PA speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-24-2013, 10:59 PM - Thread Starter
snickerpop's Avatar
My Frat is looking for new PA speakers for our basement. The main goal is music and loudness at the highest quality possible.
Budget is 300
snickerpop is offline
post #2 of 3 Old 08-25-2013, 07:48 AM
m_vanmeter's Avatar
Parts-Express is a good place to start your search
http://www.parts-express.com/cat/pa-speakers-live-sound-reinforcement/194
m_vanmeter is offline
post #3 of 3 Old 08-25-2013, 05:43 PM
skyline513's Avatar
Quoted: 30 Post(s)
Budget is 300
You're going to have a pretty hard time finding a good set of loud, GOOD SOUNDING, PA speakers for $300. You'll need an amp too, unless you plan on purchasing powered speakers which are even more expensive.
For an okay set of powered speakers, you're looking at, at least $350-400 per speaker. A good set of speakers will run you about $600 and up per speaker. A great set of DJ speakers will run you easily over $1000 per speaker. And don't forget the sub if you want one. That's another $500-600 for a decent powered one.
That being said, if you end up raising your budget, I'm a huge fan of almost all speakers that Mackie makes. JBL is also a very popular pro audio brand, although I don't enjoy how many of their speakers sound as much.
Main System: 55'' Sony W630D, Martin Logan LX16s, Martin Logan Dynamo 300, Marantz NR1403
Desk System: Cambridge Audio S30s, Yamaha RX-V471
skyline513 is offline
Reply Speakers
