Speaker problems - Polk RTI 10s - AVS Forum | Home Theater Discussions And Reviews
Old 08-23-2013, 04:06 PM - Thread Starter
iduhfuse's Avatar
Quoted: 12 Post(s)
So I have a pair of Polk RTI 10s hooked up to a pioneer VSX 823k receiver. Does 80watts rms per channel and max output is 140 watts. I was playing some pretty bass heavy music yesterday and the bass wasn't really there unless I turned my polk sub on. So, I looked at the woofers on the Polks and while playing some bass heavy songs, the woofers didn't seem to move much, unlike the midrange above it which was whacking back and forth. Any idea if this is a problem or just needs some serious juice to get them going. - Thanks
iduhfuse is offline
Old 08-23-2013, 04:37 PM
nb67's Avatar
Quoted: 39 Post(s)
Liked: 38
What's your crossover set at?
nb67 is offline
Old 08-23-2013, 04:39 PM - Thread Starter
iduhfuse's Avatar
Quoted: 12 Post(s)
100hz
iduhfuse is offline
Old 08-23-2013, 05:17 PM
Menasor's Avatar
Quoted: 20 Post(s)
Wait, you had the speakers crossed at 100hz and you had the sub off? You wouldn't hear much bass because all of that information is going to the sub, which is off. What happens when you play your RTi 10's full range on their own? Also 100hz is a really high crossover point for them. 80hz is probably as high as you should go
Vizio M75-C1
Ascend Sierra-1
Ascend Sierra-1 Center
Ascend HTM-200 SE
SVS PC12-NSD
Pioneer SC-1522-K
Menasor is offline
Old 08-23-2013, 07:20 PM
Bill Fitzmaurice's Avatar
Liked: 4631
Since the sub is the source of the bass, why is that surprising? confused.gif
Bill Fitzmaurice is online now
Old 08-24-2013, 12:21 PM - Thread Starter
iduhfuse's Avatar
Quoted: 12 Post(s)
Yes but, shouldn't these speakers be able to reproduce some of that bass? Like its goes all the way down to 25hz! (or is supposed to)
iduhfuse is offline
Old 08-24-2013, 12:38 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Tell your avr it has no sub connected to it and your speakers will play all the bass they are capable of.
Lower your crossover and your speakers will play more of the bass frequencies in the source material.
Set your crossover and enable your avrs double bass feature, which will allow your speakers to play the full range signal and your sub to play bass frequencies below your set crossover. This can have negative cancellation effects and is not usually recommended.
Simply cutting the power to your sub without telling the avr that it is not in use will eliminate bass below your crossover setting.
iduhfuse likes this.
I don't need snobs to tell me how to think, thank you!
67jason is offline
