Suggested rears for an extremely tight budget - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 08-21-2013, 09:07 AM - Thread Starter
DaveMN's Avatar
Liked: 24
I've got very little disposable income because of a recent divorce. Even though money is tight, I'd like to get a pair of rear speakers for my 5.1 setup. Is there something that will give me the best bang for my buck in the $100 range? And yes, I'm talking about $100 for the PAIR. :-)
I'm looking at something that can sit on a shelf or possibly be mounted on a wall. Not looking for in-wall or in-ceiling.
My fronts are the Axiom M60s
My center is the Axion VP150
DaveMN is offline
post #2 of 12 Old 08-21-2013, 09:34 AM
jdcrox's Avatar
Quoted: 78 Post(s)
Liked: 102
Dayton B652's from Parts Express. I think they are $51 for the pair right now. They are pretty amazing speakers for the price.
jdcrox is offline
post #3 of 12 Old 08-21-2013, 11:25 AM - Thread Starter
DaveMN's Avatar
Liked: 24
Did a little digging on these. It sounds like the earlier version was great, but a newer version is crap:
http://www.reddit.com/r/audiophile/comments/1bckzx/stop_buying_the_dayton_b652s/
DaveMN is offline
post #4 of 12 Old 08-21-2013, 12:12 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Is there a size limitation?
What about Polk OWM3? They can be wall mounted or sit on a shelf.
http://www.amazon.com/Polk-Audio--Wall-Speaker-Black/dp/B0018QNYVM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1377108635&sr=1-1&keywords=polk+owm3
Afro GT
afrogt is offline
post #5 of 12 Old 08-21-2013, 12:20 PM - Thread Starter
DaveMN's Avatar
Liked: 24
No size limitation. Those Polks look promising- thanks!
DaveMN is offline
post #6 of 12 Old 08-21-2013, 01:05 PM
KidHorn's Avatar
Quoted: 1374 Post(s)
Liked: 877
I own a pair of the polks. I use them for heights. I got them for $69 from newegg about a year ago. They aren't very good speakers and I would never recommend them for anything but surrounds, but for the money, they're hard to beat.
KidHorn is offline
post #7 of 12 Old 08-21-2013, 01:41 PM
StevePMo's Avatar
Pioneer BS 22 is on sale at best buy for $90 per pair now. Highly rated for the price.
DaveMN likes this.
StevePMo is offline
post #8 of 12 Old 08-21-2013, 01:44 PM
SanchoPanza's Avatar
Quoted: 197 Post(s)
Liked: 511
Your local Craig's List has lots: set of 5 Quintet speakers for $90...
just 1 more pair of KLIPSCH Classic speakers...
RED AND BLUE=MAROON!
PANASONIC 60" PLASMA 3D, DENON AVR-3312CI, LG BD670 3D NETWORK BRD (iPhone APPs), TOSHIBA HD-XA2 HD DVD, SAMSUNG BD-UP5000 HD DVD/BRD, iPod 8 GB, 13.2: KLIPSCH La Scala 1980 (Crites Rebuilt Type AA Crossovers Sonicaps) FRONT, HERESY II "SIGNATURE EDITION" WIDE, HERESY II CENTER/SURROUND, kg2 SB, kg3/kg1 Front/Rear HEIGHT, RW-12d SW, km-rsw
SanchoPanza is offline
post #9 of 12 Old 08-21-2013, 01:55 PM
LastButNotLeast's Avatar
Quoted: 1471 Post(s)
Liked: 1066
newegg has the previous BS 21 for $80.
Or get the bigger BS 41 for $100.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=pioneer+bookshelf&N=-1&isNodeId=1
See, lots of options!
Good luck.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #10 of 12 Old 08-21-2013, 02:11 PM - Thread Starter
DaveMN's Avatar
Liked: 24
I went with the Pioneer BS22s at Best Buy for $90. I had some reward points to use, so after tax I got the pair for $86. They're $127 on Amazon. Looks like these won't mount on the wall, so I'll have to figure something else out. Thanks all for your suggestions!
SanchoPanza likes this.
DaveMN is offline
post #11 of 12 Old 08-21-2013, 02:34 PM
m9610172's Avatar
Quoted: 29 Post(s)
You can try this wall mount.
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI/ref=sr_1_2?ie=UTF8&qid=1377117142&sr=8-2&keywords=speaker+wall+mount
Well on second thought, you might not want to spend $35 on $90 speakers. smile.gif
- LG 70UH6350, Onkyo 646, Energy RC-70, RC-LCR, RC-10 & V-mini (FH), 2 x DIY Subs (Micro Marty), Fire TV, HTPC, Outdoor Antenna
- Panny 65PS64 Plasma, Pioneer VSX-1018, Energy Micro 5.0, Outlaw LFM-EX, Xbox One/360, WiiU, PS2
- Onkyo TX-8255, Infinity Primus P163
m9610172 is offline
post #12 of 12 Old 08-21-2013, 02:54 PM
toddbigeasy's Avatar
yea, but the mounts will adjust to upgrades! I have those mounts myself.
toddbigeasy is offline
Reply Speakers
