Looking to buy 2.1 computer speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 08-28-2013, 10:24 PM - Thread Starter
gtrplyr201's Avatar
I'm in the market for a 2.1 speaker system. Right now I have Alesis M1 Active 320 USB which I like a lot, the only problem is I don't think I can add a sub to these and I'd like to get a sub. So I'm thinking of moving these to a different room of the house and getting all new.
What I don't understand is what all I need. I've read that I'll need a new sound card and an amp, is that right? I'm using a laptop as my main PC right now so I probably will need a new sound card. I'm ok with that because I plan on building a desktop soon so I'll need a sound card anyways, right?. Do I really need an amp though?
Also should I buy the satellites and the sub separate or as a bundle? I looked at 2.1 speaker systems and found this Corsair SP2500 system that I can get for $200. I like how those look but if I can do better buying the parts separately I'd rather do that.
One last thing I need is that this system needs to plug into my computer but I'd also like to hook it up to use with my Xbox 360 too if that's possible. If the computer and the Xbox 360 could play audio at the same time that would be ideal as well. I'm not too sure what I would need for that though.
Thanks for the help!
gtrplyr201 is offline
post #2 of 28 Old 08-31-2013, 07:45 PM - Thread Starter
gtrplyr201's Avatar
anyone?
post #3 of 28 Old 08-31-2013, 08:57 PM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
coli is offline
post #4 of 28 Old 08-31-2013, 10:04 PM
dansou5's Avatar
Most computer speakers (2.1) have an amp built into the sub. I don't know if you necessarily need a sound card, they are typically used if you are going to use more channels like a 5.1 setup.
I have the http://www.amazon.com/Logitech-Z-2300-THX-Certified-Speaker-Subwoofer/dp/B0002SQ2P2 which are not produced anymore but i believe they make a new version similar to this one. It uses a standard headphone jack that will connect into you laptop/desktop. Now to use these for an xbox you will need to have a tv that has an analog audio out like a stereo jack or a rca audio out. http://www.amazon.com/Logitech-980-000402-Speaker-System-Z623/dp/B003VAHYTG/ref=dp_ob_title_ce this is the model that replaced mine. Ive never heard them but if they are anything like my z2300 you will be happy with them
You could also buy a stereo amp like this http://www.parts-express.com/pe/showdetl.cfm?partnumber=310-300 and buy 2 bookshelf speaks and a speaker level input/output subwoofer.similar to this http://www.parts-express.com/pe/showdetl.cfm?partnumber=300-629 . This way would give you more flexability in what satellite or bookshelf speakers you want and sub you would like to buy. Personally I would probably choose this over computer speakers because of the option to upgrade.
Another option would be to buy a 5.1 home theater receiver and just use it as a 2.1 set up. More expensive but will allow you to upgrade to more channels in the future.
It really depends on how much you are willing to spend.
dansou5 is offline
post #5 of 28 Old 09-01-2013, 08:54 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
$200 won't buy you much. Consider this - good speakers are as complex as laptop. So your price target should be - each speaker equal in price to your laptop. Then we can talk about what's better or worse based on specific preferences and use cases.
ap1 is offline
post #6 of 28 Old 09-01-2013, 11:04 AM
cel4145's Avatar
Quoted: 2659 Post(s)
Liked: 2991
+1
See this CNET review of the Lepai matched with Dayton speakers: http://news.cnet.com/8301-13645_3-57439115-47/build-your-own-desktop-stereo-for-under-$70/ Then get that Dayton sub.
I don't know know how you would do that without some kind of mixer setup. I would abandon that idea.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
post #7 of 28 Old 09-01-2013, 12:18 PM - Thread Starter
gtrplyr201's Avatar
Originally Posted by cel4145 View Post
+1
Awesome thank you! Grand Rapids represent!
post #8 of 28 Old 09-01-2013, 12:20 PM
cel4145's Avatar
Liked: 2991
If you edit your profile, you can add your location.
cel4145 is offline
post #9 of 28 Old 09-03-2013, 10:25 AM - Thread Starter
gtrplyr201's Avatar
I have a question about this setup you were both talking about. I'm having trouble picturing how I would connect the sub to the amp, and also how I connect the amp to my laptop. Other than that I'm loving how this setup is looking
post #10 of 28 Old 09-03-2013, 10:32 AM
coli's Avatar
Quoted: 203 Post(s)
Liked: 42
You can get some pretty decent AV receiver on Craigslist for cheap. Any of the $1000+ non-HDMI receiver now goes for below $50. Get that, then you can get real
speakers like the BS22 ($80 when on sale for a pair), then get an isoacoustic stand, and you got a setup that's worth at least $1000 in sound.
coli is offline
post #11 of 28 Old 09-03-2013, 10:37 AM
cel4145's Avatar
Liked: 2991
The Lepai has both 3.5mm inputs and RCA. So you would hook the sound out from your laptop headphone jack to one of them (depending on what type of cable).
You can hook the Dayton sub up in two ways:
1) Connect the speaker out from the amp to the speaker level inputs on the sub, then the speaker level outputs to the speakers. This will pass through the amplified speaker signal and allow you to control the volume of both with the Lepai.
2) Split the output from your computer and run it to both the Lepai and the sub. This would mean you would have to set the volume on the amp and the sub to match them, then control volume with your computer.
cel4145 is offline
post #12 of 28 Old 09-03-2013, 12:30 PM - Thread Starter
gtrplyr201's Avatar
I'm starting to wonder if the Lepai is necessary reading into it more. Couldn't I just run the speakers to the sub's amp and call it good?
post #13 of 28 Old 09-03-2013, 01:08 PM
cel4145's Avatar
Liked: 2991
The sub amp is only for powering the sub.
cel4145 is offline
post #14 of 28 Old 09-03-2013, 01:47 PM - Thread Starter
gtrplyr201's Avatar
I'm still incredibly confused. The Lepai only has room for 2 channels it looks like, so where would the sub input to it?
post #15 of 28 Old 09-03-2013, 01:50 PM
cel4145's Avatar
Liked: 2991
The sub does not "input to it." Connect the speaker outputs on the Lepai to the sub speaker level inputs. Look at pictures of the back of each.
cel4145 is offline
post #16 of 28 Old 09-03-2013, 02:08 PM - Thread Starter
gtrplyr201's Avatar
So let me make sure I have this correct lol. Speakers go into the sub, sub goes to the lepai, lepai goes to computer?
post #17 of 28 Old 09-03-2013, 02:18 PM
cel4145's Avatar
Liked: 2991
Yes. But I can see how you are not conceptualizing it because you are listing it backwards from the way I did. The audio signal goes from your computer to the Lepai, where is amplified. Then the amplified output goes to the sub, which passes it through to the speakers. So learn it not by how it is connected, but how it works smile.gif
cel4145 is offline
post #18 of 28 Old 09-03-2013, 02:22 PM
losservatore's Avatar
Quoted: 2303 Post(s)
Liked: 2048
lol at least you perfectly understand ,either way is the same.
Living Room :Oled 65" B6 / Marantz SR7010 / Xbox One S / PS4 Pro / HTPC / 2 PSA XS30 / Revel Performa3 F206 / Revel Performa3 C205 / Revel Surrounds / Sonos Connect / Roku 4 Ultra /Amazon Fire tv /
losservatore is offline
post #19 of 28 Old 09-03-2013, 04:06 PM
cel4145's Avatar
Liked: 2991
I don't know about that. If he understood it, he wouldn't have had to ask again smile.gif
cel4145 is offline
post #20 of 28 Old 09-03-2013, 04:24 PM
Liked: 2048
post #21 of 28 Old 09-03-2013, 05:07 PM - Thread Starter
gtrplyr201's Avatar
Ah thank you! I think I understand now smile.gif I was going to start ordering soon until I saw this warning to stay away from the B652's. Now I'm not too sure if I want to try those or get something else!
post #22 of 28 Old 09-03-2013, 05:39 PM
cel4145's Avatar
Liked: 2991
That's good. If it's your first foray into passive speakers and amps and such, good to learn enough about it to understand it smile.gif
I read on another forum that someone called Parts Express, and they told him that they had corrected that problem. You could place your order by phone and confirm that smile.gif
cel4145 is offline
post #23 of 28 Old 09-03-2013, 05:50 PM - Thread Starter
gtrplyr201's Avatar
Excellent! Here is a photo of my shopping cart, I hope I have everything smile.gif
post #24 of 28 Old 09-03-2013, 06:08 PM
cel4145's Avatar
Liked: 2991
That looks good. Although I would be tempted to buy 18 or 20 gauge wire. However, 22 gauge should be enough.
Also, the Lepai amp is cheaper on Amazon. And the Dayton SUB 1000 is free shipping there, too, in case it's not at Parts Express. Might check Parts Express and Amazon against each other. smile.gif
cel4145 is offline
post #25 of 28 Old 09-03-2013, 06:22 PM
Liked: 2048
If you cant wait and want everything delivery at once go ahead, but if you can wait a save you some money cel is giving you a better option. Is your choice smile.gif
post #26 of 28 Old 09-03-2013, 06:38 PM - Thread Starter
gtrplyr201's Avatar
I did check on amazon for the Lepai amp but it said it would take 17-26 days to ship eek.gif wasn't worth it in my opinion so I just went with everything on parts express for the ease of it. I got a Labor Day $10 discount which completely payed for the shipping so I basically got free shipping anyways. I can't wait to get it!
post #27 of 28 Old 09-03-2013, 06:49 PM
cel4145's Avatar
Liked: 2991
Just search for "Lepai" on Amazon and see what comes up. This seems to be in stock and immediate shipping: http://www.amazon.com/LP-2020A-Lepai-Tripath-Class-T-Amplifier/dp/B0049P6OTI/
cel4145 is offline
post #28 of 28 Old 09-03-2013, 06:51 PM - Thread Starter
gtrplyr201's Avatar
Oh, ya that one is probably shipping sooner but Lepai had the new upgraded 2013 model on there that I was hoping to get but I didn't want to wait that long for it. I don't mind though, I have placed my order smile.gif
Reply Speakers
