What's better front wides or turn rear surrounds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-26-2013, 07:52 PM - Thread Starter
tempnexus's Avatar
I currently have a 7.1 setup with my Onkyo 818.
Basicaly 5 forward and 2 side surround.
The forward are Center, L/R/, L/R wide vis Audessey DSX set to front wide.
So in terms of movie watching would I see better impact with that configuration or should I move the front wide into rear surround?
So 3 front and 4 back?
Where front is Center, L/R
Back is Rear Surround and 2 Side Surround?
tempnexus is offline
post #2 of 4 Old 08-26-2013, 08:51 PM
afrogt's Avatar
Quoted: 1435 Post(s)
Liked: 982
Its totally up to you. Try it both ways and see which way you like it better.
If there was a consensus that the surround backs sound better you probably wouldn't have the option for front wides or heights.
Afro GT
afrogt is offline
post #3 of 4 Old 08-26-2013, 08:53 PM
67jason's Avatar
Quoted: 79 Post(s)
Liked: 802
Depends, if you have the room for proper 7.1 set up it may be beneficial. Personally I have never had the room for rear surrounds, so I have played with wides and heights. I really like wides, audyssey dsx really makes a huge impact on movies.
I don't need snobs to tell me how to think, thank you!
67jason is offline
post #4 of 4 Old 08-26-2013, 08:55 PM
sdurani's Avatar
Quoted: 5135 Post(s)
Liked: 3614
Depends on your seating location.
If your seating is at or near the back wall, then stick to your current set-up (no space behind you for the rear speakers).
If your seating is a few feet away from the back wall, then 4 surround speakers will give you side-vs-rear imaging and wrap-around envelopment that's not possible with only 2 surround speakers.
Sanjay
sdurani is online now
Reply Speakers
