Klipsch RF-7II main w/RF-82II *OR* RC-64II for Center ???? - AVS Forum | Home Theater Discussions And Reviews
Old 08-24-2013, 05:42 AM - Thread Starter
rms8's Avatar
Quoted: 445 Post(s)
Liked: 284
Hi All!
Planning on purchasing the Klipsch RF-7II for the Main L&R speakers in our HT (construction due to start soon). I am trying to figure out which way to go for the Center channel. I was thinking about just going with another RF-7II, but the would put the top of the RF-7 just under the screen (10' wide 16x9). If I did this, I would not be able to go to a larger screen if I ever had the urge to do so. The RF-82II would give me that extra bit of room to expand if need be in the future. The RC-64II would obviously not impose ANY limits on the size of the screen I would want to change to in the future.
(just FYI, no plans to do a pref screen)
Any opinions on going with the 82 vs 64 ? Going with the 82 would be MUCH cheaper too vs. the 64 and have better bass response (according the the Klipsch specs).
Rob
*DIY ConcreteBunker Rustic Dream Build w/11' screen, 11.2chnl, 8x18" IB subs, 28.8KW*
GR Research LS-9 + LS-C | Denon AVR-4520 11.2 | Sony VPL-HW55ES | DaLite 11' screen | Sanway FP-14000 & FP-10000Q | Sherbourn PA 7-350 | Behringer iNuke NU1000DSP | 8x IB318's | Buttkicker Original(2x), LFE(2x), MiniLFE(8x) | MinDSP 2x4 | 21'W x 27'L x 10'H | MiniSplit
rms8 is offline
Old 08-24-2013, 06:10 AM
Zen Traveler's Avatar
Quoted: 493 Post(s)
Liked: 514
Get the RF-64II because it was voice-matched to the RF-7IIs and has a larger/better compression driver for the horn than the RF-82IIs. Fwiw, if you are going to be using a Subwoofer you are going to be sending the low end there anyway...The build quality on the RC-64II is also going to be better and was made in Hope, Arkansas along with the RF-7IIs.
Zen Traveler is offline
Old 08-25-2013, 04:34 AM - Thread Starter
rms8's Avatar
Quoted: 445 Post(s)
Liked: 284
Yes, sub for sure (8x Fi-318's :-) )
Thanks for the input!!
rms8 is offline
Old 08-25-2013, 05:46 AM
Martycool007's Avatar
Quoted: 280 Post(s)
Liked: 175
Actually the RF-82ii is a much better center channel than the 64ii. There are all sorts of advantages of the 82ii over the 64ii, as it is always better to not use a horizontal center when possible. The 82ii would be voiced the same as the RF-7ii, and would have less lobbing, and create a much fuller, and expansive sound stage compared to the 64ii. I can think of zero advantages of the 64ii. Of course an RF-7ii for the center channel would be the best choice, but the 82ii would be the next best thing.
Martycool007 is offline
Old 08-25-2013, 06:50 AM
Quoted: 493 Post(s)
Liked: 514
Originally Posted by Martycool007 View Post
Actually the RF-82ii is a much better center channel than the 64ii. .
I agree about having a 3rd RF-7II being the best choice, but the RF-82II was not voice-matched to the RF-7II as the RC-64II was. If the OP wants to confirm this he should call Klipsch CS, post the question in the Klipsch Forum, or ask this question in the Klipsch Owners Thread here on AVS.
Old 10-09-2013, 07:09 PM
BitChin2's Avatar
I just purchased the RF-7ii for mains and RC-64ii for center from Sound Distributors (good price on b stock that has no issues other than wrong color - which I liked better:))
Just listening to music so far but these speakers sound very good together.  I am looking to add RF-82ii for wide's as I figured out my receiver will cover 11.2
SanchoPanza likes this.
BitChin2 is offline
Old 02-05-2014, 10:11 AM
retro124's Avatar
Quoted: 906 Post(s)
Liked: 668
Talking about voice matching is there any for RF-82II and RC-62II for surrounds ? Can I go with RS-62II or RS-52II?
Denon X4000
Klipsch RF-7II's, RC-64II, RB-81II's, RS-62II's, RS-52II's (soon for sale (maybe) :-)
SVS 2x PC12-Pluses
Sony XBR65X850B
Emotiva XPA-200 , Oppo 103D
Apple Mac mini, Sony PS3
retro124 is online now
Old 02-05-2014, 12:45 PM
Kini62's Avatar
Quoted: 1109 Post(s)
Liked: 1020
All the Reference speakers below the 7/64 are voice matched and "can" be intermixed at will with good results. Best results would be to match the horn size, RF62/82, RC62 or RS62 etc...
Mine are all mixed sizes and in multichannel music I hear no difference at all. Very well matched.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is online now
Old 02-13-2014, 01:02 AM
Robbiey60's Avatar
Quoted: 424 Post(s)
Liked: 517
the guys on the klipsch thread say rs62ii are better matched with rf7ii, and rs52ii with rf82ii.
(2)RF-83 (1)RC-64ii (2)RF-82ii (2)RC-62ii
(2)Exodus audio tempest-x 15" subs in 200l sealed enclosures
Onkyo 705 pre/pro and rear surrounds
DSPeaker Antimode 8033 sub eq Behringer EP4000 subs
NAD C275BEE mains
AMC 2N100-3 surrounds and center
Robbiey60 is offline
Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Black Each , Klipsch Rc 64 Ii Reference Series Center Channel Loudspeaker Cherry , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Black , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Cherry , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker , Klipsch Rf 7 Ii Reference Series Flagship Floorstanding Speaker , Klipsch Rf 7 Ii Reference Series Floorstanding Loudspeaker Pair Black , Klipsch Rf 7 Ii Reference Series Floorstanding Loudspeaker Pair Cherry , Klipsch Rf 82 Ii Reference Series Floorstanding Loudspeaker Pair Black , Klipsch Rf7ii Reference Ii Flagship Floorstanding Speaker Black B Stock , Klipsch Rf 7 Ii Reference Series Ii Flagship Floorstanding Speaker Cherry B Stock
