Klipsch THX U2 speaker "fatigue" possibly? - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 38 Old 08-28-2013, 11:07 AM
thebland's Avatar
Quoted: 1666 Post(s)
Liked: 1005
Originally Posted by Aaron Smith View Post
Jeff,
Are you using DSP-30/DSP-3/DSP-4 (2in/2out) units, or the Basis/Rave (8in/8out) units by chance? I have a few Basis, but am looking for a few more. smile.gif
(sorry for the hijack)
Hi
I am going to be selling:
4 QSC DSP-4 (2 in/ 2 out)
1 QSC DSP-30 ((2 in/ 2 out)
Goodbye to a great audio and video genius and writer... JOHN GANNON. I enjoyed your friendship, wit and a nice long run we took around Indianapolis at CEDIA years back... and for buying my Runco 980 Ultra years back... you saved my ass! Rest in peace.
thebland is offline
post #32 of 38 Old 08-28-2013, 11:36 AM
MKtheater's Avatar
Quoted: 1736 Post(s)
Liked: 1306
The THX post processing rolls off the highs like in a theater so could help but again, he does not have this so it won't matter. He liked his old speakers in his room the way it is and the new speakers are controlled directivity designed. He is most likely getting much more reflective sound off the back wall and back sides due to the directivity. The Logan's are dipole? He was getting more reflective sound from the front wall and side walls? Treating the room is always a great idea and much better than just applying Eq or whatever.
Marantz 7702 Atmos
Outlaw 7140 and 5000
Speakers- DIY mini arrays all channels.
subs 2 XXX ported SLLT.
MKtheater is offline
post #33 of 38 Old 08-29-2013, 11:01 PM
Reddig's Avatar
Quoted: 248 Post(s)
Liked: 518
It depends a lot on the speakers. With my old speakers, Audyssey flat was a little harsh when turned up real loud. With my current speakers Audyssey flat sounds very good. This is in the same room using the same setup.
Right on. Is the Audessey Flat setting a MultEQ XT-32 feature? My Onkyo NR-809 with MultEQ XT does not have that feature.
JBL Pro Cinema-JTR subs-Sony projection-Elite AT screen-Denon/Oppo electronics-Acoustimac panels
MANCHESTER UNITED!!
Reddig is offline
post #34 of 38 Old 08-29-2013, 11:44 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
My denon 2312 has audyssey flat and it uses multeq xt. Probably worded differently on your receiver.
Mrkazador is offline
post #35 of 38 Old 08-30-2013, 08:19 AM
doublewing11's Avatar
Quoted: 229 Post(s)
Liked: 968
Originally Posted by thebland View Post
I prefer horns and am moving to a PHC set up (Pro Audio Technology). I'm selling my excellent QSC DSPs/EQ and moving to Trinnov room correction to tame my horns (and my room is fully treated)!
Good luck!
Good call......
PHC ie. Proaudio Tech's were the best horn loaded speakers I ran across and came close to purchasing. Long story.......
With Trinnov, I presume you won't use DSP in PHC amps......or will you? Or are you going to use something else to power? Just curious.......
doublewing11 is offline
post #36 of 38 Old 08-30-2013, 08:28 AM
thebland's Avatar
Liked: 1005
Originally Posted by doublewing11 View Post
Good call......
Still working that out. May use the amps' crossovers.
Still considering Seaton's as well but need to get a few answers from Mark. Mark will likely do the subs at a minimum - he's the man.
Excited to get started but still planning.
thebland is offline
post #37 of 38 Old 08-30-2013, 09:42 AM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
You need to angle them, also, position them using the equilateral triangle setup. Angle is super important. Try aim it and you, aim it before you, aim it after you.
Audyssey will help a lot, REW too. These are not the easiest speaker to position.
Also, turn off any "enhancer" function in your receiver.
Plus, I think you are sitting too close to these speakers. Your room may not be big enough for them.
coli is offline
post #38 of 38 Old 08-30-2013, 09:47 AM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Different avr manufactures have different names for the same setting. Denon and Marantz call it audyssey flat while Onkyo and Integra call it audyssey music. And your 809 does indeed have the audyssey music setting, I use it frequently on my 809. wink.gif
I don't need snobs to tell me how to think, thank you!
67jason is offline
Reply Speakers
