Woofer size when using a sub? - AVS Forum | Home Theater Discussions And Reviews
Old 08-26-2013, 01:16 PM - Thread Starter
mcarbo's Avatar
Quoted: 42 Post(s)
Is there an advantage to an 8" woofer over a 6.5" when using a sub? I'm leaning towards an Acoustech PL-76 but am concerned about the woofer size. I also have a PL200 as a sub. I'm replacing an old set of Klipsch 5.5 monsters with 2 10" woofers. Klipsch is too big for the room and a little harsh at times with music. I was told when I called BIC that the Acoustech horn is warmer sounding than a Klipsch. So all that's left is to figure out which size wink.gif
mcarbo is offline
Old 08-26-2013, 02:05 PM
Petden's Avatar
Liked: 33
Going to larger drivers can have various benefits not all of which are geared towards bass extension. Larger drivers can have lower distortion at the same frequency due to the fact that it displaces more air more easily. Also larger drivers can be made to have slighly higher sensitivity while maintaining similar extension.
Petden is offline
Old 08-26-2013, 02:22 PM - Thread Starter
mcarbo's Avatar
Quoted: 42 Post(s)
Any thoughts on the difference in tone between the horns?
mcarbo is offline
Old 08-26-2013, 02:51 PM
Bill Fitzmaurice's Avatar
Liked: 4630
That depends on the crossover frequency from the woofer to the tweeter. I wouldn't take an eight higher than 2kHz., above that it will beam.
A better question is why get a tower that goes to 30Hz if you're not going to run it below 80Hz? A 2 x 6.5 bookshelf will work just as well in the frequency range you're using for.
Bill Fitzmaurice is offline
Old 08-26-2013, 04:57 PM - Thread Starter
mcarbo's Avatar
Quoted: 42 Post(s)
I keep bouncing between the PL horn series and the DV dome. I just want to be sure that I get clear highs and the full range of sound. As far as the horn comment from BIC, that's what I was expecting to hear from them. I have the DV62si bookshelf but it's missing "something." That's why I'm leaning towards the tower.
mcarbo is offline
Old 08-26-2013, 05:50 PM
Liked: 4630
Old 08-26-2013, 06:04 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Probably not, as long as the crossover is high enough, 60 Hz or higher.
arnyk is offline
Old 08-26-2013, 06:05 PM - Thread Starter
mcarbo's Avatar
Quoted: 42 Post(s)
You don't know unless you try. I tried... Still looking and trying to get as much information as possible about different speakers.
mcarbo is offline
Old 08-27-2013, 02:11 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
If by try, you mean listening tests in your listening room, that's not always the case. Of all kinds of speakers, subwoofers are the most likely to be accurately predictable from the right technical information.
Live and learn!
arnyk is offline
Old 08-27-2013, 08:40 AM
TwoPlusone's Avatar
A 2 x 6.5 bookshelf will work just as well in the frequency range you can have a try.tongue.gif65pFOd
TwoPlusone is offline
Old 08-27-2013, 09:00 PM
Dave1027's Avatar
Quoted: 12 Post(s)
I I have the DV62si bookshelf but it's missing "something." .
The DV62si, in it's stock form has little warmth. It's tonally imbalanced. I think BIC purposely made them that way for two reasons, one to work as a surround and two, so it would not compete with the more expensive offerings.
BIC DV62si speaker mod for warm musical sound. PM me for info.
Dave1027 is offline
