Good solution? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 08-23-2013, 11:16 PM - Thread Starter
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 361
So I am currently using the sony ht-ct260 sound bar but am not to thrilled with the sound quality. The reason why I initially got a sound bar was because of the limited space I have. The location for speakers is 5" tall and 55" wide. I was wondering if I could get two polk tl3 center speakers and use them as left and right speakers with a psw111 for a 2.1 system instead of using the sound bar. Would this be a good solution? Or could you recommend better speakers for the price? I chose the tl3 because the tweeter is mounted higher than the mids, which is supposed to be better then the in-line tweeter location on most center speakers. Also, I love the sound of ring radiator tweeters.
*UFO* is offline
post #2 of 8 Old 08-24-2013, 05:56 AM
myoda's Avatar
Liked: 57
Here's a suggestion for you - you're at $400 for two tl3 - for $439, you can pick up 2 Polk tsi300 floor standing speakers, and a CS10 center:
http://www.amazon.com/Polk-Audio-FloorStanding-Speakers-Channel/dp/B00DT41PTE/ref=sr_1_96?s=electronics&ie=UTF8&qid=1377345134&sr=1-96
Do you have a receiver to power the speakers?
myoda is offline
post #3 of 8 Old 08-24-2013, 08:38 AM - Thread Starter
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 361
While I would love tower speakers, they just wont work. The tallest the speaker can be is 5" frown.gif
*UFO* is offline
post #4 of 8 Old 08-24-2013, 08:48 AM
Bill Fitzmaurice's Avatar
Liked: 4629
That's very limiting. I'd look at getting rid of whatever is causing that restriction.
Bill Fitzmaurice is offline
post #5 of 8 Old 08-24-2013, 09:48 AM - Thread Starter
*UFO*'s Avatar
Quoted: 465 Post(s)
Liked: 361
Is there a problem with using center channel speakers as L/R?
*UFO* is offline
post #6 of 8 Old 08-24-2013, 10:40 AM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
Unless you can do something about your 5" x 55" requirement (very restrictive), you might as well stick with a soundbar.
crn3371 is offline
post #7 of 8 Old 08-24-2013, 12:57 PM
Liked: 4629
There's a problem with using center channel speakers as centers if the drivers are placed side by side, ie., comb filtering and narrowed midrange dispersion. If you must have a horizontal speaker because a vertical speaker won't fit it's a necessary compromise. You should avoid making the same compromise with the L/R.
post #8 of 8 Old 08-24-2013, 04:01 PM
sdg4vfx's Avatar
Quoted: 81 Post(s)
Liked: 140
Your 5" height limitation is tough.
One (obvious) option is to get the best soundbar you can afford.
Another option is the Cambridge Audio Minx speakers (you'd want the 11/21 series over the 10/20 series). There is a dedicated thread here in the forum. Three of them are less expensive than a higher end soundbar and I'm guessing they would sound better, or at least as good. (Their dynamics and imaging are unusually good for such small speakers in that price range - very desirable qualities for HT listening.)
For both options a very, very good subwoofer - esp. one with lots of detail/accuracy in it's mid and upper ranges - would be a must since you'll have a higher than average (120 vs 80) crossover.
An example would be the SVS SB12-NSD or PB12-NSD. The SB version is uncommonly small for it's output while the PB version is bigger and a bit louder, but both have superb detail and would work great with small LCR speakers. In that price range there are several ID brand subs that would work well ... those are just two that I'm familiar with.
sdg4vfx is offline
Reply Speakers
