SPEAKER CALIBRATION - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-21-2013, 06:33 AM - Thread Starter
Robinst's Avatar
Hi this is robin i bought new sony blu ray home theater system bdv E290 2 months before they came for installation also but still iam not satisfied i want to set the exact volume level for all the speakers . i dont have auto speaker calibration setup .In manual calibration the volume level +- 6db for all the speakers.i dont know how to use spl meter.kindly send me the exact speaker level volume for each speaker in db.
i installed smart tools spl meter andriod application for my galaxy note but values displayed in that app is from 0 to 120 db how can i convert it for 6db.
Then i analyzed all the speaker it shows 30 db So what is my speaker level . And tell me the exact level for my woofer out of 6db please
MY Sitting position towards front left,right center,Woofer is about 3.5 m and rear speakers is about 1.6m
PLEASE HELP !!!!!
Robinst is offline
post #2 of 2 Old 08-21-2013, 07:37 AM
xFreshEntrailsX's Avatar
Quoted: 60 Post(s)
Liked: 392
Its preference .. adjust them to the level where you like the way it sounds.. there isn't any 1 level that all systems are set at .. and with your system being an HTiB .. its very limited on what it can do as far as Calibration .. Listen to a movie and adjust each channel as you are watching it .. Thats all you can do ..
Onkyo TX-NR929, QSC GX5, Polk Audio RtiA9's, CsiA6, F/XiA6's, RtiA3's,PSA xs30se, Xbox 360, PS3, hopper w/Sling, Samsung 55" LED, All controlled with a Harmony One
xFreshEntrailsX is offline
Reply Speakers
