Replace Klipsch Reference for Palladium...Worth the upgrade? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 37 Old 08-26-2013, 03:34 PM - Thread Starter
MV_Cinema's Avatar
Hi
I have the following setup:
- (2) RF-7II (Front)
- (1) RC-64II (Center)
- (2) RF-82II (Back Surrounds)
- (1) SW-115 (Subwoofer)
And i am thinking on upgrade to this setup:
- (2) P-37F Floorstanding Speakers
- (1) P-27C Center Channel Speaker
- (2) P-27S Surround Speakers
- (2) P-312W Subwoofer
or,
The THX Ultra 2 Setup 5.2
I have a 20 Square Meter Home Theater, it's small, but i expect even more detail from the Palladium...or the THX Ultra 2 Set.
I use the SC-LX90 as Amplifier and soon it will work as a Pre/Pro and will add a Parasound A51 + A21.
MV_Cinema is offline
post #2 of 37 Old 08-26-2013, 03:44 PM
shadyJ's Avatar
Quoted: 1330 Post(s)
Liked: 1350
The THX have better measurements than the Palladium. The Palladium look nicer. I think they would both sound great. I think the THX Ultra set would have better subwoofers. If I were stuck on Klipsch, I would go for some Klipschorns over any of those.
shadyJ is offline
post #3 of 37 Old 08-26-2013, 03:52 PM - Thread Starter
MV_Cinema's Avatar
It's going to be 100% for Home Theater, i don't hear much music.
WHat do you mean klipschhorns?
Anyway the THX ones and the Palladium will sound even better than my setup right?
It crossed my mind to give a try on B&W CM10 and all the CM setup, but Klipsch will be much better for cinema.
post #4 of 37 Old 08-26-2013, 04:38 PM
airgas1998's Avatar
Quoted: 101 Post(s)
Liked: 147
la scala
Habit Forming....Wallet Burning Hobby....55" Oled Lg B6p 55" Samsung B8500 Fald Channel Master Dvr+ Onkyo RZ900 avr Samsung K8500 UBR player Svs Ultra Towers/Center, Svs Satellite Surrounds Svs Pb-13 Ultra Sub
airgas1998 is offline
post #5 of 37 Old 08-26-2013, 04:43 PM
Reference_head's Avatar
Quoted: 142 Post(s)
Liked: 730
The Palladium would be but not so sure on the thx. I think that would be close. I would pass on the Palladium sub and get something better for less money.
Klipsch Pro Cinema KPT-904 L/C/R, Pro Cinema KPT-1201-T2 for sides and Heresy II for backs.
SVS PB13-Ultra, PB12-Plus x2, and Velodyne SMS-1 Sub EQ
SC-55 elite and B&K 200.7 S2
JVC RS-45 Projector, and Seymour CS 125” 2.35 screen
Oppo BDP-103 9 ATS Acoustic panels
Reference_head is offline
post #6 of 37 Old 08-26-2013, 04:44 PM
Quoted: 142 Post(s)
Liked: 730
what don't you like about your current set up? Or what are you trying to improve on?
post #7 of 37 Old 08-26-2013, 05:34 PM
shadyJ's Avatar
Liked: 1350
Behold the mighty Klipschorn! Note these need room corners to really work in, so you have to have the right kind of room for them. They are just an awesome speaker. The set I heard blew me away. Heard them in the same room as some RF-83s and they blew away the RF-83s, no contest. La Scalas would be great too.
They are rather expensive speakers though, the Khorns are $9k per pair, the La Scalas are $7k.
Pi speakers make great Klipsch heritage type speakers which actually measure very well, and are a great less expensive alternative. Check out the Pi Fours, a set of those with upgraded drivers would be a killer system. They have corner horns too, like the Klipschorn, check out the Pi Seven. That thing would be amazing, expensive but not nearly as much as Klipschorns. I wouldn't be surprised if they exceeded the performance of true Klipschorns.
shadyJ is offline
post #8 of 37 Old 08-27-2013, 10:25 AM - Thread Starter
MV_Cinema's Avatar
I love my current setup. but i am moving my setup to a dedicated division of the house, and i have the possibility o buy the THX Ultra or Palladium and trade mines.
After i talked to the dealer he says my system will improve if i buy the THX Ultra 2 series.
Just wondering if i should buy the 2 subs from the THX series or buy 2 SVS PB-13 Ultra....rolleyes.gif
The Palladium is becoming an option far away after i talked to the dealer...
post #9 of 37 Old 08-27-2013, 10:33 AM
Mike Garrett's Avatar
Quoted: 5548 Post(s)
Liked: 3538
Before buying new speakers, I would purchase a couple SVS PB13-Ultra subs, set the crossover on your current speakers to 80hz and then see what you think of your system. Sent you a PM.
mjgarrett100@gmail.com
Mike Garrett is online now
post #10 of 37 Old 08-27-2013, 10:38 AM - Thread Starter
MV_Cinema's Avatar
Many Tanks. Already replied...
Do you think that to join 2 SVS and instead of using the power of the Pioneer Susano i buy a Parasound A51 + A21 will it be worth?
post #11 of 37 Old 08-27-2013, 10:48 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
If he has the coin for Palladium, he can afford the Klipschorn of La Scala.
The problem is that you need a wide room and most people orient their HT room along the other axis.
Consider the Jubilee, along the same favor as Klipschorns but with easier room placement and a more recent design.
psgcdn is offline
post #12 of 37 Old 08-27-2013, 10:53 AM - Thread Starter
MV_Cinema's Avatar
With all the due respect ,but the looks matter to me, and those speakers don't have my favorite look....
post #13 of 37 Old 08-27-2013, 11:08 AM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Then go with the Palladium... modern look and fancy woodwork!
I am in it for the sound, and dynamic horn-loaded speakers are big! But I'll admit that I am likely much older than you and always loved the look of Klipschorns.
psgcdn is offline
post #14 of 37 Old 08-27-2013, 11:11 AM - Thread Starter
MV_Cinema's Avatar
They must have a great sound...would love to hear it.
One of these days i think i made a stupidity...i had INAKISTIC cables single wired, and i bought for 1000 Euros MIT Terminator 2 for the front and center speakers. I think my sound got worst....
My 30 Euros per meter cables were better, can you believe this? mad.gifrolleyes.gifeek.gif
post #15 of 37 Old 08-27-2013, 01:25 PM
psgcdn's Avatar
Quoted: 206 Post(s)
Liked: 307
Considering I spend about $3 per meter on 12 AWG monoprice speaker wire...
(I would love to hear the Palladium!)
psgcdn is offline
post #16 of 37 Old 08-27-2013, 02:45 PM - Thread Starter
MV_Cinema's Avatar
Today i got an advise, from a person with experience and i might keep my Reference set, and sell only the sub.
After i sell my Sub i will connect 2 SVS Subs PB-13 Ultra and calibrate the system.
Then let's see what happens...
post #17 of 37 Old 08-27-2013, 03:06 PM
Quoted: 142 Post(s)
Liked: 730
post #18 of 37 Old 08-27-2013, 03:07 PM
Quoted: 142 Post(s)
Liked: 730
I have 3 svs subs with my rf-7ii system and i couldn't be happier biggrin.gif
post #19 of 37 Old 08-27-2013, 03:39 PM
Kini62's Avatar
Quoted: 1410 Post(s)
Liked: 1293
If you'r still not happy take a look at the JBL Synthesis line.
Def Tech SC8000
Harman Kardon AVR 1600
PS3, Apple TV, Sharp 70" Qattron
Kini62 is offline
post #20 of 37 Old 08-27-2013, 03:42 PM
Liked: 3538
If your not happy with the sound after that, then give the hobby up. smile.gif
Valtyr likes this.
post #21 of 37 Old 08-27-2013, 04:32 PM - Thread Starter
MV_Cinema's Avatar
I think i will be happy...either way i don't think JBL will beat Klipsch...but it's just a guess....
post #22 of 37 Old 08-27-2013, 05:34 PM
shadyJ's Avatar
Liked: 1350
JBL is very much a worthwhile adversary to Klipsch. Their Synthesis line is widely admired, although a bit pricey. Their $70k Everest speakers have some top engineering in them. JBL's upper LSR line is one of the top measuring speakers that money can buy. JBL helped Lusasfilm develop the THX audio specs. They is owned by Harman which has one of the best R&D departments in the audio industry. There is a lot to like about JBL speakers.
shadyJ is offline
post #23 of 37 Old 08-27-2013, 07:10 PM
Kini62's Avatar
Liked: 1293
Hmmmm, I'm guessing their top end line would stomp all over Klipsch, but I'd just be guessing of course wink.gif
JBL is in the vast majority of movies houses throughout the world.
Def Tech SC8000
Kini62 is offline
post #24 of 37 Old 08-27-2013, 07:17 PM
Quoted: 142 Post(s)
Liked: 730
JBL is in the same boat as klipsch. People hear the lower level models and walk away unimpressed. But those lower end models is what keeps the lights on biggrin.gif
post #25 of 37 Old 08-27-2013, 07:20 PM
shadyJ's Avatar
Liked: 1350
True. I don't even think those lower lines are that bad. But their high end lines are as good as anybodies.
Reference_head likes this.
shadyJ is offline
post #26 of 37 Old 08-27-2013, 07:33 PM
Quoted: 142 Post(s)
Liked: 730
agreed, I had a set of lower line jbl 4800s a long time ago and they were nice speakers for the cost. But its a huge gap from the higher end models. Same can be said for klipsch their best buy speakers are ok. But the better klipsch speakers are miles better imo.
post #27 of 37 Old 08-27-2013, 09:10 PM
Liked: 3538
I was referring to the everest:http://www.jblsynthesis.com/Products/Details/122
post #28 of 37 Old 08-27-2013, 10:40 PM
Cowboys's Avatar
Liked: 107
The two PB13 ultra will definitely make a HUGE improvement. I think you will be happy. Your speakers are really realy nice but your SW-115 sub is the weak point in your system. Sub in a theater is a must but until you have great sub(s) to compliment your great speakers, you are missing out quite a bit. You might want to check out the dual Rythmik FV15HP subs which is as good if not better than the PB13 Ultra for a lot less ca$h. Here is databass measurements that lists both the FV15hp and PB13 ultra: http://www.data-bass.com/systems
Ultimately, if money is not an issue (doesn't look like one for you), I would go for the dual JTR Orbit shifter, dual submersiveHP or dual powersound Triax. This will be UNBELIEVABLE AWESOME!
Cowboys is offline
post #29 of 37 Old 08-28-2013, 12:20 AM
shadyJ's Avatar
Liked: 1350
If money isn't an issue, also check out Funk and Danley. Funk is basically the most beautiful high performance subs you can buy (and I do mean high performance), and Danley Sound Labs. Danley's subs aren't going to win any beauty contests, but the sheer SPL from some of those subs are insane. Danley is way beyond SVS subs in performance.
shadyJ is offline
post #30 of 37 Old 08-29-2013, 02:35 PM - Thread Starter
MV_Cinema's Avatar
Just talked with the dealer today, he is going to install in my dedicated room the THX Ultra 2 together with new Processor and Amps.
I will tell my experience then.
Reply Speakers
