choices choices choices - AVS Forum | Home Theater Discussions And Reviews
Old 08-24-2013, 03:31 AM - Thread Starter
SDB553's Avatar
ok, i currently have Sony STR-DG820 7.1 AVR coupled with klipsch quintet 5 speaker system and a Klipsch RPW10. Sounds good, or at least it used to. Since moving to my new apartment, I suppose the dimensions in the living/dining area are a little bigger, combined with higher ceilings and faux hard wood floors means that, for some reason, when the audio source is regular audio, it plays fine, but when a dolby digital 5.1 signal comes across, it's hard to hear. Basically, if I play a movie from my roku box via amazon instant video or vudu, the sounds and dialogue are hard to hear, but if i play classical music from the Abacus.fm app from the roku, it sounds great.
im assuming that the speakers I have, when played with a surround sound signal are just not big enough to produce enough volume or SPL in this apartment. As such, I now have a Yamaha RX-V871 arriving next week, and am now looking at speakers to go with it.
Today, after looking at and going to frys, i picked up a pair of the Infinity P363's. While in the store, I also auditioned some polk speakers. I believe they were the TSX330's, but dont remember. I called frys and he said he thought they were the Tsi550's. of the 3 polk speakers they had set up in that one room, they were the smallest of the bunch, but the cabinets were not "square", they had a curved cabinet, tapering from large to small from front to back, this is why i think they were the TSX330s and not the TSI550's.
Anyway, i got the 363's because of the price, $214/pr. However, due to the whole thing on ohm ratings, im concerned. I know some say not to worry about it and it makes sense as there are not any reviews of people losing their AVRs because of them. However, the 363's are not bi-ampable, and im wondering if im going to regret that, if bi-amp is something that one would definately want. I must say though, the polks did sound good, better than the 363's i would say, but they were also $199 each, making them $200 more for the pairs.
Ive also been considering BIC, HTD, HSU, Axiom, KEF and on ebay, there is a pair of RTi8 polks for like $399 (new speakers direct from polk, i think the rti8's are no longer made as their website lists only rti5, rti7, and rti9). There is also a user with a listing of Paradigm monitor 11 v2 for $500 which i would consider.
anyway, i would think in houston, there would be a ton of stores that i could go to, to audition speakers, but apparently, there's not. Aside from Modia and one other store that I cant remember the name of, seems like the big box stores are it (frys, BB). I wish I could actually hear Axiom, BIC, HTD, and HSU, but i cant. That leaves me with the major brands like Klipsch, paradigm (which for the decent speakers (reference line and monitor 9's and up, are going to be too expensive for me unless i can find some good used or factory refurbished), as well as martin logan, which again, for anything decent, will be too expensive.
so, now that i have the infinity speakers in my posession, yet still unopened, would i be making a mistake by keeping them and not taking them back and getting the polk txs330's? also, are there anyone that has any experience with BIC, HTD, and HSU that could tell me where those brands fall as far as sound and quality comparing them to the polks, 363's, or paradigm monitor 9's (i owned a pair of these years ago, and remember them sounding pretty good)
thanks and i apologize for being so long winded.
SDB553 is offline
Old 08-24-2013, 08:56 AM
m_vanmeter's Avatar
TSx330 towers would probably not be "better" than your Infinity Primus 363's - more or less a "lateral to downward move" (PS: you got a fantastic price on the pair ! )
http://www.polkaudio.com/products/tsx330t
http://infinitysystems.com/product-detail-11657/p363bk.html
I think you are referring to "bi-wiring" instead of "bi-amping" the speakers. Bi-amping speakers means a separate amplifier for the woofer speaker and one for the mid and tweeter. Unless you are willing to spend many thousands more on electronics and speakers I really think you will never notice any improvements by "bi-wiring" the equipment you have. The lack of double input connectors is NOT an issue on the Infinities.
I have a Klipsch 12" sub and am very satisfied with it, but if I had to choose a powered subwoofer just from specs, I would go with Hsu Research.
Don't fall into the trap of second guessing your purchases to date, hook them up and enjoy the magic. You will get the upgrade virus soon enough, but enjoy what you have and establish a base for what like. You can always make a "home theater poor" friend or relative VERY happy when you pass the Primus p363's down to them.
Make sure you match the p363 towers with an Infinity Primus PC351 center speaker.
m_vanmeter is offline
Old 08-24-2013, 11:00 AM - Thread Starter
SDB553's Avatar
thanks, you are right, i always second guess things like this. for the price im going to pay, i think ill just stick with what i got, and after i get this system built, what I may do is just start researching speakers and start buying a new setup but do it one speaker at a time, that way i can get into a higher quality set. It may take several months to complete the higher end set, but, it would allow me to it more affordably.
thanks for the input on bi wire vs bi amp. i always thought bi amp was taking the SBL and SBR wires, and changing the AVR config to "bi amp" and running those wires to the front speakers in a 5.1 setting, essentially taking the power from the amp circuitry of those channels and routing them to the front speakers.
SDB553 is offline
Old 08-24-2013, 11:05 AM - Thread Starter
SDB553's Avatar
also, im curious about speaker wire. right now, i have the speaker wire running from the AVR to the fronts and the surrounds are running around the edge of the room to the rears. it's not going under the floor or through the walls and ceiling. It is currently 16guage rocketfish wire i picked up from best buy. would i be doing myself a favor changing that out to 12 or 14 guage wire?
SDB553 is offline
Old 08-24-2013, 11:17 AM
losservatore's Avatar
Quoted: 2300 Post(s)
Liked: 2047
Don't buy cables at best buy the majority of people here buy speaker cables at http://www.monoprice.com/ you will save a lot of money.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
Old 08-24-2013, 11:38 AM - Thread Starter
SDB553's Avatar
will do from now on smile.gif but for now, will the 16 guage wire be thick enough or do I need to move up to 14 or 12?
SDB553 is offline
Old 08-25-2013, 07:25 AM
m_vanmeter's Avatar
My "personal minimum" wire gauge is 14 ga. for general speaker wiring.....12 ga. only where the wire run length requires it.
And yes, Monoprice is a very good source for wiring and cables of all sorts. www.parts-express.com is also a good source for wiring
This is probably the best internet reference to wire http://www.roger-russell.com/wire.htm
and to wire sizing based on impedance and run length http://www.roger-russell.com/wire.htm#wiretable
It's worth the effort to go back up-site to learn something about Mr. Russell's technical background.
Old 08-25-2013, 07:40 AM
FMW
FMW's Avatar
Quoted: 1652 Post(s)
Liked: 1681
My personal maximum wire gauge is 16 but I don't do any long runs. I ran 18 gauge under the wood floor in my family room when I installed it for the surround speakers. The run is about 15 feet. No problems at all. 18 gauge should suffice for most installations I think. I don't know why I use 16 gauge for the front speakers. Just the old "better safe than sorry" routine, I guess. In short, you will be fine with what you have.
FMW is offline
Old 08-25-2013, 02:02 PM - Thread Starter
SDB553's Avatar
well, i went ahead and just got all 12AWG wire. ive read several threads on this topic and everyone says that going 12 guage isnt going to hurt anything, basically, just get 12 guage and be done with it.
i have my surrounds that each is roughly a 35 to 40 foot run, fronts are only 3 or 4 feet and center is about 3 feet.
shouldnt be a problem, right?
SDB553 is offline
Old 08-25-2013, 03:11 PM - Thread Starter
SDB553's Avatar
now i have to find a good deal on the infinity PC351 center channel speaker. anyone know of a good place for deals? A4L doesnt sell them, neither does frys, Amazon about the only place i know that has them other than directly from the website, or ebay. Ebay has 2 for sale, but they are just as much as the original price.
SDB553 is offline
Old 08-25-2013, 04:46 PM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 107
How about Crutchfield?
Salk STRT / SongCtr-RT / SongSurr I ; Rythmik F12 (x2) (latest ver of my setup guide) ; Denon 4520CI; D-Sonic M2-800S; Oppo BDP93; Panny 65VT50; BJCables; NAS DLNA; Chromecast; Harmony One; Furman Elite-15 PFi; Omnimic & REW; CalMAN 5 HT i1D3 & i1Pro2 ::Headphones:: RPi3 w/Digi+ > AGD DAC19 > Cavalli LC > HFM HE400i & Meze 99 Classics :: CCA > Schiit Bifrost 4490 > Schiit Valhalla > Senn HD600 & HD6XX :: FooB2K > Schiit Modi2U > Schiit Magni2U > Oppo PM3
laulau is offline
Old 08-25-2013, 06:07 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
How about Crutchfield:
http://www.crutchfield.com/app/product/search/searchresults.aspx?SearchTab=Shop&us=2&search=primus
bladerunner6 is offline
Old 08-25-2013, 06:24 PM
laulau's Avatar
Quoted: 77 Post(s)
Liked: 107
Since the OP asked about the PC351, I provided a link to the PC351.
laulau is offline
Old 08-25-2013, 06:39 PM
Quoted: 20 Post(s)
Liked: 59
The point is, I just saw highlighted blue and did not notice it was a link.
In others, the point is, Whoops!
My apologies for my oversight.
