 02:26 PM - Thread Starter
spyboy's Avatar
Liked: 47
Guys
What do you use to "staple" your speaker wire? For example wiring surround speakers.
TIA
spyboy is offline
post #2 of 3 Old 08-20-2013, 02:42 PM
Ozzie Isaac's Avatar
Liked: 101
I use the nailed clips you use for 12-2 and then use zip ties. I zip tie the speaker wire to the clip. Makes it easier to adjust things.
Ozzie Isaac is offline
post #3 of 3 Old 08-22-2013, 11:21 AM - Thread Starter
spyboy's Avatar
Liked: 47
Thanks Ozzie.
No one uses the kind of staple gun that cable tv installers use?
spyboy is offline
Reply Speakers
